Nov 06, 2018, 07:09 AM
Quad Erat Demonstrandum
scousethief's Avatar
New Product
Feiyue FY03H 1/12 2.4G 4WD BRUSHLES Rc Car Metal Body Shell Desert Off-road Truck RT
https://www.banggood.com/Feiyue-FY03H-112-2_4G-4WD-Brushless-Rc-Car-Metal-Body-Shell-Desert-Off-road-Truck-RTR-Toy-p-1376223.html
BRUSHLESS VERSION , METAL GEARED SERVO, WATER PROOF
Description:
Basic information Brand:Feiyue
Item No:FY-03H
Scale:1/12
Color:grey and red
Max speed:≥35km/h Power System ESC:40A all waterproof metal case ESC
Motor:brushless 3800kv motor
Servo:all metal gear 2.2kg servo
Transmitter Frequency: 2.4G
Full scale synchronous control system (gun control)
Channel: 4CH
Remote distance:≥ 80m
Battery:4X 1.5V AA(not included) Battery Car Battery:7.4V 1500mAh lipo battery(included)
Charging time:about 2.5hours
Using time:about 15minutes
Other Material:hardware,plastic and metal Dimension Car Size:402316.5cm(L*W*H)
Wheelbase:247mm
Tread:193mm
Features:
1.Full car ball high speed bearing
2.Full vehicle transmission components, chassis strength upgrade
3.Metal gear planetary differential
The difference between this one with the product id ID: 1375629:
1.This one motor is brushless,and the 1375629 is brushed
2.The esc has been upgraded to all metal and waterproof;servo change to all metal gear 2.2KG
Package included:
1X Rc Car(included the car battery)
1X Transmitter
1X 7.4V Balance EU Charger
1X Manual
1X M4 Cross Wrench
1X 1.5mm Hex Wrench
1X 2.0mm Hex Wrench
2X Clasp
1X M3 Machine Screw
2X Motor Gear
Nov 12, 2018, 07:17 AM
kodak_jack's Avatar
Looks very interesting. Hope to see a review soon.
Nov 21, 2018, 07:06 AM
On its way now thankfully
Nov 23, 2018, 05:36 PM
Panhead5496's Avatar
That looks sweet!!
Latest blog entry: Life Updates :)
Nov 24, 2018, 08:21 AM
Nice to see the OG model getting a new lease of life. Not sure it needed any more weight up top though!
Nov 29, 2018, 02:42 PM
wow this thing just jumped in price! went up 50+ bucks Canadian in the last couple days..
Apr 19, 2019, 12:53 AM
BajaBugBasher's Avatar
Slipper clutch ???
Does anyone know how thick the pressure plate is?
tia
Apr 19, 2019, 06:23 AM
kodak_jack's Avatar
This version of the buggy gets very good reviews on Banggood. How is it holding up for those who bought it? I know I would want the brushless motor and ESC for reliability, but does it make the buggy too fast for normal bashing? I bought a ZD Racing monster truck in December and probably should have bought this one instead.
Apr 19, 2019, 05:22 PM
cbp
cbp
I bought it and ran it inside the apartment.
After about 3 runs and a jump, a rear plastic part holding the axle in place broke. I glued it but didn't run it since.
Waiting on the metal replacement parts to arrive.
The remote has two modes. One for kids and a normal mode. Inside the house the kids mode is ok.
In normal mode, when you brake, the car rolls over. If you turn too fast it rolls over.
I wouldn't buy it to use as is. Parts will break. I'd order upgrades to have them available when needed. Price doubles.
Apr 19, 2019, 05:45 PM
cbp
cbp
Apr 19, 2019, 08:40 PM
kodak_jack's Avatar
I've read of how the ESC on brushless vehicles can be adjusted and that includes the brake. I've never done it, but can see how it can be an issue. To do that, you need a programming card.
Apr 20, 2019, 07:41 AM
cbp
cbp
Yes, I ordered a brushless kit that comes with a programming card. Still waiting on it to come from China.
I will test it out to see if I can program the FY03 esc.
Apr 20, 2019, 12:51 PM
kodak_jack's Avatar
I'm not so sure you needed to buy the whole kit. I think you could have gotten away with just buying a programming card, but I'm not absolutely sure.
How fast is it when you're trying to just drive around? If it's too fast for normal use, you may have to gear it down. Doesn't it come with a few other gears to try? I had a guy who frequents the 12428 Mod thread say the gears weren't the right size, but if the hole that fits on the motor shaft is too small, can't you drill it out? Understand that this is all speculation because I don't have one, but this and the 12428 are very close to the same.
Apr 20, 2019, 03:33 PM
What about Feiyue FY07, is it more stable than FY03?
Because probably will buy one, but can't decide which Feiyue.
Apr 21, 2019, 06:39 AM
kodak_jack's Avatar
They're all basically the same. They have plastic parts that will break. The rougher you use it, the more likely something will break. When you replace plastic parts with metal ( usually aluminum), the next part after that becomes more vulnerable. As I have said, I wanted a brushless drive so it is more reliable than brushed, but then it may become too fast for my driving style. It seems that most lower priced cars,trucks and buggies give you many plastic parts that eventually get replaced with upgraded parts. There is nothing from one version to the next that makes it more stable. Going to wider wheels and tires may help with that. Otherwise, it's more your driving than anything else that determines how stable it is. Why not just buy the original FY-03 and have fun with it? There is plenty of support on the thread for that vehicle if you run into anything you need help with.
New Product Feiyue FY03 Eagle-3 1/12 Off-Road Truck 2.4G 4WD Desert Safari Racer RC Car GeekBuying Micro Cars 158 May 20, 2019 06:54 PM
New Product Feiyue FY03H 1/12 2.4G 4WD BRUSHLES Rc Car Metal Body Shell Desert Off-road Truck RT scousethief Banggood.com 1 May 09, 2019 04:04 PM
New Product Feiyue FY03H 1/12 2.4G 4WD Metal Body Desert Buggy Brush RC Car - Red Merch Banggood.com 0 Nov 05, 2018 01:57 AM
New Product Feiyue FY03 Eagle-3 1/12 2.4G 4WD Desert Off-Road Truck RC Car Kenxiaofei Car Talk 4 Dec 31, 2016 06:08 AM
Discussion FEIYUE - 02 1 : 12 2.4G Full Scale SUV 4WD RC Off-road Racing Car S3MKi Off-road Cars 1 Feb 17, 2016 09:40 PM
