Nov 05, 2018, 01:57 AM
Merch's Avatar
New Product
Feiyue FY03H 1/12 2.4G 4WD Metal Body Desert Buggy Brush RC Car - Red
https://www.banggood.com/Feiyue-FY03H-112-2_4G-4WD-Metal-Body-Desert-Buggy-Brush-RC-Car-p-1375629.html
Description:
Basic information Brand :Feiyue
Model:FY:03H
Proportional:1/12
Color:White and red
Material:metal Power System Motor:390 brush motor
ESC:2CH 2.4G 40A
Charge:Included
Transmitter Transmitter frequency:2.4G
Control Channels:2 Channels
Control distance:About 80m Battery Battery for Car: 7.4V 1500mAh Rechargeable Battery Pack(Included)
Battery for Transmitter: 4x 1.5V AA Batteries(No Included)
Other Running time: About 15mins
Charging time: 150mins
Control distance:35M
Max speed:35km/h Dimension Product size:402316.5cm
Package Size: 50*20*21cm
Wheelbase:247mm
Tread:193mm
Feature:
1. Charging protection: protection against overcharging and overcurrent of the battery.
2. Low voltage protection: The receiver automatically stops working when the battery power is lower than 6.5V.
3.High temperature protection: When the working temperature of the receiver is higher than the setting, the receiver will protect the drive control circuit;
4.The model is equipped with full-scale synchronous control functions such as forward, backward, left and right turn, and brake.
5.1500mAH large rate lithium battery
6. 2.4G full-scale synchronous remote control system.
7.19g high-speed steering gear (1 kg torque)
8.front wheel torsion shaft independent horizontal suspension suspension system, rear multi-link straight bridge suspension
9.2CH 2.4G 40A integrated control ESC
10. damped independent metal shock absorber.
11.All metal difference Gear 8. Remote control upgrade configuration to increase adult mode and child mode
Package:
1x rc car
1x transmitter
1x 7.4V balanced charger
1x Chinese and English bilingual manual
1x M4 cross wrench
1x 7.4V 1500MAH lithium battery (T plug)
1x 1.5mm hex wrench
1x 2.0mm hex wrench
1x Clasp
2x M3 machine meter screw
1x Motor gear
New Product Feiyue FY03 Eagle-3 1/12 Off-Road Truck 2.4G 4WD Desert Safari Racer RC Car GeekBuying Micro Cars 158 May 20, 2019 06:54 PM
New Product Feiyue FY03 Eagle-3 1/12 2.4G 4WD Desert Off-Road Truck RC Car Kenxiaofei Car Talk 4 Dec 31, 2016 06:08 AM
Discussion FEIYUE - 02 1 : 12 2.4G Full Scale SUV 4WD RC Off-road Racing Car S3MKi Off-road Cars 1 Feb 17, 2016 09:40 PM
Discussion Desert Buggy FEIYUE 1/12 2.4G Full Scale 4WD raul329 Micro Cars 0 Aug 31, 2015 10:42 AM
