This thread is privately moderated by Merch, who may elect to delete unwanted replies.
Nov 04, 2018, 06:33 PM
Merch's Avatar
Mini-Review
HG P104 1/10 2.4G 4WD 25km/h Rc Car Knight 550 Brushed Big Foot Off-road Truck RTR
https://www.banggood.com/HG-P104-110-2_4G-4WD-25kmh-Rc-Car-Knight-550-Brushed-Big-Foot-Off-road-Truck-RTR-Toy-p-1337415.html
Description:
Basic information Brand:HG
Item No:P104
Scale: 1/10
Main Color:red
Max speed:25+km/h Power System ESC: 80A 2 In 1 esc
Motor:550 brushed motor
Servo:3kg S3003 standard analog plastic gear servo
Transmitter Frequency: 2.4G
Channel: 3CH
Remote distance:≥ 100m
Battery:4X 1.5v AA(not included) Battery Car Battery: 7.4V 3000mAh 30C Lipo battery(included)
Charging time:about 6hours
Using time:about 15minutes
Other Material:hardware,electronic and plastic Dimension Car size:41.5*34.5*19cm(L*W*H)
Wheelbase:300mm
Track:265mm
Wheel diameter:120mm
Wheel width:75mm
Function:
Forward,backward,brake,turn left/right/around
Features:
1.The remote control is with channel forward and reverse settings and it is automatic frequency
2.Brake / no brake function can be switched
3.Independent suspension shock absorber system
4.Front and rear is with differential
5.Ball bearing and Closed gear dustproof drive
6.Adustable metal suspension link
7.High grip sponge TPR soft tire
8.Metal shaft drive system
9.Damping adjustable shock absorber
Package included:
1X Rc Car(included the car battery)
1X Transmitter
1X 7.4V Balance Charger
1X Manual
1X Accessories Set
Nov 13, 2018, 09:45 PM
Merch's Avatar
The rainy weather has been stopping me from reviewing this truck because the ESC is not waterproof, I should have it done in the next few days
Nov 19, 2018, 07:10 AM
Merch's Avatar
Sorry for keeping you waiting the video is done just need to edit it!
Nov 20, 2018, 10:09 PM
Merch's Avatar
Pro:
Fully RTR with a 2s 3000mah lipo
Very tough,nice looking body shell
Good run time 15+ minutes
Metal steering links,dogbones,differential cups,axel cups also with front and rear wheel bearings
4WD front and rear metal difarential gears
Good range around 100 meters with failsafe
Good ride hight for getting up kirbs
Decent tires for off road with soft foam inserts
Nice transmitter with a good grip and trigger,with low,med,high speed switch
Cons:
Spring loaded shocks
None waterproof ECS
No sensitivity knob for the proportional stearing
Main driveshaft gear is plastic
Transmitter battery bay is very loose needs to be held on with some tape
Top speed 15mph a bit slow for me but good for beginners
Long charging times from the stock charger
Tires are a bit to soft imo
Overall it's a good truck for begginers could do with a little more speed.
Nov 21, 2018, 04:26 PM
Merch's Avatar
Updated with some pros and cons.
New Product HG P402 1/10 2.4G 4WD Rc Car 540 Brushed Rock Crawler Metal 4X4 Pickup Truck RTR Toy Merch Banggood.com 6 Mar 25, 2019 10:56 AM
New Product HG P403 1/10 2.4G 4WD 49cm Rc Car 540 Brushed 20m/h Rock Crawler Off-road Truck RTR Merch Banggood.com 0 Sep 28, 2018 02:19 AM
Discussion HG P104 1/10 2.4G 4WD 25km/h Rc Car Knight 550 Brushed Big Foot Off-road Truck RTR To scousethief Banggood.com 0 Aug 13, 2018 05:30 AM
New Product Vkar 21201 1/10 2.4G 4WD 375mm Brushless Rc Car 80km/h Metal CVD Buggy Off-road Truck scousethief Banggood.com 0 Aug 09, 2018 06:31 AM
New Product HSP RGT 18000 1/10 2.4G 4WD 470mm Rc Car Rock Hammer Crawler Off-road Truck RTR Toy scousethief Banggood.com 0 Jul 26, 2018 05:22 AM
