Dec 29, 2004, 09:46 PM
gpw
gpw
“There’s no place like Foam”
gpw's Avatar
J250DD "Mini-Horten"...
Ok, guys ... inspired by Jerbears' Simple Wing , I came UP with the Mini-Horten as a sorta' scale alternative...really easy to build ... pretty hot flyer ... no airfoil , no dihedral , j250 with flux ring and 3x3 prop ...2/1200 lipos ...put Grandma in the car when you fly this one ... responsive...
I just sent HIPPO the plans at FoamFly and he should have them UP in the gallery soon , I had all sorts of trouble posting them so I just sent them to him .... as soon as we get a link we can post it here... Have FUN !!!
Dec 29, 2004, 10:17 PM
Trying to defy gravity...
jimsky's Avatar
gpw,
Very cool. Look simple, cheap and fun...just what a Bluecor foamie is supose to be. Those German engineers were years ahead of their time. Where did you get the Iron Cross decals?
Mid motor mount, that's a nice twist. You may have lured me out of my self inflicted "no more building" promise. Now that I added an Optic to my radio collection , I've got an empty Flash4X to play with.
If you want to up fun on the J250, but don't want to deal with the hassle & weight of a real prop adapter (those rubber things just don't work) try a 4X3 (100mm X 80mm) Hobby Electronics dark orange "twisty" prop. Flexible (un-breakable) plastic and they fit on an EDP50 shaft. A quick drill out, and they fit on a J250 shaft with no adapter needed. Balsa Products carry the prop, for 80 cents each. A very wild prop indeed.
http://www.balsapr.com/catalog/prope...LargeImage=yes
Thanks again for your never ending Bluecor inspired creativity.
Jimsky
Dec 29, 2004, 10:35 PM
JAM
JAM
MaxAmps CMO
JAM's Avatar
GPW nice job, I'm gonna add that one to my J250 file for future bashing. Keep up the good work. If you have a cad of it I'd be interested. PM me if you do.
TM
Dec 29, 2004, 11:55 PM
gpw,
I love Hortens. Anxious to put blue foam, J250, gws 4x2.5 and 4 gm servos to work as soon as possible. Awaiting plans.
Thank you for the thread.
Dec 29, 2004, 11:58 PM
Can't build them all!
AKACully's Avatar
GPW,
Looking forward to the link for the plans.
Bill "AKACully"
Dec 30, 2004, 10:32 AM
gpw
gpw
gpw's Avatar
Oops!!!!!
I just noticed that I drew the tongue depresser motor mount on backwards with the rounded end towards the prop opening .... MY DUMB!!!!... Picture indicates the correct motor mount layout ....
Thanks for the prop tip .... I'll order a few asap....3x3 is rather "slippy"
just talked to HIPPO and he said he'd have the plans UP this AM.... Cool!!! You can print out the plans on some index card stock and you'll have instant templates .... I'd suggest cutting out a few ,cause OFB's will want one once they've seen yours fly ..... and I have a backUP....hahahaha...hot little wing!!!.....hahahaha
Latest blog entry: Lost plans
Dec 30, 2004, 11:41 AM
jimsky's Avatar
Yahoo, it's up at FoamFly.
http://www.foamfly.com/gallery/Mini-Horten
Looks like I'll be cutting some Bluecor tonight.
Jimsky
Dec 30, 2004, 07:36 PM
AKACully's Avatar
Got it!!!!! Thanks
Bill "AKACully"
Dec 31, 2004, 08:01 AM
gpw
gpw
gpw's Avatar
j/sky ... thanks for the link .... iron cross decals are actually black Sharpie ,hand scrawled... and by the way , the blue tape is Scotch masking tape ... slightly reinforces edges (keeps the skin from peeling on the edge), and after a few days becomes permanent ...don't get carried away with anything that adds weight though ....
I wonder what a cd motor would do on here ....????I think it would fly with an ips A motor (if kept light) much , much slower though ....
You guys have FUN !!!!
Jan 01, 2005, 03:58 PM
Ack
Ack
Waiting for Balsa Products order...
GPW:
Thanks for the opportunity to build the Mini Horton!
I have a construction question: (the answer may be obvious, but I thought I'd ask in hopes that others who are wondering could be informed)
Do the wings butt together? Or are they attached to the sides of the "keel"? I noticed that you either drew in the wing profile or a "tab" line on the drawing. One picture looks like they are butted together, another picture looks like the wings are glued to the keel.
I ordered the HE props from Balsa Products along with a few other items that escaped my notice from the last order... I wish the LHS was closer and better-stocked!
Again, Thanks!
Ack
Jan 02, 2005, 12:07 PM
gpw
gpw
gpw's Avatar
Ack... the wing is one piece of foam , flat with no dihedral ... it butt glues to the fuse(keel) ... I only show half the wing on the plan to save space...I usually make a half template as shown ... draw one half , flip it over and draw the other half... cut it out as one piece...OK!!!
why are hobby shops so far away ????
Jan 02, 2005, 11:06 PM
gpw
Finished building the wing today. Some how I missed the C.G. location. Will the leading edge in line with the rudder/fin be close. If any one is interested and I can figure out how to send them, PDF file of crosses and Horton logo are avaliable.
Jan 03, 2005, 08:29 AM
gpw
gpw
gpw's Avatar
LD&D... in the picture on the bottom , the motor close -UP, you'll see a little green dot in front of the tongue depressor motor mount ... that's the CG , rather small but it works...
It's rather easy to figure the cg on these wings ,or come close ... simply go halfway out between the root and the tip , find 33% from the le do the same for the other side of the wing .... connect the two marks ,and where the line runs through the fuse , that's where the CG is ... or at least a good place as any to start .... some adjustment may be necessary to suit particular flying styles...
Jan 03, 2005, 08:36 AM
gpw
gpw
gpw's Avatar
Any Horten logos or IC pics would be greatly appreciated....we could print them out , give em' a coat of clear Krylon and glue them directly to the foam .... COOL!!!! much better'n those hand drawn Sharpie things...little heavier though ...try putting em' UP here ... that may work ... Thanks !!!
Jan 03, 2005, 12:32 PM
Cool little plane! Is the J250 the same as the DCM-189 and what part of the motor is the flux ring?
Thanks for another project.
Andy
Video Pilots View From Mini Horten CD motor UBILDIT Electric Plane Talk 0 May 31, 2006 09:21 AM
