Nov 02, 2018, 07:56 PM
Seagull Edge 540 (180) Engine Mounting
The seagull manual says to drill the holes for the mounts and then attach them. However it doesnít provide any mounting template or anyway to center the engine mounts so that it will come out in the right spot on the Cowl. Does anybody have any advice about how to drill the holes for this? Itís the blue one.
Mar 30, 2019, 08:01 AM
i work on boats so i'm fairly new to aeromodelling, but i'd put grease(or prussian blue if you're a machinist) on the motor mount and hold the motor/mount just above the surface and put the cowl over(very tricky) and onto the nose, center the spinner with your eyes and press down where you want it, the grease should leave a mark where you want your holes
Discussion Seagull edge 540 180 146skip Fuel Plane Talk 2 Aug 31, 2017 04:44 PM
Discussion Seagull edge 540 (180) colthillary Fuel Plane Talk 12 Apr 21, 2014 06:09 PM
Discussion EDGE 540 180 Seagull canister tunel Stefansuba Fuel Plane Talk 0 Mar 05, 2012 08:53 PM
Discussion DLE 30cc for edge 540 180 seagull Stefansuba Engines 1 Jul 14, 2011 01:47 AM
Discussion Best engine for the Seagull Edge 540 180 marksherlock Competition Aerobatics 6 Jul 26, 2010 09:48 PM
