Mar 02, 2020, 03:02 AM
I want to order these wifi-adapters https://aliexpress.ru/item/32971875623.html
What is the difference between 2 and 2.54mm? With a directional antenna there will be a range of about 2-3km?
Mar 02, 2020, 04:28 AM
These adapters have 2 pin rows in their layout, one with 2mm pin pitch, the other with 2.54mm. Only one of these seems to be placed in the different variants.
This sounds to be possible. However, you may consider to use an adapter with higher output power for the AirPi instead. So you wouldn`t need to point your directional antenna to the aircraft.
Mar 02, 2020, 06:43 AM
Best translator i know: www.deepl.com
means: Цвет: = color
Mar 03, 2020, 03:17 AM
Good morning when it is possible to have an image for pi4b
Unfortunately I have the pi4b available
Thank you
Mar 03, 2020, 07:04 AM
Thank you
Stephen is working on this. He likes to release things that work well. So probably 1 to 4 weeks is my guess
Mar 03, 2020, 09:50 PM
RocketMouse's Avatar
Please advise what's the best DIY CCTV IP camera module tested so far?
Mar 07, 2020, 08:02 PM
Hi
I have ordered and now received the little lan/adapters from aliexpress.
https://de.aliexpress.com/item/32957...3eec4c4d9z7hvV
At first: they work
But the connection description seems to be wrong. I had to swap USB D+ and D- to make it work.
Mar 08, 2020, 05:04 AM
Complicating things
Karamba's Avatar
How you used it? Rx?
At5.3ghz?
Mar 08, 2020, 05:29 AM
I have tested them on RX with different Alfa on TX.
It all works and my former RSSI problems are no longer present.
Finally I want to use them on RX and TX
Mar 08, 2020, 08:21 AM
Complicating things
Karamba's Avatar
5ghz?
Mar 08, 2020, 09:19 AM
>5ghz?
Yes
Mar 08, 2020, 11:26 AM
Complicating things
Karamba's Avatar
What you used for antennas? Linear or circular?
Mar 08, 2020, 11:41 AM
Hello
Until now always circular.
https://www.docu-and-info.de/gallery3/Antennenbau
But for my little copter with Pi Zero i will try linear next days.
Mar 08, 2020, 02:17 PM
Htcohio
Htcohio's Avatar
@RocketMouse,
The recommended IP Cameras are Hisilicon type board cameras.
I have used the Hi3516CV300 IMX291 and it looks good but, does not have WDR. The previous developer Vitaliy posted some flight video.
планерная гора (25 min 14 sec)
Also, another user tried Hi3516E & Hi3518.
IP board 1080p camera based on Hi3516E also working perfect with OpenHD (3 min 45 sec)
IP camera based on Hi3518 working with OpenHD (1 min 47 sec)
This is a hisilicon HI3516A with IMX291 sensor but, supposedly supports 50/60FPS...
*This would be ideal if it's actually correct because, higher FPS results in lower latency.
With Hi3516, 3518, 3519 etc... Just be sure to read all the specifications closely to match what you're looking for and maybe contact the seller.
**Example: Hi3516cv300 w/ Imx291 is considered one of the lower end type cameras it's actually the same one I have.
But, Hi3516A seems to be higher-end.
https://www.aliexpress.com/item/32947438654.html
Aliexpress can be such a cluster fuk sometimes trying to find exactly what you're looking for in terms of information.
Overall, any IP camera from Hisilicon should work and, one of the larger versions with a high-quality zoom lens can easily be adapted for an inexpensive zoom UAV.
AS with most things, the more expensive cameras on there will probably have higher quality and performance but, if you just buy a $20 camera it should work good enough.
Sent from my SM-G975U using Tapatalk
Mar 08, 2020, 06:24 PM
Htcohio, thank you for your answer. I agree that Ali web site is really annoying in any aspect.
I did some research and it looks like you are right - HI3516A is the one most expensive, but the only supports 60fps.
http://www.xiongmaitech.com/en/index...il/185/187/377
- Advanced Full-HD IP Camera Soc - Hi3516DV100
- Mainstream Full-HD IP Camera Soc (FHD 30fps):
Hi3516CV300 - 2-frame WDR, Tone mapping
Hi3516CV100/200 - DWDR, Max.2M Pixel
Hi3518EV200/201 - DWDR, Max.2M Pixel
Here is some data:
Hi3516A - H.264/H.265 @ [email protected] fps − [email protected]60 fps
Hi3516E V100 - H.264/H.265 @ 1920 x [email protected] fps + 720 x [email protected] fps
Hi3516E V200 - H.264/H.265 @ 1920 x [email protected] fps + 720 x [email protected] fps
Hi3516E V300
Hi3516C V200 - H.264 @ [email protected] fps
Hi3516C V300 - H.264/H.265 @ 1920 x [email protected]45 fps
Hi3516DV100 - H.264/H.265 @ 1920 x [email protected] fps + [email protected] fps
Hi3516D V300 - H.264/H.265 @ 1920 x [email protected] fps + [email protected] fps
Hi3518E V200 - H.264 @ [email protected] fps
Hi3518E V300 - H.264/H.265 @ 1920 x [email protected] fps + [email protected] fps
Best sensor is IMX307 2mp ( prev 291) or IMX335 fir 5mp.
Discussion Open 3D Flight Assistant discussion and creation thread racermark DIY Electronics 5 Apr 07, 2018 11:54 PM
New Product <Discussion thread>Hubsan H111C&H111D 720P HD Camera Quadcopter RTF BG Well Mini Multirotor Drones 62 Sep 06, 2016 08:59 PM
New Product Discussion thread---FQ777-124C MINI With 2.0MP HD &Switchable Controller BG Well Micro Multirotor Drones 41 Aug 11, 2016 05:51 PM
Discussion An open discussion about Model Aviation, the FAA, and the AMA dag214 Model Aircraft & Drone Advocacy 46 Dec 24, 2015 11:07 AM
New Product HeadPlay HD FPV Headset w/ 32ch 5.8GHz Receiver - Pre-Order open at GetFPV.com GetFPV FPV Equipment 41 Dec 13, 2015 03:33 PM
