Jan 12, 2020, 08:43 AM
Originally Posted by narpat007
Yes, its working.
Which is the URL for the stream from the camera?
At the bottom of the aliexpress's page, in the FAQ there are a couple of examples of rtsp streaming, did you use them?
..and how about latency?
Many thanks for your informations!!
Jan 13, 2020, 02:19 AM
Rana
Originally Posted by Karamba
so if i have Pi3B airside i dont need usb-LAN adapter?
Right !
Latency?
Not measured, but very low almost no delay noticable.
Comments embedded above in blue!
Jan 13, 2020, 02:43 AM
Rana
Hi, pls have look at https://github.com/OpenHD/Open.HD/is...ment-538705892
Jan 17, 2020, 12:33 PM
Hi
I allways try to find lightest and easy to handle material for OpenHD-Copter
My personal goal with OpenHD:
As small and light little HD-race-copter, of course < 250gr
Range about 800m
Flight time about 10min
Stable video link with RSSI and mavlink
no gps, no long range
I am close :-)
regards
Jochen Causemann
Jan 22, 2020, 05:34 AM
Does anyone use two AirPi WiFi dongles with different frequencies? Is that the point, a more stable connection?
Jan 25, 2020, 05:24 PM
Does not work well with 2 on the Tx, best is to have more on the Rx side.
Like they say in the HAM Radio world " small mouth but big ears " More important to have a good RX antenna.
I use 3, one basic one that comes with the USB dongle and 2 others for longer range. Dipole and Patch.
Right now the Tx is an ASUS AC-56 0n 5.8
Jan 27, 2020, 02:13 PM
Hello, I am collecting information and making a list of components to build my OpenHD system and I have some doubts.
1. Would it be correct to use an ASUS USB-AC56 in the air unit with the stock antenna and a Pi Zero W and in the ground unit a single Alfa AWUS036ACH with two good antennas and a Pi 3B +? Or is it better two ASUS USB-AC56 also on the ground? Is it compatible with the current OpenHD image, plug and play?
2. Which antennas do you recommend for long range on an airplane, which on the ground and which on air with the setup of point one?
3.My intention is to fly the first few times with 1.2 GHz video in buckup mode in case there is a problem, does that frequency affect digital 5.8 in any way?
https://www.amazon.es/ASUS-USB-AC56-...0152167&sr=8-3
https://www.amazon.es/Alfa-AWUS036AC...0078659&sr=8-2
Jan 27, 2020, 03:01 PM
Complicating things
Karamba's Avatar
hello
this thread is outdated
visit this channel
https://t.me/OpenHD_HDFPV
Jan 27, 2020, 04:55 PM
If you are going 5.8 then the AC-56 is the best choice.
1 Tx and 2 RX for diversity .
Lots of choice in 5.8 for antennas and just as many opinions but you should setup and debug the system with the stock ones first and only then change for longer range.
I can get down to -90 rssi without glitches using the Ac-56 and stock antennas.
Good examples here
https://www.youtube.com/channel/UCRz...cWVGqCA/videos
Jan 27, 2020, 07:03 PM
Good examples here
Thanks for the tip on using the AC-56 on 5.8ghz. I had one for my desktop and was about to toss it out because it was too flaky with Windows 10. Just for fun I tried it with Open.HD and was amazed how much better RX signals were than the TP-Link TL-WN722N. I have plans to move to 5.8 at some point and will definitely be keeping this adapter around.
Jan 28, 2020, 05:56 AM
Good examples here
Thanks for answering,
For long range which is better 2.4 or 5.8?
DragonLink world well whit OpenHD?
In the telegram group they have not answered me or have not read my questions.
Jan 28, 2020, 09:52 AM
Complicating things
Karamba's Avatar
2.4 is more "penetrating" and WILL work better for LR
but.. it is the size of antennas on air side - 2.4 cloverleaf twice bigger
Jan 28, 2020, 10:10 AM
Thanks.
What is the reason why the ASUS USB-AC56 does not work in 2.4?
Jan 28, 2020, 10:15 AM
Have in mind that 1.2 video can cause big problems on 2.4 systems.
Both on WIFI and RC.
Speaking of own experience...
Jan 28, 2020, 12:01 PM
Where is the best starting point for OpenHD? The links on first post of this thread?
The Telegram link a few posts back seems like a stream of consciousness -- good for chatting and sharing but impossible to use as a reference.
Discussion Open 3D Flight Assistant discussion and creation thread racermark DIY Electronics 5 Apr 07, 2018 11:54 PM
New Product <Discussion thread>Hubsan H111C&H111D 720P HD Camera Quadcopter RTF BG Well Mini Multirotor Drones 62 Sep 06, 2016 08:59 PM
New Product Discussion thread---FQ777-124C MINI With 2.0MP HD &Switchable Controller BG Well Micro Multirotor Drones 41 Aug 11, 2016 05:51 PM
Discussion An open discussion about Model Aviation, the FAA, and the AMA dag214 Model Aircraft & Drone Advocacy 46 Dec 24, 2015 11:07 AM
New Product HeadPlay HD FPV Headset w/ 32ch 5.8GHz Receiver - Pre-Order open at GetFPV.com GetFPV FPV Equipment 41 Dec 13, 2015 03:33 PM
