Dec 27, 2019, 07:22 PM
Originally Posted by Kavlingedude
Here is a screenshoot
That is the boot partition. You need to mount the root partition. Then home/pi
You will see all the code in that dir. Screenshots is in wifibroadcast-scripts
In github here is the file I THINK (if it was me attempting this) you would have to modify- https://github.com/OpenHD/Open.HD/bl...t_functions.sh
I cannot tell you what to do from here. This is not enabling some setting or turning something on. You would have to change some code to make this work the way you want.
Some things to consider-
- You are probably running openhd at 1280x720. So I dont think taking a higher resolution screenshot will give you a better picture. It will just be bigger and take more space. What resolution is the screenshot the system captures?
- You could increase the resolution of the transmitted signal but you can only go so far before your airpi, bandwidth, latency, and general performance will suffer.
The ultimate fix I think is described here-
https://github.com/OpenHD/QOpenHD/issues/52
Dec 27, 2019, 07:27 PM
Originally Posted by qczek
Hi,
Stupid question, is it possible to record video stream directly on Air Rpi (Rpi Zero) to sd card ?
Thx
Kris
It is possible and I have done it but it is experimental and not well tested. It is a feature I would really like to see. I think picamera library and using a splitter might be a good solution to this problem.
As far as recording to sdcard on the groundpi that became broken when the distributed image became read only again. If you try sdcard recording you see on your sdcard a new partition is created and video file. However no videos get recorded. This should be fixed soon as the next image should be back to read/write
Dec 27, 2019, 08:17 PM
The files you do not see on the sd-card are on a second partition with ext4 file-system
Not possible to mount with Windows
If you want to see this partition and files you can use a free programm named Linux Reader.
You can download here:
https://www.diskinternals.com/linux-reader/
Supported is read ext4, ext3, ext2, ReiserFS, HFS(+) and exFAT.
Greetings
Jochen
Dec 28, 2019, 11:13 AM
Thnx Guys.
I will start with this even if I do not have a slightest clue about Linux, programming, code et.c - but you know every journey has a starting point
Jan 01, 2020, 05:58 AM
Rana
Just tested one more camera Wide View 2.8mm Lens H.265 IPC Board 1080P Hi3516E CMOS sensor DIY CCTV IP camera module, worked perfect on OpenHD with Pi0 using external USB to LAN adapter.
IP board 1080p camera based on Hi3516E also working perfect with OpenHD (3 min 45 sec)
Jan 02, 2020, 05:09 PM
https://www.youtube.com/watch?v=1hsu-RbYTms
Thanks for sharing your results!
Jan 03, 2020, 02:31 AM
Rana
Drandulet2, You are welcomed !
Jan 03, 2020, 03:44 AM
Hi,
I designed case for rpi zero and AR9271HP WiFi card, maybe would be useful for someone
https://www.thingiverse.com/thing:4081631
Kris
Jan 03, 2020, 07:03 AM
Rana
Hi,
Kris
Very nice, thanks for sharing ! Looks like there is no space left in your inbox, I am unable to send you message
Jan 03, 2020, 12:34 PM
Hi,
Kris
Awesome! What total weight is it?
Jan 03, 2020, 01:13 PM
67 grams including antenna
Jan 06, 2020, 11:09 AM
Multiple senders
Just wonder if two openhd drones transmitting at the same time nearby would interfere each other causing receivers to receive all frames from both wifi transmitters?
Jan 12, 2020, 04:53 AM
It seems a great solution!!
You have used an adapter lan <> usb becaouse you use a pi zero, do you have tried to connect directly the camera to a raspberry with a lan port through the lan cable?
Jan 12, 2020, 06:00 AM
Rana
Yes, its working.
Jan 12, 2020, 08:30 AM
Complicating things
Karamba's Avatar
so if i have Pi3B airside i dont need usb-LAN adapter?
Latency?
Discussion Open 3D Flight Assistant discussion and creation thread racermark DIY Electronics 5 Apr 07, 2018 11:54 PM
New Product <Discussion thread>Hubsan H111C&H111D 720P HD Camera Quadcopter RTF BG Well Mini Multirotor Drones 62 Sep 06, 2016 08:59 PM
New Product Discussion thread---FQ777-124C MINI With 2.0MP HD &Switchable Controller BG Well Micro Multirotor Drones 41 Aug 11, 2016 05:51 PM
Discussion An open discussion about Model Aviation, the FAA, and the AMA dag214 Model Aircraft & Drone Advocacy 46 Dec 24, 2015 11:07 AM
New Product HeadPlay HD FPV Headset w/ 32ch 5.8GHz Receiver - Pre-Order open at GetFPV.com GetFPV FPV Equipment 41 Dec 13, 2015 03:33 PM
