MaxAmps High Capacity and High Discharge 18650 Lithium-ion Cells.
MaxAmps has released a new line of 18650 lithium ion cells. The 3450Mah cell is a high capacity option for low draw applications and the 2150Mah cell is designed for those high amp draw applications.
MaxAmps releases new high capacity and high discharge 18650 lithium-ion cells.
From MaxAmps
MaxAmps is proud to announce the newest additions to our battery lineup. The MaxAmps 2150mah and 3450mah lithium-ion cells were developed and tested to take advantage of both the highest capacity and highest discharge options in the 18650 lithium-ion cell size.
For high discharge, we have found the MaxAmps 2150mah 18650 lithium-ion cell to hold the highest voltage under a load of all the cells tested. This is the perfect option for all of those amp hungry setups. Pulling 30amps has never been easier.
SPECS:
  • Nominal Capacity: 2150mAh
  • Maximum Discharge Current: 30A
  • Positive Terminal Style: Flat Top
  • UNPROTECTED(No PCB)
  • Nominal Voltage: 3.6V
  • Minimum Voltage: 2.5V
  • Maximum Voltage: 4.2V
  • Standard Charge Current: 1.075A(0.5C)
  • Maximum Charge Current: 2.15A(1C)
3450mah 18650 Lithium-ion
On the other side of the spectrum where runtime is key the 3450mah 18650 lithium-ion cell provided more runtime than any other cell at its size. Run longer and charge less with this high capacity option only available from MaxAmps.
SPECS:
  • Nominal Capacity: 3450mAh
  • Maximum Discharge Current: 5.175A
  • Standard Charge Current: 1.725A(0.5C)
  • Maximum Charge Current: 3.45A(1C)
Custom Packs
We can also build custom packs based on your requirements using these cells. Just send us an email or give us a call for a quote.
Nov 01, 2018, 04:32 PM
Gettin' back into flyin'
MartMX's Avatar
Let the critiquing begin.... would be nice to know the weight of these.
Nov 01, 2018, 05:40 PM
Quad Erat Demonstrandum
scousethief's Avatar
Well, 18650 is the way to go I believe , will wait and see how these fair after they've been put through the wringer a few times but hopefully they perform as stated .
Nov 01, 2018, 09:41 PM
fly2bob's Avatar
If am assuming correctly, these are meant to be used for (or common use would be for) rx packs?
The high discharge cells for HV servos?
I recently bought an old school F3B glider because I've been missing flying a bigger glider, and it's all that I could afford right now. I am currently researching as to what rx pack to go with, replacing what came with it, a 5s 600mah NiCd pack, which I've got to assume is old as dirt and should be replaced. The pack is configured into a triangle at the rear (one cell on the bottom & two cells on top of it) and two cells inline in front of the triangle along the bottom.
I'm considering;
5s NiMh 2100mah range
2s 18650 Li-ion 3000mah range with BEC
others?
Bob
Nov 02, 2018, 04:36 AM
rchopper56's Avatar
They look like double A's but again weight and size?
Gene
Nov 02, 2018, 08:16 AM
18650 is the size. They are the same size as the 1100 mah A123's. 18mm dia x 65mm long nominal.
Nov 02, 2018, 03:42 PM
rchopper56's Avatar
They look .706" in diameter but not 25.590" long!
Gene
Nov 02, 2018, 04:04 PM
pull up -- PULL UP!!!
Typical high discharge 18650s measure about 18x65mm, weigh about 45g and cost about $6.
Nov 02, 2018, 08:05 PM
I am a nice guy! Really!
Originally Posted by Al M
18650 is the size. They are the same size as the 1100 mah A123's. 18mm dia x 650mm long nominal.
65.0mm long
Nov 03, 2018, 01:29 AM
fly2bob's Avatar
Gene
millimeters not inches
Nov 03, 2018, 07:30 AM
You are correct Mike. I will correct my post.
Nov 03, 2018, 08:55 AM
Why do I think they are not POSSIBLE in that size ? If really LIFEPO4 ?
Must have PAPER THIN metal strips to get that much cell area. To generate high currents. The insulators would also be paper thin also.
DO NOT EVER drop on an anything hard & reuse. I would fear a hot spot developing. Where does it say LIFEPO4 ? The voltages read like it is a LIFEPO4. Would check with the company before buying.... Would use them if the life is even only 10 years. Like A123 are.
Shelf life characteristics ?
Nov 03, 2018, 09:01 AM
Deleted
Nov 03, 2018, 10:38 AM
Some of the specs are unknown , but , The use of 18650 in more consumer devices and Tesla's involvement and need for mid-high quality batteries has helped increase the performance of 18650's. The VAST majority will of course still be your typical low performance offerings but there will be manufacturers who see the use of a more attractive hard cased version of a LiPo as the way forwards.
Nov 03, 2018, 10:46 AM
Space Coast USA
hoppy's Avatar
Spec Voltages read like a LiCoO2 cell, not LiFePO4.....
What voltages were you referring to?
Discussion Experimental Lithium Ion Battery Pack with high discharge rate dantheman213 Batteries and Chargers 11 Nov 06, 2017 01:27 PM
18650 lithium ion 2400mah cylinderical battery with 10C to 15C discharge rate ???? stevevanwagner Batteries and Chargers 5 Mar 21, 2014 11:21 AM
Discussion Custom li-ion 18650 high discharge packs or what to use instead? davercfan Batteries and Chargers 7 May 06, 2008 07:15 AM
Any new NiMH high capacity/high discharge cells on the horizon? tic Batteries and Chargers 11 Dec 17, 2005 10:25 PM
Assembly of Lithium Ion cells (18650) Frankenator Batteries and Chargers 6 Oct 09, 2004 04:11 PM
