Oct 31, 2018, 03:36 PM
guyst's Avatar
New Intersting Charges - HTRC H150, HT208, HT100, HT206
HTRC H150 DUO AC/DC 300WX2 12AX2 Dual Output Battery Balance Charger Discharger
Features:
-Full Aluminium Alloy Appearance Design,Solid & Well-made.Built-in Cooling fan for easy heat dissipation.
-2x16 LCD Disply Touch Screen, Easy Reading and Operation
-AC/DC Dual Input,AC input range:100-240V.can plug to the wall directly.
-Two Independent Output, Each Output Port Circut Power can Reach 150W, Max current 12A.High Power Circuit,High Charging Efficiency.
-Automatic identification of Li-Po batteries cells.
-Practical for variety of batteries.1-6s Lilon/LiPo/LiFe/LiHV,1-15cell Nicd/NiMh, 2-20V PB battery. Smart Battery I,II,III.
-Multi-function: Balance Charge, Discharge,storage,Terminal Voltage Control,Lithium Battery Capacity & Voltage Checking, Battery Internal Resistance Checking, Data Storage and Loading, USB DC Output 5V 2.1A,
-Users Could Set The Charging Current Limit, Capacity Limit, Temperature Threshold and Processing Time Limit Which Makes the Charger Safe to Use.
-Built-in PFC can improve the energy consumption from mainpower grid evidently,
-Support Firmware update.
Specification:
Input: AC 100-240V / DC 11-28V
Charge Circuit power: CH1+CH2=300W. (CH1 Max.150W, CH2 Max.150W)
Discharge circuit power:20W x2
Charge current range:0.1-12A x2
Discharge current range:0.1-5A x2
Current drain for balancing:500mA/cell
LiPo/LiIon/LiFe/LiHv cell count:1-6cells x2
NiCd/NiMH battery cell count:1-15cells x2
Pb battery voltage:2-20V x2
Smart Battery:I/II/III x2
Dimension:195*143*70mm
Net Weight:1.05kg
Package size: 270*210*96mm
Gross weight:1.7kg
Package Included:
1 x H150 AC/DC Duo Device
1 x AC Cord (US EU UK AU Optinal)
1 x DC Cord
2 x Charge Cable
2 x Charing Board with pin cord
Oct 31, 2018, 03:38 PM
guyst's Avatar
Htrc ht208 ac/dc 420w 20a
HTRC HT208 AC/DC 420W 20A 4.3 Inch Color LCD Touch Screen Battery Balance Charger Discharger
Overview:
1.Full Aluminium Alloy Appearance Design,Solid & Well-made.Built-in Cooling fan for easy heat dissipation. 4.3 inch Color LCD Disply Touch Screen, Easy Reading and Operation
2.AC/DC Dual Input,High Power Circuit,Max Charing Power 420W, Max Charging current 20A.
3.Practical for variety of batteries.1-8s Lilon/LiPo/LiFe/LiHV,1-20cell Nicd/NiMh, 2-24V PB battery. Smart Battery I,II,III.
4.Multi-function: Balance Charge, Discharge,Terminal Voltage Control,Lithium Battery Capacity & Voltage Checking, Battery Internal Resistance Checking, Individual Cell Voltage Calibration,Data Storage and Loading,Charging Status Graphic Photo Display, Digital DC Power Supply 5-25V ,0.1-20A, USB DC Output 5V 2.1A,
5.Users Could Set The low input voltage, Capacity Limit, Temperature Threshold and Processing Time Limit Which Makes the Charger Safe to Use.
Features:
1.4.3 " Color LCD Disply Touch Screen, easy reading and operation
2.Full Aluminium alloy Appearance Design facilitate heat dissipation,
3.Built in cool fan, Good Cooling System.
4.With rubber pads, prevent sliding and the air can circulate.
5.AC/DC Dual Input. 420W Independent output
6.Support New LIHV High Power Battery and Smart battery.
7.Automatic identification of Li-Po batteries cells.
8.Battery management check battery capacity and voltage balancer. 8 Memories Data
9.Soft switching is also introduced can reduce radiation interference
10.Built-in PFC can improve the energy consumption from mainpower grid evidently
11.Support USB DC Output 5v/ 2.1A
12.Support for firmware upgrades
Specification:
Input AC 100-240V / DC 10-30V
Charge power: 420W
Discharge power:25W
Charge current range:0.1-20A
Digital DC Power:5-25V, 0.1-20A
Lilon/LiPo/LiFe/LiHV cell count :1-8cells
NiMH/NiCd: 1-20cells
Current drain for balancing: 500mA/cell
PB: 2-24V
Smart Battery: I/II/III
Dimension: 15.6*14.3*7cm
Net Weight:1.008kg
Gross Weight:1.52kg
Packaging Included:
1 X HT208 Charger
1 X DC Cord
1 X Charge Cable
1 X Charging board with pin cord
1 X AC Cord
Oct 31, 2018, 03:41 PM
guyst's Avatar
Htrc ht100 ac/dc 100w 10a
HTRC HT100 AC/DC 100W 10A 3.2 Inch Color LCD Touch Screen Battery Balance Charger Discharger
HTRC HT100 AC DC is a new design Color LCD Touch Screen RC Charger with full plastic case and new operating system develpoed by HuiTuo. AC /DC Dual Input, Small size, light weight, easy to carry and easy to use.
Description:
1.Full Plastic Shell,Light and handy,Solid and Well-Made,Built in Cooling Fan for Easy Heat Dissipation,3.2 inch Color LCD Display Touch Screen,Easy reading and operation.
2.AC/DC Dual Input,High Power Circuit,Max Charing Power 100W, Max Charging current 10A.
3.Practical for variety of batteries charging: 1-6s Lilon/LiPo/LiFe/LiHV,1-15cell Nicd/NiMh, 2-20V PB battery. Smart Battery I,II,III.
4.Multi-Function:Balance charge, discharge,Terminal Voltage Control,Lithium Battery capacity & voltage checking,Battery Internal Resistance checking, individual cell voltage calibration,Data storage and loading,Charging status graphic photo display, Digital DC Power supply.
5.Users could set the Charging Current Limit, Capacity Limit, Temperature Threshold and Processing Time Limit which makes the charger safe to use.
Features:
-3.2 inich Color LCD Touch screen.
-Full plastic shell, light and convenient.
-Built in cool fan
-Setting: Buzzer volume, balance speed, Max charging power,
-Security setting : Low Input voltage,Max Capacity, Safety time, Temprature cut-off.
-High power circuit,supports LiHV Charging.
-Supports DJI Smart Battery Charging (Need optional DJI Charging cable)
-Automatic identification of Li-Po batteries cells counts
-Battery Capacity & Voltage Checking,
-Battery Internal Resistance Checking.
-Battery Balance
-Individual cell voltage calibration
-(TVC)Terminal Voltage Control.User is able to adjust the end charge voltage per cell,
and set a voltage which is kinder to the batteries as his will.
-Digital DC Power:5-25V.0.1-10A
-Data storage and loading.6 Memories Data
-Graphic photo display of charging stauts.
-Lipo/Lilo/LiFe/LiHv 4 models : balance charge, charge, storage, discharge.
-NiMH/NiCd 3 models: Charge, Discharge, Cycle.
-PB 3 models: Charge, Discharge,Trickle.
-Smart battery 4 model:Smart battery I,II,III,and user set.
-Support firmware upgrade.
Specification:
Input:AC 110-240 / DC 11-18V
Charge Power:100W
Discharge Power:10W
Charge Current:0.1-10A
Discharge Current:0.1-2A
Current Drain of Balancing:350mA/Cell
Data Power:5-25V.0.1-10A
Lipo/LiIon/Life/LiHV:1-6Cell
NiMH,NiCD:1-15Cells
PB Battery:2-20V
Dimension: 12.2x12.9x5.3cm
Net Weight:0.3kg
Package Included:
1 x HT100 Main unit.
1 x DC Cord
1 x Charing Cable
1 x Charging Board
1 x User's Manual
Oct 31, 2018, 03:43 PM
guyst's Avatar
Htrc ht206 duo ac/dc 2x200w 2x20a
HTRC HT206 DUO AC/DC 2X200W 2X20A 4.3 Inch LCD Touch Screen Dual Battery Balance Charger Discharger
Description:
1. The HT206 Duo is a dual-channel charger with two independent outputs that can charge two different types of batteries at the same time.
2.Full design of aluminum alloy, solid & well-made.built-in fan for easy heat dissipation. 4.3 inches Color LCD Disply Touch Screen, Easy Reading and Control
Dual AC / DC Input, two independent outputs that can charge two different types of batteries at the same time. Each output port of circut power can reach 200 watts, high power circuit, high charging efficiency.
3.It is practical for various models of batteries.1-6S lilon / lipo / life / lihv, 1-15cell NiCd / NiMH, 2-20V Pb battery. Smart Battery I, II, III.
4. Multi-function: balance charging, discharge, terminal voltage control, lithium battery capacity and voltage check, internal resistance check, individual cells calibration, data storage and loading, charging status graphic display, digital dc power supply 5-27 V, 0.1 -20a, USB DC Output 5 V 2.1a, Using the RS can set the current charging limit, capacity limitation, temperature threshold and processing time, which makes the charger safe to use.
Features:
1.AC/DC Dual Input.
2.4.3" Color LCD touch screen display for easy operation and convenient to use.
3.Full Aluminium beautiful Appearance Design, Built in cool fan, Good Cooling System.
5.Two independent Port which can charge two different kinds of batteries simultaneously.
each port max charging power up to 200W, max charging current up to 20A.
6.Automatic identification of Li-Po batteries cells.
7.Support LIHV High Power Battery and Smart Battery.
8.Battery management check battery capacity, voltage and balancer.
9.Memory function save up to 8 operation data.
10.5V 2.1A USB DC power supply output.
11.Built-in PFC can improve the energy consumption from mainpower grid evidently,
12.Soft switching is also introduced can reduce radiation interference
13.Support Firmware update.
Specifications:
Input Voltage:AC110-240V/DC10-30V
Charger Circuit Power:200W*2
Discharger Circuit:25W*2
Charger current range:0.1-20A*2
Discharge Current Range: 0.1-5A*2
Digital DC power:5-27V ,0.1-20A
Lilon/LiPo/LiFe/LiHV:1-6cell*2
Nicd/NiMh:1-15cell*2
Current Drian for Balancing Port:500mA/cell
PB: 2-20V*2
Smart battery: I/II/III*2
Charger plug: EU, US, UK plug optional (send plug according to buyer's location)
Demension:L19.5*W14.3*H7cm
Net Weight:1.072Kg
Screen Display:
1.Setting: general settings such as Buzzer volume, Low input voltage, balance speed, Max charging power. Besides,user can set some cut off value according to your requirments for each channel, makeing sure a safety charging .
2.Memory: save up to 8 operation data.
3.Monitor: checking battey capacity ,voltage, Internal Resistance, balancer.
4.Calibration: calibrate battery cell voltage.
Working interface:
The working interface shows all setting data of charging.
and the charge current and voltage will be displayed by graphic photo.
Different battery has different model:
In Lipo/Lilo/LiFe/LiHv charging interface , there are 4 model : storage, charge, bal-charge, discharge.
In NiMH/NiCd charging interface, there are 3 model: Cycle charge discharge
In PB charging interface , there are 3 model : trickle charger discharge.
In smart battery charging interface, there are 4 model: Smart battery I, II, III , and digital power.
Digital DC power supply voltage range : 5-27V, current range,0.1-20A.
Packaging Included:
1 x HT206 AC / DC Duo RC Balance Charger
1 x Power Cable (EU Plug)
1 x DC Cord
2 x Charging cable
2 x Glob board with pin cord
1 x User Manual
Oct 31, 2018, 03:45 PM
guyst's Avatar
Htrc ht206 tri ac/dc 3x200w 3x20a
HTRC HT206 TRI AC/DC 3X200W 3X20A 4.3 Inch LCD Touch Screen Battery Balance Charger Discharger
Description:
Features:
-AC/DC Dual Input.
-4.3" Color LCD touch screen display for easy operation and convenient to use.
-Full Aluminium beautiful Appearance Design, Built in cool fan, Good Cooling System.
-With rubber pads, prevent sliding and the air can circulate.
-3 independent Port which can charge 3 different kinds of batteries simultaneously.
-Support LIHV High Power Battery and Smart Battery.
-Battery management check battery capacity, voltage and balancer.
-Memory function save up to 8 operation data.
-5V 2.1A USB DC power supply output.
-Soft switching is also introduced can reduce radiation interference
-Support firmware upgrades
Specifications:
Input Voltage:AC100-240V/DC10-30V
Charger Circuit Power:200W*3
Discharger Circuit Power:25W*3
Charger current range:0.1-20A*3
Discharge Current Range: 0.1-5A*3
Lilon/LiPo/LiFe/LiHV:1-6cell*3
Nicd/NiMh:1-15cell*3
PB: 2-20V*3
Smart battery: I/II/III*3
Demension:L27.35*W14.3*H7cm
Net Weight:1.12Kg
Gross Weight:2.38kg
Tips: Built-in AC high power charger naturally run hot,although with built-in fan, you need pay attention to the temperature,if prolonged use,especially in discharge modle,the internal AC adapter in a risk of damage.
if serious heat, it is better to place an external fan for heat radiating to prevent from damage. or use DC input to avoid problem.
Package Included:
1 x HT206 TRI Charger
1 x DC Cord
3 x Charging cable
3 x Charging Board with pin cord
1 x AC Cord (EU Plug)
Jun 02, 2020, 07:59 AM
What would lonelasso do?
jfv61's Avatar
Reviving this old thread. Anyone have experience with these HTRC chargers? I'm looking for a more robust alternative to the new small plastic designs, hopefully without spending a fortune.
OK, found this. https://www.rcgroups.com/forums/show...-DUO-Stay-away
Jun 05, 2020, 09:19 PM
doug14's Avatar
I just bought one of these.
seems good so far .
New Product HTRC HT206 DUO AC/DC 2X200W 2X20A 4.3 Inch LCD Touch Screen Dual Battery Charger Merch Banggood.com 0 Oct 30, 2018 03:05 AM
New Product HTRC HT208 AC/DC 420W 20A 4.3 Inch Color LCD Touch Screen Battery Balance Charger Merch Banggood.com 0 Oct 30, 2018 02:57 AM
New Product HTRC H150 DUO AC/DC 300WX2 12AX2 Dual Output Battery Balance Charger Discharger Merch Banggood.com 0 Oct 30, 2018 02:50 AM
Discussion Intersting new LiFe 6.6V, 15g, battery kcaldwel DLG Hand Launch Gliders & F3K 68 Aug 15, 2011 12:19 AM
