Hi all,
I have my gps connected to tx1 and rx1 and my buzzer connected to buzzer and sbus connected to sbus. Can I connect my video tx smart audio any where on this board to control. Thanks. |
I think that V of the GVIO is intended to supply 5V to the camera. If you attached battery power to that pad and the link was set to 5V, then battery power would be at all 5V pads. Possibly damage the 5V buck converter too, not sure. The battery voltage input should connect only at the esc connector.
F4 NOXE - HAKRC 15 A ESC Problem (solved)
Hello,
Thanks for your help, i have tried all - replacing motors - fresh setup with "legacy" firmware, using the snippet - nothing really helps. I have set now "Motor Timing" to "High" ( 1103-7500 KV Amaxinno) - and now the 48 KHZ version is flyable for me First time i changed a parameter in BLHELI firmware |
How have you activated softserial? What settings have you used?
Thread Tools | |
Similar Threads | |||||
New Product | Micro 20x20mm Betaflight STM32F4 F4 FC + OSD built-in | nitbeat | Multirotor Drone Electronics | 269 | Sep 10, 2021 01:41 PM |
Help! | Anybody here build a Bristol Boxkite? | Fly Wheel | Scale Kit/Scratch Built | 1 | Jan 08, 2016 02:03 PM |
anybody here fly at the beach flying sight in carlsbad? | mr.zagi5c | Slope Soaring | 19 | Jun 25, 2004 11:38 PM | |
Anybody flying coroplast or"SPAD" planes here? | slowflyer | Electric Plane Talk | 12 | Sep 06, 2001 03:36 PM |
