Build Log
Mick Reeves Spitfire Mk.IX, 1/6 Scale
I‘ve got a delivery today from UK: Mick Reeves’ Spitfire Mk.XI in 1/6 scale. It’s a pretty complete kit, featuring an epoxy fuselage, a wing kit that’ll be sheeted using Mick’s Proskin material, mechanical retracts, scale cockpit and lots of vacuum formed pieces.
Unfortunately I won’t be able to start the build before mid November, so this is just a little teaser... I have a build thread over at RCSB, too. In case anyone’s interested: https://www.rcscalebuilder.com/forum...TID=28794&PN=1 |
Reason: Added RCSB link
Ouch!, ....... just looked up the price, but then you usually have to pay for quality.
That's why I prefer to scratch build
But then any Spitfire is worth money and time just to fly them. . |
I just couldn’t resist: I had to take another look at the kit. So I started by checking if all the laser cut pieces were there - all present and accounted for.
Then, by old tradition of mine, I started building the tail feathers. I began with the rudder. It’s pretty straightforward to build. All ribs are just slid onto the frame, add the post, a little laser cut sheet for the leading edge and you’re done. Nice! ImagesView all Images in thread
I still have a kit in a box so I am following you build.
Very Nice. The Spitfire is my favorite warbird. Will be following.
That pilot is outstanding. Then again, I suppose if he's 1/6 scale, that makes him the size of a GI Joe (the original ones from the '60s, not the newer tiny ones), so there's lots of room for authentic detail. He sure looks the part.
Good luck with the build; I'll be following! Steve |
The pilot is a figure purchased from a 1/6 scale shop, so the body is very articulated but also very heavy. For my Fokker D.VII I used a similar pilot and replaced the body with a light foam pieces held together with elastic bands. I kept only the head and the hands from the original pilot.
I started building the elevator stab. Generally it’s very nice laser cut balsa, easy to assemble without plans. There’s one detail though that’s a bit tricky: rib 1 isn’t prepared for the two joiner pieces that connect the stab halves. You need to cut out the front slot and cut off the tails a little to make room. On the main stab frame you need to cut a bit off the rear notch, too.
Add the trailing edge pieces first before starting to add the ribs for a stiffer frame. When gluing the ribs make sure everything is true. I used wood blocks (like Jenga pieces). ImagesView all Images in thread
All major RC components arrived today - motor, controller, servos, RX.
Motor: Dualsky XM6350EA-12 Controller: Hacker Master Spin 80 Pro Servos: 6x Hitec D85MG Retract servos: 2x Hitec HS-75BB RX: Spektrum AR9030T To test the servos i programmed a basic setup on the TX including a nice sequence for the two retract servos. Works like a charm. Couldn’t test the motor/controller combo since I had no time to solder the connectors. |
Thread Tools | |
Similar Threads | |||||
Discussion | Mick Reeves Hawker Hurricane 1/6 scale Kit | -Exlex- | Fuel Warbirds | 9 | Apr 09, 2021 08:58 AM |
Discussion | mod to a mick reeve 1/4 spitfire | wager | Giant Scale Airplanes | 1 | May 05, 2017 04:06 AM |
Help! | Mick Reeves 63" Spitfire (Sport Scale) | chilipecker | Fuel Warbirds | 6 | May 26, 2012 11:35 AM |
Question | Mick Reeves' 1/4 scale Spitfire question | Boo | Fuel Warbirds | 9 | Mar 04, 2010 11:47 PM |
Best Retracts for Mick Reeves Sport Scale Spitfire | brobin1 | Scale Fuel Planes | 13 | Dec 11, 2003 06:31 AM |
