Oct 19, 2018, 07:00 PM
Help!
Motor rev
Hi all
Wondering if someone can help please?
Iíve only just moved from fuel engines to electric motors and have run into a snag.
Have a DX18 and need to reverse the direction of a motor.
Firstly, do I reverse the polarity on the motor through the pos/neg wires or reverse the motor in servo direction in the trans..?
When I tried the reverse in the transmitter, it asked me to Re-bind the receiver in low throttle position.... question is, the transmitter will not allow me to change the throw in the motor with out resetting the bind in closed position... does this mean I have to bind in full open to then swap the throw to have a closed position in the reversed motor throw..???
Would really appreciate some advise if possible as do not want to fry anything by swapping wires and not sure how to proceed with trans.
Cheers
Tony
Oct 19, 2018, 08:01 PM
ooooh yeah
Frenche's Avatar
So the throttle was working fine, but the motor is spinning backwards?
Easy fix, put your transmitter back the way it was. If it's a brushless motor, swap any 2 of the 3 wires from the esc to the motor
Oct 19, 2018, 09:45 PM
Hi
Yes the transmitter was working fine the motor was just running backwards
Wow... that easy hey..!!!
Will do that now.
Many thanks
Oct 20, 2018, 01:37 AM
scirocco's Avatar
Your problem is solved, but a critical point to note. Never ever reverse the polarity of the battery to ESC connections. You'll fry the ESC pretty much instantly
Oct 20, 2018, 06:48 AM
Hey
Worked a treat... thank you
Cheers
Help! 2 motors rev up at low throttle - CC3D nlightnme Beginner Multirotor Drones 14 Jan 16, 2019 09:50 AM
Discussion motor revs on power connection baldy40 Power Systems 10 Nov 17, 2015 09:40 AM
Help! Motor problem, won't rev up -- F4U Corsair Parkzone njsnel Power Systems 8 Oct 25, 2015 06:59 PM
