Video
Jumper T12 Plus Review
► Jumper T12: http://bit.ly/T12-HC || https://amzn.to/2EwIn8x
► 10% Off coupon: KremerFPV10off ► JumperTX Firmware: https://www.jumper.xyz/jumpertx
Description: Radio Features: Open source multi-protocol firmware, Based on OpenTX JR/FrSKY compatible module bay on rear side (module not included) USB online firmware upgrade Ultra-low power consumption, longer battery life Channels: up to 16 channel output Open Source Firmware, all channels are fully programmable Wide voltage input (2s lipo recommended) Multilingual menu Vibration reminder function Support telemetry (depending on the receiver) Crossfire CSRF Compatible: Yes LUA Script support: Yes Radio Specs: Radio MCU: STM32F205VET6 (512kb) Size: 158 * 150 * 58 Weight: 342g (without battery) Working voltage: DC5-DC9V (factory with 4 * AA battery box, 2s Lipo recommended, batteries not included) Firmware: OpenTX Channels: up to 16 channel output Display: 1.7-inch LCD display, 128* 64 resolution Gimbal Type: Potentiometer JR/FrSKY compatible module bay on rear side Upgrade method: USB online upgrade Simulator mode: 3.5mm standard ppm output or USB HID Voice support: YES JP4-in-1 Specifications: Working voltage: 6-9v Working current: -=100ma Operating frequency: 2.4G ISM band RF power: +22DBM Main control chip: STM32F103CBT6 (128K ROM, 20K RAM) Module bay compatibility: FRSky, Jr and other dimensions: 64*49*33 (without antenna) Net Weight: 42g (including antenna) Software Compatibility: Suitable for radios using OpenTX or er9x/ersky9x Firmware updatable: Yes, via USB. Package options: T12 Jumper Transmitter w/ 4in1 module T12 Jumper Transmitter w/o module T12 Jumper Transmitter w/ Hall Effect Gimbal (Black) w/ 4in1 module T12 Jumper Transmitter w/ Hall Effect Gimbal (Black) w/o module |
I have a fleet of Eachines E013 (Small Pepper) quads and considering a better radio transmitter (remote controller), however, I need to know if this transmitter will work by someone who has actually tested it on the model. No one seems to know and I have had trouble even finding out what protocol the E013 uses. If it works, I would like set up instructions. (( Answers like "it should work" or "it might work")) are not sufficient. I need to know for sure before buying a transmitter. Although some suggest that the E010 and E013 use the same protocols, my E010 transmitter will Not bind nor control my E013s, nor will the E013 transmitter bind nor control the E010s.
Does anyone out there know if the Jumper T12 will work with the Furibee F36 (and Helifar F36) quads? If so, what protocol and how do you program it? What I know for sure is that it is NOT Bayang, Eachine E013, Eachine E010, nor JJRC H36. I have all of those controllers and it does not work with them. It only works with the native F36 transmitter. Thanks.
Edit: Please see related post here.
Reason: Reposted original post in another thread
| Similar Threads | |||||
| Category | Thread | Thread Starter | Forum | Replies | Last Post |
| Discussion | Jumper T12 Open Source 16ch Radio with JP4-in-1 Multi-protocol RF Module | Hobby Porter | Radios | 844 | May 10, 2023 11:07 AM |
| Discussion | Jumper T12 OpenTX 16CH Radio Transmitter for Frsky JR Flysky -- Free Reviewing | BGKevin | Radios | 625 | Jan 03, 2023 03:38 AM |
