H-King Sky Shadow S800 FPV Flying Wing 820mm (32.3")
Ohhh yeah! Another FPV wing from the fine folks at Hobbyking!! Designed for extreme FPV flying, the H-King Sky Shadow S800 is constructed from almost indestructible EPP foam. Six carbon fiber spars also provide strength and rigidity for excellent performance.
The H-King Sky Shadow S800
The H-King Sky Shadow S800 is built for extreme FPV flying. The plane is constructed from almost indestructible grey EPP foam with six carbon fiber spars to provide strength and rigidity for excellent performance.
The aerodynamic wing gives stable flight throughout the entire flight envelope, from low speed passes to high-speed turns. The model has been well thought-out with ample room in the nose for an FPV camera and action cam, behind the camera is a large covered hatch for your battery and avionics allowing them to be neatly tucked away. In addition, there is also a compartment in each wing for the video transmitter and radio receiver.
The PNP H-King Sky Shadow S800 comes packaged with a 2205-2300KV brushless motor, 30A ESC, 9g servos, 6045 propellers, 5.8GHz 200W VTx and 700TVL FPV camera. All you need is your favorite radio system and a battery to get in the air.
Features:
  • High quality, lightweight EPP foam construction
  • Aerodynamic design for high speed, low wind resistance, stable flight
  • Comes with 3-Axis flight control to ensure a more stable flight
  • New design 5V/3A and 9V/3A Dual output powerboard for clean power for your video camera
  • 2205-2300KV motor and 30A ESC
  • 700TVL FPV camera for clear images
  • 200mW VTx for real-time video transmission
  • Fun to fly
Specs
  • Material: EPP
  • Wingspan: 820mm
  • Overall Length: 405mm
  • Weight: 170g (without electronics)
  • Flight Controller: 3-Axis flight controller
  • Camera: 700TVL
  • Image Transmission: 200mW with antenna
  • Servo: Emax ES08A 9g x 2
  • Motor: Sunnysky 2205-2300KV CCW
  • ESC:30A ESC
  • Propeller: 6045
Photos
Learn More
Head over to Hobbyking to learn more!
Oct 17, 2018, 07:20 PM
USA: LakeGeorge, New York
Is this rebranded?...or a HK made FPV plane?
Latest blog entry: My FAVORITE FPV CockPits'!!!!
Oct 18, 2018, 07:34 AM
Landing is not optional
JamesonC's Avatar
It seems like they are releasing new wings every other week. How about some more actual planes?
Oct 18, 2018, 07:42 AM
They're doing that too: new EFX Racer, Bonanza, etc..
Wings have their place. I've been getting into them more. Mostly because they're cheap.
Which does not apply to this one though btw.... (insert finger-waving icon...) For a third rendition of the Reptile S800 I think it should be cheaper. Or are there improvements I'm not aware of? I got my Eachine Fury from BG EU for under €80 shipped, and could (and may..) do the same with the Sonicmodell F1 PNP... - both of which are higher performance wings too..
Oct 18, 2018, 10:52 AM
Quad Erat Demonstrandum
scousethief's Avatar
An extra 14+shipping just to use a different set of stickers ? this is just the V2 according to the spec sheet it even has the same FC/PDB that outputs 9v instead of 12v
Oct 18, 2018, 08:45 PM
This Wing is not new the sky shadow has been out for over a year.
Oct 19, 2018, 08:04 PM
Gregco10's Avatar
Deleted post
Nov 02, 2018, 10:00 AM
Here's the link to the original thread:
https://www.rcgroups.com/forums/show...ng-RC-Airplane
Discussion Reptile S800 SKY SHADOW 820mm Wingspan FPV EPP Flying Wing Racer KIT or EPP kbird Flying Wings 1503 Jan 16, 2019 04:47 PM
New Product [New Arrival]Reptile S800 V2 SKY SHADOW 820mm Wingspan FPV Flying Wing RC Airplane BG Tobey FPV Aircraft 627 Jan 10, 2019 09:50 AM
New Product Reptile S800 V2 SKY SHADOW 820mm Wingspan Gray FPV EPP Flying Wing Racer PNP With FPV D Gains FPV Aircraft 1 Aug 10, 2017 10:31 AM
