Oct 16, 2018, 05:33 AM
Quad Erat Demonstrandum
scousethief's Avatar
New Product
RunCam Split 2S FOV 170 Degree Super WDR Mini FPV Camera 1080P 60fps DVR HD Recording
https://www.banggood.com/RunCam-Split-2S-FOV-170-Degree-Super-WDR-Mini-FPV-Camera-1080P-60fps-DVR-HD-Recording-OSD-for-RC-Drone-p-1365856.html
Description:
Brand Name: RunCam
Item Name: Split 2S
Version: With WiFi module, Without WiFi module (optional)
Specifications:
Field of View(FOV) FPV FOV 4:[email protected], 16:[email protected]/HD Recording 170
Lens Thread Size M12*0.5
Video Resolution [email protected]/[email protected] /[email protected]/[email protected]
Video File Format MOV
Image Resolution 2 Megapixels
TV Mode NTSC (720*480)/PAL (720*576) Switchable
Interface Micro USB / UART
Max Micro SD Card Supported 64G(need Class 6 or above, recommend Class 10/UHS-I/UHS-II/UHS-III)
WiFi Module Support (Removable)
Dimensions PCB 38*38mm/Lens Module 19*19mm
Power Input DC 5-15V / DC 5V(USB)
Working Current 650mA @5V / 270mA @12V
Net Weight 19g
Features:
- [email protected] HD recording & WDR 16:9 / 4:3 FPV camera
- [email protected] M4 holes, Standard size for a better experience
- Removable WiFi module for APP
English Manual, Click Here
Package Included:
1x Camera
1x SD Card Protector
1x ABS Bracket
1x 3pin FPV Silicone Cable(male)
1x 3Pin Silicone Cable (female)
1x Set of Screws
1x Manual
Oct 24, 2018, 11:29 AM
What exactly are the differences to the Split 2?
Oct 27, 2018, 06:06 PM
Very good question.
I'm currently in gear acquisition mode for a new build and am trying to work out if it's just a different form factor from the Runcam Split 2 or if there are other important changes.
Oct 27, 2018, 11:25 PM
dirkzelf's Avatar
RunCam:
"It can switch between 4:3 and 16:9 for FPV.
The camera part is designed with a micro size. But you can mount with a bracket we provided to make it a standard size. Thus it can compatble with either your micro size quad of standard size.
Above are the main difference."
I've also been given to understand that the files are COMPLETELY saved when power is cut from USB.
The lens has F1.9 aperture.
It can start recording automatically at bootup in the desired setting and resolution.
That's what I know so far.....
Oct 29, 2018, 12:07 PM
Would love it to do [email protected] and [email protected] would even like [email protected] , that would be pretty cool.
Nov 04, 2018, 02:36 AM
did they keep the same lens (gopro) that is on the Split2?
Nov 14, 2018, 09:56 PM
FPV Ground Pounder
Gramps50's Avatar
I was wondering that too but haven't see the lens mentioned anywhere
Nov 22, 2018, 05:37 AM
anyone tested?
i was planning to buy one and use it as HD cam.
I'm not yet good enough to fly with an expensive gopro (plus the session is no longer in production).
my concerns are:
1- latency...most of the review are saying latency is quite bad. Hence i was planning to use normal Foxeer as FPV cam and install the Split2s in the space where you normally mount your HD camera.
2- how do you prevent vibration/jello on such camera?
Nov 23, 2018, 12:18 AM
HD recording is OK, but FPV is not good, latency, noise.. I have to add another FPV cam
Dec 07, 2018, 04:15 AM
HeliWobbles's Avatar
I cannot see any way of getting audio out to the VTX.
Can anyone pick up on something I have missed?
Thanks.
Ted.
Jan 08, 2019, 05:54 AM
are we expecting a new version?
it looks to me this new 2S is not going very well and very little information shared about it.
New Product RunCam Split Mini 2 FOV 130 Degree 1080P/60fps HD Recording & WDR FPV Camera NTSC/PAL Merch Banggood.com 0 Aug 29, 2018 01:53 AM
Discussion Caddx Turtles FOV 145 Degree Super WDR Mini FPV Camera 1080P 60fps DVR - Micro HD! BobFromMars Banggood.com 0 Jul 05, 2018 09:05 AM
Discussion RunCam Split, 1080p/60fps HD recording and WDR FPV Cam RunCam FPV Talk 50 Jan 31, 2018 04:01 AM
Discussion RunCam Split 2 FOV 130 Degree 1080P/60fps HD Recording BobFromMars Banggood.com 0 Oct 13, 2017 11:27 PM
