Dec 02, 2019, 09:54 PM
Team Futaba
Neilbo4's Avatar
Incoming Container Remaining Inventory
I have (2) Mythos 50E's in the White/Blue scheme and (1) Wind S 50E in the White/Blue scheme left on the incoming container (ETA December 20). Reach out ASAP to reserve your next pattern airplane!
Neil
www.sebartusa.com
[email protected]
443-961-7050
Dec 03, 2019, 01:12 AM
Hello Neil,
I have 120 flights on my Prometheus 2 meter mono now, mostly happy except for the spin. I started CG at the front of wing tube, then lighter batteries got me to center of wing tube, now I have switched from 5000mah 5 cell batteries (2) to now 4500mah Gator RC packs. CG now just behind wing tube but still the spin isn't good. The spin either travels around an imaginary cylinder or straight down rolling depending on throws. Ideas?
Dec 03, 2019, 01:22 AM
Just for more information, plane weight is 10lb 12oz. I couple Aileron, Elevator and Rudder to a condition switch for spin and a similar but separate switch for snaps. I have tried many combinations, my snaps are good but spins are not. I can give throw angles if you like but I've tried so many I only have the latest attempt.
Dec 03, 2019, 09:27 AM
Team Futaba
Neilbo4's Avatar
Originally Posted by C Brown
Hello Neil,
Spin presentation is highly dependent on end user (pilot) execution, throws, and CG. Post your throws (in degrees)... depending on what you come back with, I would suggest you start moving your CG forward in small increments.
Neil
Dec 04, 2019, 01:10 AM
Hello Neil,
Normal throws for my Prometheus 2m mono: Ail-10 degrees, Elev-12 degrees, Rud-11 degree
Snap throw: Ail-15 degrees, Elev-20 degrees, Rud-20 degrees.
Spin throw: Ail-13 degrees, Elev-11 degrees, Rud-19 degrees.
All throws are from neutral. User style Spin: bring model to a stop nose up 10 degrees approx. then as the nose drops go to max spin settings so as to avoid dropping wing early. Snap style: I pull in a curve instead of going diagonal to corner, I start favoring up elevator to get the break and curve into max aileron+elevator as per snap settings. My snap comes down to user style but the spin never looks stalled as it falls, it's flying as it drops. I have tried many combinations in the 120 flights so far to spin, using just rudder and elevator, and combinations of all three controls and I flew 12oz. more nose heavy for much of that time. Recently went to Falcon carbon vented spinner, Falcon V2 extra light carbon prop and carbon landing gear and wheel pants from F3A Unlimited for "Proteus", the sweep was to much so I tipped the mounting plate by 1/8" over the mounting plates 1.5" width. Gear is still swept 3/4" more than stock but no issue. I can move CG forward again if you think I'm going the wrong way.
Dec 04, 2019, 09:24 AM
Team Futaba
Neilbo4's Avatar
Hello Neil,
Your snap and spin degrees look a little low to me...
If this were my airplane, I would have my rates more like:
Ail: 25 - 28 degrees
Elev: 15 degrees
Rud: 18 - 20 degrees
Most times I will spin the airplane using the same rates as my snap rates, again personal preference. I would try increasing your aileron and rudder rates. Increase both surfaces by 2-3 degrees at a clip and fly it each time. If you don't want to take your throw meter with you to the field and do lots of takeoffs and landings - pull up your dual rate screen while you are flying. Add a little bit to both, do a spin and evaluate.
Neil
Dec 04, 2019, 11:09 AM
Thank you Neil, may not have been the right thread to discuss set-up and flying of my SebArt Prometheus 2m but I knew you were active here. Thanks again, C Brown
Dec 12, 2019, 10:22 AM
Team Futaba
Neilbo4's Avatar
Container has arrived! Pre-orders will begin shipping tomorrow. Online store has been updated to reflect what is left.
Reach out with any questions - First come first serve!
Neil
www.sebartusa.com
[email protected]
443-961-7050
Dec 14, 2019, 10:05 PM
Team Futaba
Neilbo4's Avatar
New Bipe - 2M Zeus
New F3A offering - the 2M Zeus!
Additional specs to come as the details get finalized. Hope to have them available for sale this Spring (April 2020).
Enjoy the pictures and reach out with any questions/to be added to the preorder list.
Neil
www.sebartusa.com
[email protected]
443-961-7050
Dec 15, 2019, 07:15 AM
The big question, how much!
Dec 15, 2019, 11:41 AM
Team Futaba
Neilbo4's Avatar
Pending tariffs, $2,699 plus shipping.
Dec 21, 2019, 09:07 AM
Team Futaba
Neilbo4's Avatar
Last Minute Sale!
Last Minute Sale!
All remaining 90mm jets are 7% off + Free Shipping!
Enter XMAS7 at checkout (valid through 12/24/19)
Neil
www.sebartusa.com
[email protected]
443-961-7050
Jan 06, 2020, 01:38 PM
Team Futaba
Neilbo4's Avatar
I have (1) Mythos 50E in the White/Blue scheme left - reach out for a special price . First come first serve!
Neil
www.sebartusa.com
[email protected]
443-961-7050
Jan 18, 2020, 11:30 AM
Team Futaba
Neilbo4's Avatar
Next container will be arriving the end of April. Reach out to reserve your next Seb Art airframe!
Neil
www.sebartusa.com
[email protected]
443-961-7050
Jan 18, 2020, 10:31 PM
flydynamics's Avatar
Email sent, still looking for this older one
Discussion Seb-Art Angel 30e - mods ? xenon20 Electric Plane Talk 0 Mar 15, 2017 06:53 PM
Discussion Seb Art Angel 30e mikbul F3A Pattern 7 Oct 13, 2016 03:27 PM
Discussion Sukhoi 29S 140e Seb Art G.Hanssmann 3D Flying 33 Feb 21, 2010 11:49 AM
Build Log Seb Art Angel 50/ 5S/ Neu 1910/ HS-225MG turbine50 Sport Planes 173 May 18, 2009 10:37 AM
Discussion New Seb ARt Katana always flying 3D Flying 2 Oct 14, 2006 12:46 PM
