Dromida Sync 251 FPV Camera Drone
The Dromida Sync 251 is a ready to fly FPV drone that can capture HD video and photos. It uses Optical Flow technology along with the stabilizing flight board to hold its position in the air without the need for GPS.
Capture HD Aerial Videos and Photos Inside or Outdoors
The Dromida Sync 251 is a ready to fly FPV drone that can capture HD video and photos. It uses Optical Flow technology along with the stabilizing flight board to hold its position in the air without the need for GPS. It also features Altitude Hold which allows it to hold its height above the ground. All that makes it easy to fly for newer pilots and lets you focus more on capturing content. When flying just for fun, you can perform flips with the auto-flip button and there is also a take off or land button that automates the take off or landing for you.
The transmitter that comes with the Sync has buttons to take photos or videos while flying and features a detachable mobile phone holder. Using your phone, you can connect to the Sync via an app and see the video feed from the drone while flying. The Dromida Sync 251 is only available in stores currently, so be sure to check with your local hobby suppliers for availability. Pricing puts the camera version at $139.99. There's also a non camera version for $79.99.
Check out the Dromida Sync 251 FPV Camera Drone Here
Key Features:
  • Optical Flow Technology
  • Low-Latency 5G Wi-Fi Camera
  • 1080p Camera definition
  • SAFEŽ Technology
  • Altitude Hold functionality
  • Auto take-off and landing ability
  • Headless Mode
  • Integrated LEDs
Transmitter Features:
  • LED indicators for transmitter battery power status, binding progress, low/high rates on or off, optics on or off.
  • Signal loss warning (audible beep).
  • Auto-flip function (press and release top right button; move right stick in the direction desired to flip).
  • Picture button (press once to take a static photo)
  • Video button (press for one second to start/stop video)
  • Optical Flow on/off (default setting is ON)
  • Headless Mode on/off (default setting is OFF)
  • Auto start/stop, take off, and land (by pressing top right button)
  • Aileron and elevator control and trims
  • Detachable mobile phone holder
Nov 06, 2018, 05:01 AM
Is there a possibility that there will be a BNF version of this Quad ?
Nov 14, 2018, 06:02 AM
I'm curious as to the range.
Dec 15, 2018, 02:20 PM
Only one issue for me at the moment.
I bought one of these a few days ago and couldn't fly due to rainy weather. Finally get to fly and I can't seem to find the network to connect it to my phone. Given, my phone is "slightly" outdated (Galaxy Note 3). However, my friend has the Note 9...he still can't find the network. Due to it being a Saturday, customer service is closed. I'll have to wait until Monday to call. I'll update on range, video, etc...once I'm able to connect. Other than that issue, it's a great little drone, easy to fly. Has 2 speed modes, for indoor and outdoor use. Seems durable so far. Blades may bend (one tip got bent to 90 degrees), but flattened it back out with fingers and it was able to fly perfect. I have a 2 year old brindle/pit mix who loves chasing this, and has even snatched it out of the air a few times, smacking it against the ground...still flies like a champ. If it turns out the camera has taken some damage, I will update. But for price and what this thing is about, I'd recommend it.
Jan 05, 2019, 06:56 PM
Just got my sync 251 drone in the rear of the drone the left side will not raise off the ground simultaneous with the other three , causing it to flip over. Any thoughts. Thanks
Discussion Dromida XL 370 FPV Drone w/1080P Camera jobinseattle Beginner Multirotor Drones 0 Jul 31, 2017 06:06 AM
News Dromida HoverShot RTF Camera Drone Jason Cole FPV Aircraft 4 Sep 30, 2016 05:09 PM
Mini-HowTo Dromida XL370 5.8 camera FPV marcuskeeler Multirotor Drone Talk 0 Sep 04, 2016 06:36 PM
News The Dromida Vista UAV 251 mm Jim T. Graham FPV Aircraft 6 Oct 05, 2015 06:02 PM
Discussion Sync FPV and still camera? techspy Aerial Photography 5 Mar 18, 2009 01:40 PM
