This thread is privately moderated by neonext FPV, who may elect to delete unwanted replies.
Oct 13, 2018, 12:01 PM
neonext FPV's Avatar
Mini-Review
Eachine US65/UK65 Review | The Best Brushless Tiny Whoop For the money
After long waiting, he finally arrived at my door :-). It took him long time to arrive.
Almost 50 days, express was too slow . What to say about this tiny brushless whoop?
It is really amazing, the best whoop for this money only 79$. It fly great 19000kv brushless
motors gives great punch, lot of power and smooth flight.
On this little quad nice features I like is Smart Audio so I can very easily change PID and freq on my Taranis QX7.
Frame is build of nice plastic material and can suffer lot of impacts. Great whoop for indoor and outdoor calm
weather flights. Highly recommended.
You can get this on Banggood.com only 79$
Eachine US65/UK65 test flight Stabilized mode Whoop (3 min 25 sec)
Specifications:
Brand Name: EACHINE
Mode Name: US65/UK65
Item Name: 1S 65mm Brushless Whoop racing drone BNF
Wheelbase: 65mm
Weight: 22g(without battery)
Weight:28g(with Original 250mah lipo battery)
SE0603 KV19000 Motor
Mode: SE0603 KV19000
Configu-ration:9N12P
Stator Diamter:6mm
Stator Length:3mm
Shaft Diameter:Φ0.8mm
Motor Dimension(Dia.*Len):Φ9mm*15.5mm
Weight(g):1.8g
No.of Cells(Lipo):1S
Flight controller
Firmware: Betaflight_3.4.0_Crazybee
Betaflight target:
CRAZYBEEF3FR(Frsky version)
CRAZYBEEF3FS(Flysky version)
MCU: STM32F303CCT6 (72MHZ, 256K FLASH)
Sensor: MPU-6000(SPI connection)
Board size: 28.5 * 28.5MM
Board weight: 3.5 g
Power supply: 1S battery input (DC 3.5-4.35V)
Built-in 6A(each) Blheli_S 4in1 ESC Dshot600 ready
Built-in Frsky receiver with telemetry(D8/D16 switchable)
Built-in Betaflight OSD(SPI Control)
Built-in Current meter Max 14A
Built-in 5V 0.8A BEC with LC filter
Built-in voltage detection
BLHELI_S pass-through Ready
Heading LED Ready
Onboard 4in1 6A ESC
Power supply: 1S LiPo/LiPo HV (4.2v/4.35v)
Current: 6A continuous peak 7A (3 seconds)
Support BLHeliSuite programmable
Factory firmware: O_L_5_REV16_6.HEX
Default protocol: DSHOT600
Frsky receiver Version
SPI BUS receiver
Frsky D8/D16 switchable
Compatible both D8 and D16 transmitter
Channels: 8ch or 16ch
Failsafe support
No ground interference ( Transmitter and receiver 1 m from the ground): 300m
Flysky receiver Version
SPI BUS receiver
Protocol: AFHDS and AFHDS-2A Switchable
Channels: 8ch(AFHDS) or 14ch(AFHDS-2A)
Failsafe support
AIO Camera&VTX
Output power: 25mW
Frequency: 40CH
Input voltage: 3.3V 5.5V
Current consumption: 300mA(type)
Camera resolution: 700TVL
Field of view: 120į
Smartaudio ready
Video Format: NTSC
Antenna: RG178 antenna
Frequency: 5.8GHz 6 bands 48 channels
With Raceband: 5474 5945 MHZ
Size: 13.9"12.0mm ( L*W )
Weight: 3g
Lipo Battery
Capacity:250mAh
Voltage:3.8v
Continuous Discharge Rate: 40C
Instantaneous discharge rate: 80C
Weight: 6.5g
Connector: PH2.0
Features:
Betaflight support , multi flight mode: ACRO/AIR/ANGLE
Powerful Brushless motor and Smooth ESC
Betaflight OSD support ,easy to get RSSI , Voltage and other info from your goggles
Adjust the settings and the PID of the flight controller via OSD
Frsky version support both D8 and D16 transmitter
Full telemetry function ready
Head lights ready
Camera angle adjustable
Real Bind and Fly version
Turtle mode ready
Package Included:
1 x 65mm Brushless whoop Frame (US or UK to choose)
1 x Crazybee F3 FC (Frsky and Flysky option)
4 x SE0603 KV19000 Motor
1 x 31mm propeller(4cw+4ccw)
1 x AIO Camera & VTX with smartaudio
3 x 3.8v 250mah 40C/80C battery
1 x 1S06 6 way Lipo/LIHV charger
1 x Propeller disassemble tool
1 x Screwdriver
How to use External recevier on Crazybee F3 flight controller, Download
Notes: 1. Package donít include Power Adapter, suggest 12V 3A power adapter
2. FrSky LBT EU Firmware D16 Transmitter can not compatible with FrSky version drone. You can change your transmitter to LBT EU Firmware D8 version or International version.
3. Please don't upgrade the ESC firmware to the newest one. Because it will lost configuration so damage motors . If you have upgraded to 16.7, please try to adjust the Starput Power to 1.00.
Recommend parts (Not Included):
UK65 Canopy + Frame
US65 Canopy + Frame
IT65 FR65 ES65 DE65 frame
IT65 FR65 ES65 DE65 canopy
UK65/US65 Crazybee F3
US65 UK65 0603/1900kv
Racestar 0603/17|19|22kv
UK65/US65 31mm Propeller
Eachine HV 4.35V 250mAh 40/80C
Eachine US65 UK65 5.8G 700TVL 25mW VTX FPV Camera Smartaudio Ready
PROS
* Great flight performance
* Betaflight support FW
* 3 battery in package with charger
* Smart Audio feature
* Price only 79$
* Great video transmision range and control range
* Great image quality - very sharp and bright image
CON
*NO Cons
Oct 13, 2018, 12:16 PM
Eachine US65 / UK65 Outdoor test flight (2 min 31 sec)
Oct 16, 2018, 03:10 AM
AIR Mode test flight Outdoor
Eachine US65/UK65 test flight AIR mode Whoop (3 min 29 sec)
Oct 22, 2018, 08:55 PM
Hey neo..
Just got my us65 today bound it up ,got my beta flight going , everything works on the screen ,but when i give it throttle nothing happens...
I have a solid red light , then when i arm it it has the red light and a blinking green light insted of a solid green light ... Whats that mean??
Oct 23, 2018, 12:12 AM
Originally Posted by FASTCRASHER
Hey neo..
Search for "Arming disable flags". That flashing says you something. You need check the disable flag code. Probably easier to connect to configurator and check them there.
I have made a small guide on this: http://www.multirotorguide.com/guide...-quad-not-arm/
Oct 23, 2018, 04:25 AM
Stupid question but whether you configured channels correctly ?? Maybe throttle is set up too high , can you post image of your OSD when you arm it.
Discussion NEW Eachine UK65 US65 Whoop FPV Brushless Racing Drone review Bill M - RC Multirotor Drone Talk 0 Sep 14, 2018 04:12 AM
