Bad Dog Smokes Atomizing Smoke Nozzles
Bad Dog Smokes has a new standard for smoke systems with the only Atomizing smoke oil injection nozzles and Atomizing turbine smoke tubes designed for RC use.
Atomizing Smoke Oil Injection Nozzles
Bad Dog Smokes has a new standard for smoke systems with the only Atomizing smoke oil injection nozzles and Atomizing turbine smoke tubes designed for RC use. These nozzles can really make a difference in reducing mess and increases smoke on times compared to conventional smoke fittings. If you like to smoke it out on the field, then you'll want to check these nozzles out. Here's a snippet from their website with info on why you should atomize.
"The reasons are clear, or should we say smoky? A very small orifice size decreases smoke oil consumption and increases smoke ON time per tank. Droplet size of fluid as it leaves the surface of the nozzle is extremely small which aids in faster vaporization of smoke fluid. Expelled fluid velocity is slowed substantially aiding in more complete burning or smoke generation. This minimizes inherent muffler cooling and unburnt blow-by resulting in an oil covered airframe. Added features such as depth of spray adjustment, rotational directionality & consistency in flow volume and spray pattern."
Learn more at Bad Dog Smokes
New Product Bad Dog Smokes NEW Star Fan atomizing smoke nozzle doublestroken Fuel Plane Talk 3 Nov 02, 2017 11:22 PM
Discussion ESC Bad? Smoking motor! Alpine42 Multirotor Drone Power Systems 0 Apr 22, 2016 11:26 PM
Question Smoked ESC bad motor?? RunAway15 Multirotor Drone Electronics 5 Dec 16, 2015 08:59 AM
