This thread is privately moderated by unclegeorge, who may elect to delete unwanted replies.
Oct 11, 2018, 08:02 PM
Trader Rating: 376
unclegeorge's Avatar
$19.95 USD
Buyer pays shipping
Sold
NIB-Down & Locked DL517 Miracle KILL switch.
NIB-Down & Locked Miracle Kill Switch for ignition gas engines from you transmitter. $19.95 + $2.80 S&H.
Down and locked's 15 AMP Miracle Switch and regulator provides a 15 amp current and low amp cut of switch. Connection are two female JR connectors are provided as battery inputs and two mail JR as outputs to your model. Plug in the on/off switch , adjust the voltage and you are ready to go, 5V factory set. Comds with heavy duty switch to mount in your fuse!
INSTALLATION
1- Connect input power to the female JR connectors.
2-With a small screw driver adjust the voltage to you models requirements.
3-Using a volt meter varify the adjusted voltage on the Brown (-) and the Plus (+) wires of the male JR connector out.
4-Connect the ON/OFF switch and mount it in your model, if can be extended length if you need with more JR extensions.
SPECIFICATIONS
Input voltage range to 16 volts
Output range 4.7-Aprox Battery volts
Output current 15 amps (Continuous and peak)
Temperature range -(40 to 185 deg F)
Weight with switch 20 grams.
I do not ship outside the US or other countries. I no longer take Money Orders but will take personal checks! Send a personal check if you do not have a Pay Pal Account! My mailing address : George Jenkins, 2012 Old Arbor Court, Sarasota, Fl. 34232
NOTE, PLEASE READ ALL OF THIS: Please give me your name, mailing address & email to help me keep track of your order by typing in the item you are buying in the “Detail” section along with your mailing address in your Pay Pal purchase.
NOTE: RC Groups and Pay Pal are NOT connected so when you tell me what you want to buy you STILL need to write it in the Pay Pal detail section so I don’t have to chase it back on forth.
PLEASE DON’T MAKE ME GUESS AS TO WHAT YOU ARE ORDERING, YOU KNOW, BUT I DON’T! Also, please put in your email address.
If you PM me for an item, follow up immediately with a Pay Pal payment to make sure your get what you want. I sell on the “First Come-First Serve” Basis. Please note! My account in Pay Pal is under: [email protected]
Keep in mind that I am not Amazon Prime and it was mailed at the US Post office "Snail Mail" and may take 4 to 6 days to reach your doorstep.( Be patient!) Uncle George
Sold Tech aero ignition kill, duraliite, miracle switch Mattsrcking Aircraft - Fuel - Airplanes (FS/W) 0 Feb 14, 2018 08:39 AM
For Sale NEW!_NIB-Miracle Switch DL517 to keep yor engine running! unclegeorge Aircraft - General - Radio Equipment (FS/W) 0 Nov 28, 2016 05:26 PM
Sold Servos, kill switches, Miracle switch SBP Aircraft - General - Radio Equipment (FS/W) 6 Apr 15, 2015 03:31 PM
Sold Kill Switches,Miracle Switch,Servos SBP Aircraft - Fuel - Engines and Accessories (FS/W) 1 Apr 15, 2015 06:28 AM
Discussion miracle RC switch and Opti Kill switch installation help neuhausr Fuel Plane Talk 4 Jul 30, 2013 12:46 PM
