This thread is privately moderated by unclegeorge, who may elect to delete unwanted replies.
Oct 11, 2018, 06:58 PM
Trader Rating: 376
unclegeorge's Avatar
$59.90 USD
Seller Pays Shipping
For Sale
REDUCED-Used but not abused AstroFlight Deluxe Li-Poly charger
If you need a reliable battery charger for Li-Pol batteries, the AstroFlight Deluxe is for you at $59.90 shipped in US only ! S&H priority mail due to weight $12.85
Astro Flight 109 Lithium Digital Charger/Discharger is one of the finest chargers available. This charger is specially designed to charge and discharge Lithium Polymer battery packs and can handle any pack containing from one cell up to nine cells (4.2 volts to 37.2 volts). Cell sizes can range from 140 mAh to 8000 mAh. This charge uses a proprietary 8-bit microprocessor to perform all of the necessary mathematical computations required to insure foolproof charging and discharging of Lithium Polymer battery packs. A two line digital display indicates the status of the charging sequence and tells you the charge current, the number of cells in the battery pack, the battery voltage, the duration of the charge, and the actual number of milliamp hours of charge put into te battery pack. A biult-in voltage converter boosts the input from 12 volts to 40 volts so that battery packs containing up to nine cells can be charged. This charger is designed to be powered from a 12 volt regulated power supply, or a 12 volt automobile battery. Never use an automobile charger as a power source, for it could damage your new Model 109 Lithium Charger. There are two power cords on the charger/discahrger. The four foot long cord with the alligator clips is the input cord and should be connected to the 12 volt power source. The short cord is the output cord and is fitted with Astro Zero Loss Connector #526. Connect the output cord to the Lithium Polymer battery being charged or discharged. The charger has a current adjust knob on the front panel. Charging current can then be adjusted between 50 milliamps and 8 Amps. Discharging current is electronically limited to 1.25 Amps.
I do not ship outside the US or other countries. I no longer take Money Orders but will take personal checks! Send a personal check if you do not have a Pay Pal Account! My mailing address : George Jenkins, 2012 Old Arbor Court, Sarasota, Fl. 34232
NOTE, PLEASE READ ALL OF THIS: Please give me your name, mailing address & email to help me keep track of your order by typing in the item you are buying in the “Detail” section along with your mailing address in your Pay Pal purchase.
NOTE: RC Groups and Pay Pal are NOT connected so when you tell me what you want to buy you STILL need to write it in the Pay Pal detail section so I don’t have to chase it back on forth.
PLEASE DON’T MAKE ME GUESS AS TO WHAT YOU ARE ORDERING, YOU KNOW, BUT I DON’T! Also, please put in your email address.
If you PM me for an item, follow up immediately with a Pay Pal payment to make sure your get what you want. I sell on the “First Come-First Serve” Basis. Please note! My account in Pay Pal is under: [email protected]
Keep in mind that I am not Amazon Prime and it was mailed at the US Post office "Snail Mail" and may take 4 to 6 days to reach your doorstep.( Be patient!) Uncle George
For Sale Used but not abused Park Zone 2-3 Lipo charger unclegeorge Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 12, 2017 01:43 PM
For Sale 7 charger that are used but not abused for radios and glow drivers! unclegeorge Aircraft - General - Miscellaneous (FS/W) 2 Oct 08, 2017 01:22 PM
For Sale AstroFlight Deluxe Li-Poly Charger Timeflyer Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 09, 2012 05:13 PM
Sold Sold Thanks Mike ____ AstroFlight Deluxe Li-Poly Lipo RC Battery Charger 109 Mattsrcking Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 02, 2009 02:22 PM
Li Poly Charger (AstroFlight 109 Deluxe) bmw040 Batteries and Chargers 0 Oct 08, 2003 10:15 AM
