This thread is privately moderated by grant22, who may elect to delete unwanted replies.
Oct 11, 2018, 01:38 PM
Trader Rating: 27
All aboard Flight 666
grant22's Avatar
$160.00 USD
Will not ship
Sold
FW 70mm F-16 with upgrades (AZ or CA)
Hi all. Up for grabs is the equivalent to the $279 High Performance version. Why? Because this has the upgraded metal suspension landing gear all the way around and has an inrunner fan setup. Also I’ve done a little weathering on her.
I bought this F-16 about a year ago and has been really reliable. Before adding the metal gear, I had one nose retract failure which resulted in a main only landing which resulted in some nose rash. See the pics for the repair, but looks more than adequate. After that incident is when I repl the gear with metal gear and a new front retract.
About 20 flights ago I installed an FMS V2 inrunner and has resulted in great efficiency, thrust, and sound. Really the jack of all trades.
The plane alone, PNP, is $160 LPU in Lake Havasu, AZ. Also available when I go to work in Harbor City, CA or I can drop off in between during my commute. That will all be work schedule dependent.
Also available with the AR636 installed and I have really become good at figuring out the gyro values. So right now it flies SOLID in 15+ mph winds. It’s really impressive. I’d prefer to keep the rx, but if you really want it, we'll add $40 for a true BNF Jet with a tuned stabilized experience.
This plane does really well with 6s batts between 4000-5000mah (not incl)
Ask any questions you have
PNP $160
BNF with AS3X $200
PayPal, fees are on you.
Oct 12, 2018, 08:03 AM
Trader Rating: 27
grant22's Avatar
Sale pending
Wanted Upgraded landing gear for Freewing f-16 70mm Vasaro Aircraft - Electric - Jets (FS/W) 1 Jan 21, 2018 04:18 PM
For Sale FW 90mm F-16 (HET upgraded/new/-3 flights) BNF kscobey10 Aircraft - Electric - Jets (FS/W) 0 Sep 23, 2017 02:31 PM
Sold FW 70mm F-16 Electric Retracts swps Aircraft - Electric - Jets (FS/W) 0 Sep 21, 2017 10:58 PM
Sold FW 70mm F-16 Electric Retracts swps Aircraft - Electric - Jets (FS/W) 0 Sep 15, 2017 03:40 PM
Build Log FW 90mm F-16 Kit Bash-- 70mm test model Video Added, Post 57 Knife Liddle Large EDF Jets 69 Apr 28, 2017 04:29 AM
