This thread is privately moderated by bobzilla, who may elect to delete unwanted replies.
Oct 10, 2018, 11:03 PM
Trader Rating: 117
EVFlyersBoss
bobzilla's Avatar
$250.00 USD
Seller Pays Shipping
Sold
4 lightly used MKS 777HV servos with 2-1/2" arms
Selling 4 used MKS 777 HV servos. Alumium case, titanium gears, includes long 2-1/2" aluminum arms. Used in IMAC plane a few dozen flights.
Minimal slop.
$250 shipped CONUS. PayPal ok.
SPECS:
MKS Servo with Full Aluminum Case and Titanium Gears
The MKS HV High Voltage Servo series is designed to operate at high voltage and low current, delivering higher torque per unit weight. A control data rate of 333Hz makes the MKS HV servo an exceptionally agile, ultra-fast responding product with precise control. Titanium gears, dual ball bearing output shaft, and strong overload protection delivers low noise, durability and long life.
Dead Band: 0.0008 ms (Default)
Control System: +Pulse Width Control
Working Frequency: 1520μs / 333hz
(RX) Required Pulse: 3.5 ~8.4 Volt Peak to Peak Square Wave
Operating Voltage: 6.0 ~7.4 V DC Volts
Operating Temperature Range: -10 to + 60 Degree C
Operating Speed (6V): 0.14 sec/60 degrees at no load
Operating Speed (7.4V): 0.11 sec/60 degrees at no load
Operating Speed (8.4V): 0.10 sec/60 degrees at no load
Stall Torque (6V): 388 oz/in (28.00 kg/cm)
Stall Torque (7.4V): 506 oz/in (36.5 kg/cm)
Stall Torque (8.4V): 527 oz/in (38.00 kg/cm)
Torque: 520 oz/[email protected]
360 Modifiable: NO
Motor Type: Coreless Motor
Potentiometer Drive: Indirect Drive
Driver Type: FET
Bearing Type: Dual Ball Bearings
Gear Type: Titanium Gears
Programmable: NO
Connector Wire Length: 15.0 cm (5.9 in)
Dimensions: 40X20X45 mm (1.57x0.97x1.77 in)
Weight: 81.4 g
Sold 4- Hitec 5645MG Servos W/ 4 Red Anodized Aluminum Servo Horns Crazyflyer20 Aircraft - General - Radio Equipment (FS/W) 2 Feb 15, 2016 05:44 PM
Sold 3 servos, 4 servo extensions, and one y connector dojet Aircraft - General - Radio Equipment (FS/W) 0 Nov 23, 2015 02:22 PM
Sold 8 Mini servos - 4 high speed digital 4 HS-225MG lammbn Aircraft - General - Radio Equipment (FS/W) 0 Oct 03, 2015 05:53 PM
WTB E Hobby HES490 4.8g Servo or Cirrus 4.4 g servos Morb Aircraft - Electric - Airplanes (FS/W) 0 May 23, 2004 01:12 AM
