H-King Swallow 670 FPV Flying Wing
HobbyKing has a new mini FPV wing out called the Swallow 670. It has a 670mm wingspan and it's made from EPP foam with carbon fiber reinforcements for strength and durability.
Mini FPV Wing Deal
HobbyKing has a new mini FPV wing out called the Swallow 670. It has a 670mm wingspan and it's made from EPP foam with carbon fiber reinforcements for strength and durability. There's plenty of room inside for your FPV gear too. They are selling it as an PNF for $75.77 or in a kit version for $43.75. It does have a 3 axis stabilizer included as well.
The PNF version comes with a 2205/2300kv brushless motor, a 30A ESC, 9g servos and 6x4.5 props. They suggest you use a 3S 1500mAH lipo battery to power it. This should be a fun little mini wing that you can throw in your car and go play.
Specifications:
  • Wingspan: 670mm
  • Length: 277mm
  • Weight: 160g (without electronic equipment)
Included:
  • 1 x 3-axis fight controller
  • 1 x 30A BLHeli 2~4S Opto ESC
  • 1 x 2205-2300KV Brushless Motor
  • 2 x 9g Servo
  • 2 x 6045 CW Propellers
  • 2 x 6045 CCW Propellers
Required:
  • 3~4CH Radio / Receiver (with Elevon Mixing)
  • 1 x 1500mAh 3S Lipo battery
Optional:
  • 1 x FPV Camera
  • 1 x 5.8GHz Video Transmitter (for FPV)
  • 1 x FPV Goggles or Screen (for FPV)
  • 1 x Action Cam (if required)
Check out the H-King Swallow 670 FPV Flying Wing PNF Here
Check out the H-King Swallow 670 FPV Flying Wing Kit Here
Oct 10, 2018, 10:07 AM
cbear's Avatar
is this a rebranded kit?I wonder if it would fly on a 2s li-ion using the srix nano goblin motor ?
Oct 10, 2018, 02:46 PM
Does it have the little flat spot for mounting a Mobius or Runcam upfront?
Oct 10, 2018, 09:33 PM
USA: LakeGeorge, New York
I think most will use that power setup since
it's sooo proven
Latest blog entry: My FAVORITE FPV CockPits'!!!!
Oct 10, 2018, 10:31 PM
John Hendry
It has two canopies and one has 42mm wide x 58mm length flat area set in (to front of canopy and nose drops down so 82 mm to end of nose up front, and because it sets in you lose about 15mm head room (@ 87mm from front of nose) inside up front where battery goes. HK changed the mold so a lot more room inside for battery now without front spar in the way.
Oct 11, 2018, 12:25 AM
Thanks. I considered the earlier/other version of this plane from Banggood, but quickly gave up after researching it and seeing all the mods required to get around the spar in the battery hatch etc.. So cool if HK got that sorted.
Oct 11, 2018, 12:35 PM
What does PNF mean?
Oct 11, 2018, 12:39 PM
Plug ‘n fly. It’s HK’s version of PNP.
Oct 11, 2018, 03:00 PM
ab amicis auxilio parvulo
Aerospacer's Avatar
Looks like the Reptile S670 also has had the internal upgrades done to it now as it is being shown on Banggood.
Oct 12, 2018, 02:44 PM
How hard would it be to remove the stickers?
Oct 12, 2018, 11:41 PM
Foam Rules, Gravity Sucks
Bravedan's Avatar
If in keeping with others, fly it twice and they will fall off.
I assume they come ready fitted?
Oct 13, 2018, 02:38 AM
Aka: Tom Jenkins
ApexAero's Avatar
Nope! Bought two and gave em away, useless little turds for way too much money, don't waist it...
Oct 15, 2018, 08:35 AM
was considering to buy one to put a sk3 2500kv motor + fpv and a gopro session5 but im not sure it might be too small for so many items, also im affraid is not very stable
Oct 18, 2018, 01:25 PM
Love & a Molotov cocktail
Punkie's Avatar
I just received mine, it is a box of bits.
The stickers are on a couple of sheets in the box.
The plug and fly version just has an extra bag of bits in the box.
You have to trim some of the foam and glue some bits together and solder up the motor, ESC and battery plug.
Discussion Reptile Flight Controller For Swallow-670 S670 S800 Grey RC Airplane PNP Version scousethief Banggood.com 1 Oct 10, 2018 10:41 PM
New Product Reptile Swallow-670 S670 - 670mm race wing Frimen Flying Wings 2 Jul 06, 2018 06:01 AM
Review Scale FPV Flying - The H-King J3 Navy Cub Jim T. Graham FPV Aircraft 16 Jan 16, 2018 02:39 PM
New Product Reptile Swallow-670 S670 Grey 670mm Wingspan EPP FPV Wing KIT / PNP Justapoke FPV Aircraft 5 Jan 08, 2018 04:43 PM
New Product Reptile Swallow-670 S670 FPV GeekBuying Geekbuying.com 0 Sep 21, 2017 04:34 AM
