This thread is privately moderated by GroundControlRC, who may elect to delete unwanted replies.
Oct 07, 2018, 01:47 PM
Video
Tutorial - Range Testing your Radio and Aircraft
Here is a link to the Video:
https://www.youtube.com/watch?v=rzmKVRgy2nw
First, I want to thank my Wife for going out into the Desert with me and helping to conduct this Radio Range Test. She also captured the Maiden Flight of this Aircraft on video for me. So, thank you, thank you, thank you ;-)
I'm performing a Range Test on my newly build "Glue & Fly Series" F-22 Mini V2 before the Maiden Flight.
I could not find much information online regarding how to perform a proper Range Test so I created this video to show you how I perform Range Test which I think is a very thorough and real world procedure.
If you have to conduct a Range Test by yourself I would suggest setting up a camera to record the plane, with audio, so you can review the video and see and hear everything that is going on.
The mistake I made during the Range Test was not reviewing the video footage right away. It wasn't until I reviewed the video footage that I discovered the ESC (Electronic Speed Controller) was resetting and therefore making the Receiver intermittent.
What I thought was a problematic Receiver turned out to be a problematic ESC.
Also, you should turn your aircraft 45 degrees and retest until the aircraft is back to the heading you started with as from experience I can attest to the fact that aircraft receivers can have bind spots. Doing a Range Test with the aircraft facing only one direction is not sufficient for proper Range Testing.
Going forward, I'm also going to perform the same procedure while holding the aircraft vertically and rotating 45 degrees each time to ensure everything is fine in that profile as well.
I also started with the aircraft approx. 2.5ft off the ground. The manual states putting the aircraft on the ground, however, I do not fly my aircraft on the ground except for takeoffs and landings so I think having the aircraft 2-3 feet off the ground is a more valid test.
You should always perform a proper Range Test especially with new aircraft or radio equipment.
Don't crash or lose you aircraft because you didn't do a proper Range Test.
Also, make sure your Fail-Safe is setup properly and test to make sure it works before flying.
Here is a link to the mishap with the Super Cub losing radio contact because it had a blind spot:
https://www.youtube.com/watch?v=lUF6lG-Vdtg
Happy Flying!
New Product AKK X2 Range Test 4 km distance, 5.8Ghz 40CH 25mW/200mW/500mW/800mW Range Test akkteck USA - District IV 0 Oct 13, 2017 02:00 AM
Discussion Radio Range Testing jimmycashley Giant Scale Airplanes 7 Aug 23, 2017 02:37 PM
Discussion Is turning off the radio really good enough to test out of range? SirRexAlot Radios 2 Jun 15, 2017 03:52 PM
Poll Do You still range check Your digital radio? FLOEY Electric Plane Talk 42 May 18, 2016 10:59 AM
