Sep 20, 2021, 10:16 PM
Du Bro Seabird update
Back to the Du-Bro Seabird….. Worked on making the spray rails today. Thanks to Scott and RDJeff for their modification ideas on their Lanier Seabirds…
Started with sanding(220) lower hull, then glued 1/8” strip of balsa to lower hull. The strip was beveled with a 15 * cut for the spray rail . Measured and fit fiberglass rail to balsa. Tacked glued.. Check angle of rail, re-glued rail and trimmed fiberglass.Then put green 2 pt putty above and below rail. Most of the green putty is sanded off, (220/320), primed….white spot putty next.
Will increase the step height 1/8th” and sharpen step edge later this week…..Other mods, widen rudder 1/4”, install water rudder and utilize 2 servos for aileron control instead of original one with original Du Bro Seabird.
Cheers,
B
Sep 22, 2021, 09:24 PM
Du Bro Seabird Step modification
Increased the step height by 1/8” with balsa and fiberglass.. The increased height in step should help with the planing, T/O issues.This is how I did it.
Also increased the rudder width by 1/2 “ and fiberglassed the vertical/horizontal stabilizers, rudder and elevators….with very lightweight cloth and resin.The glassing of the balsa parts is standard, old school, pattern stuff..and waterproof. I used silkspan and Aerogloss dope back in 1973 on my first Du Bro Seabird, when I was 14 yrs old …you could still see the wood grain. I’ve used Monokote for over 30 yrs which allows dents. Dan De Luca (RIP) of Pathfinder game .. is the only person I’ve ever seen that rivaled painted finishes with Monokote.…A Master monokote artist..
I’m sure many others did…..but I prefer fiberglass and paint for longevity…even for this old school Du Bro ARF.
Sep 23, 2021, 09:59 PM
More work
Rough sanding flight controls, filling fuselage seam, dual servos for ailerons ….
Sep 24, 2021, 10:06 PM
Tail
Putty an
Sep 24, 2021, 10:12 PM
Fiberglass and putty
Lots of filling on the seam initially and then spot putty to hide ridges…Still lightweight.
IMO…Lightweight fiberglassing w/ resin is the way to go on balsa flight control parts..Sands easy .Rudder has been slightly widened.
Sep 24, 2021, 11:12 PM
Thermal Seeker
McLeodAviation's Avatar
Looking good. You got a lot done the past few days. What color or colors have you chose for the bird?
Sep 25, 2021, 12:07 AM
Thx,McLeod Aviation,
Yes, Vacation..
Did you ever start on your Harpoon ?
Don’t know my livery yet, I’m a long ways off, but it won’t be standard or boring…I’m a classic pattern guy, so this will include multi colors …probably urethane or acrylic.
Sep 25, 2021, 05:58 PM
Thermal Seeker
Yes, Vacation..
I haven't started on the Harpoon but look forward to it. Sure would be fun flying off the water.
Sounds like you will be applying an awesome paint scheme on the Seabird. I've seen some really nice paint jobs on classic pattern planes. I remember seeing a Dirty Birdy at the Toledo show in RCM magazine with an amazing paint job. I loved seeing pictures from the Toledo show every year in RCM. Guys came from all over the country to show off their latest and greatest creations.
Sep 25, 2021, 06:23 PM
Yes..
Regarding the Toledo or the WRAM show ..Masterpieces on display. Nowadays, folks think foamies look good ..and display them for awards at shows. Different times and generations.
If you search RC groups , Sailplanes, Sterling 1-34 …you can see the livery on my 1-34 that I “borrowed “ from a Spot On pattern plane. the Seabird won’t be that complicated, but it will have several colors …That 1-34 only took me 8 years to build, 2 to cover….LOL
Sep 29, 2021, 01:04 AM
Thermal Seeker
I did a quick search on your profile page to find all attachments. Your Sterling 1-34 looks great. I'm sure the bright colors help keep an eye on the model when riding thermals out of sight. lol.
The T2A-MKlV in your attachments looks awesome. Did you paint that beautiful model?
Sep 29, 2021, 02:10 AM
Thx,
The Sterling 1-34 was finished over 3 years ago and is a little heavy at 4.75 lbs. I built it for the slope out here in CA. My intention is to maiden it on the slopes of Torrey Pines when the wind is at least 12kts. I haven’t been around when this has occurred….work…LOL.
The test flights went very well at a local beach with a very small slope.
No.My T2A-Mk IV (RIP) was painted by a friend(Chris) who was an RC modeler when I lived in Dallas in 1992. His auto bodyshop, in N. Dallas was called Christian Bro’s..Just OUTSTANDING work ..He was very familiar with weight issues. Chris painted my pattern models in his bodyshop when he had time..We used PPG products and I provided the paint schemes. A very talented young man…
Sep 29, 2021, 10:36 PM
Tail group attachment
Worked on priming, sanding the empennage and attaching it to the fuselage. First measured and leveled the stab. Then re-sanded the area area on the rear fuselage for the stab attachment. The original Du-Bro Seabird does not have the plywood plate in the rear area of the plastic fuselage to attach the stab. (I presume that Lanier did this to strengthen the area.) I used the original Du-Bro idea and used 15 min epoxy to attach the stab to the fuse and 5 min epoxy to attach the vertical stab. The vertical stab was slightly warped , so we pinned it straight before epoxing..We took multiple measurements to ensure the angles between wing and stab, horizontal stab and vertical stab, etc, Many more measurements than I took as a kid in 1973…. Last few photos of the Seabird with the wing and stab on…It’s starting to look like a flying boat.
Sep 30, 2021, 07:37 AM
marecisko's Avatar
Hi,
I have question , I am not sure but why did you round edge of fuselage after step?
It will have significant impact during start from my point of view.
Marecisko
Sep 30, 2021, 09:29 AM
Greetings Marecisko,
I did not round the edges of the hull aft of the step. I left this section of the hull as designed by Du- Bro in 1970.Based on previous Seabird reports, the planing and T/O issues of this early ARF design were related to the smaller, rounded plastic step that was a part of the molding process. The deeper, sharper step that I made should help with this issue and resolve the water separation issue.
Oct 05, 2021, 12:33 AM
Servo installation
Used a 3/32” plywood plate vs the 1/8” plate as specified on the Du-Bro plans.. Du-Bro has a full size paper mock up of the installation…glued the provided hold down blocks for the plate. For the ailerons, 2 servos used , instead of the one servo…which will allow flaperons,… some photos..
Discussion Inflating Du-Bro Large Scale Treaded Wheels hookpilot Scale Kit/Scratch Built 4 Dec 01, 2018 09:29 PM
News Robart now carries DU-BRO products! Jim T. Graham Electric Plane Talk 0 Oct 30, 2017 01:43 PM
Question Du Bro ball links with turnbuckle studs doublestroken The Builders Workshop 7 Mar 16, 2017 06:55 PM
Discussion Best way to cut a Du Bro Flex Cable? Pierre_de’ Loop The Builders Workshop 11 Feb 10, 2017 07:22 PM
Discussion Du-Bro 2-56 pull pull on a 1/4 CUB? badfrogg Giant Scale Airplanes 7 Aug 02, 2016 05:41 PM
