Dec 14, 2019, 02:11 AM
davereap's Avatar
The new motor has plenty of power...hover and vertical is good..
Unfortunately my ESC went weird and intermittently the motor would screech and stop..then it would go again..
The motor is fine , possibly a slight improvement over the Gartt..
The weird ESC was binned and a new one works ..
Testing on a 2s the motor draw is 6.5A at max..
quasar new motor setup 12 12 2019 (3 min 55 sec)
Dec 25, 2019, 02:16 AM
davereap's Avatar
latest video .. with a new ESC its flying great.. in this video 3 quasars are flying..
quasar new motor/prop setup 19 12 2019 (9 min 47 sec)
Dec 26, 2019, 01:59 AM
davereap's Avatar
motors.... Racerstar are 22.5gms with 2mm gold connectors and heat shrink added... the gartt motors are 23.5gms with the same connectors..
with sunnysky at 25.5gms again with connectors.. the Racerstar win out...
A possible week spot on the racerstar is where the wires exit the motor, but that/they can be reinforced with a bit of glue..
Top to bottom...racerstar... Gartt.. sunnysky..
It was the thin arms on the sunnysky that gave problems bending too easily..
The Gartt and Racerstar are individually stronger..
Jan 05, 2020, 12:24 PM
davereap's Avatar
dont you wish you had his skill level.. r/cdawg flying
Quasar EPP 3D Delta Knife Edge Flight (1 min 27 sec)
Jan 05, 2020, 12:44 PM
flyin' fool
goldguy's Avatar
All it takes is lots of practice...……………. and hot melt glue!!
Jan 05, 2020, 03:05 PM
davereap's Avatar
LOL.... I've got the glue, had the practice and still cant fly as good as that ..
Jan 12, 2020, 11:01 AM
davereap's Avatar
After a cut back , a v3 quasar is now a mix of a v2 wing with a fat v3 body...
Modified for yet another trial...
the fat quasar vs a fat disco.. spans are about 18" ..running gear all the same
This one being a mix and is yet another version..
It has a v3 fat body which is a couple of inches longer than the span of its v2 wing.
Note this makes the rudder hang further out the back.. The body plus rudder being 24.5" long
And the wing itself is 1" longer than usual, its chord is 19" to the rear of the elevons at the root, with an 18" span
Weight without its lipo is 170g...6oz...
the lipos I use are either 450 2s @ 26.3g or 500 2s @32.3g
For comparison the 18" disco weighs in at 150g without lipo.
they both have landing gear...
the setup is my standard one... racerstar motor 2304-1850.. 8x4.3 sf prop.. 3x TGY 1440a servos.. 12A ESC and a small RX.. on a 2s 450-500 lipo...
Note... with this setup I can also run on 3s with no problems , other than an excess of power and higher speed....lol.. I stick with 2s for indoor flight, that is fast enough..
Jan 12, 2020, 03:05 PM
flyin' fool
goldguy's Avatar
Flat n' fat is where it's at!!
Jan 13, 2020, 03:15 AM
davereap's Avatar
and over powering them is fun
Discussion Simple Delta... a quick build "prop on the front" delta dekan Foamies (Scratchbuilt) 3061 Jul 31, 2019 09:54 PM
Discussion Bullseye Delta, RET w/no dihedral delta-- the finest RET Delta w/ Video tymbrewolf Foamies (Scratchbuilt) 145 Jul 04, 2012 05:38 PM
Cool tool for changing numbers of winding and diameters wye/delta - delta/wye powerditto Power Systems 1 Nov 05, 2005 01:17 PM
Rave advice sought on negative delta V / zero delta V peak charging djgorman23 Batteries and Chargers 3 Jan 04, 2005 08:28 PM
Micro Delta! ,maybe Mini Delta digitaloblivian Scratchbuilt Indoor and Micro Models 7 Oct 02, 2004 02:42 AM
