May 17, 2019, 01:38 AM
davereap's Avatar
latest videos.. all three standard sized versions flying..
quasar versions indoors 17 may (5 min 11 sec)
quasar versions indoors 17 may 2 (5 min 39 sec)
Jun 06, 2019, 04:02 AM
davereap's Avatar
more flying with the 3 quasars last week..
3 quasars 31may (6 min 9 sec)
Aug 18, 2019, 03:17 AM
davereap's Avatar
still in one piece, going well.. flying every week..
Aug 18, 2019, 09:23 AM
pull up -- PULL UP!!!
Yeah, mine is the stock WM kit. I bought a spare for the eventual day of replacement, but it remains in the box. Like you, fly it every week.
Aug 31, 2019, 01:02 AM
davereap's Avatar
Having tried a few wing and body variations, I have found all fly well..
For me there are only minor differences..
I am presently building another two for flying buddies..
These are at 23" span from 8mmEPP.. V2 wing ..
PDF files are below, they have added squares to make plan alignment easier
edit note...when gluing the fuz to the wing the rudder hinge line should have been the reference point.
It should be fitted, lined up with the rear of the elevons.. then the motor block is recessed slightly into the wing.
On the ones below , the fuz parts were aligned from the front of the wing resulting in the fin and rudder being brought an inch or so forward ...
This is yet another variation.. no problem , its easy enough to add in a strip to the fin and move the rudder back a bit , but I doubt it will make a difference as the rudder is well powerful , and so far my different fuz shapes have not made a noticeable difference to the way any of them fly....
Aug 31, 2019, 01:44 AM
davereap's Avatar
latest video
3 quasars 29 08 2019 (6 min 46 sec)
Sep 06, 2019, 02:17 AM
davereap's Avatar
My older V3 was looking tatty.. but still going strong.... so I gave it some more paint and then redid the pdf files...
the pdf's are for a 23.5" span..
On the gartt 2204-1800 it hovers a treat using a 2s lipo and 8x4.3 gws sf type prop.. It flies lovely..
Using Adobe and scaling down by a couple of inches makes for a lighter model and gives a sharper performance on the same power setup..
Discussion Simple Delta... a quick build "prop on the front" delta dekan Foamies (Scratchbuilt) 3061 Jul 31, 2019 09:54 PM
Discussion Bullseye Delta, RET w/no dihedral delta-- the finest RET Delta w/ Video tymbrewolf Foamies (Scratchbuilt) 145 Jul 04, 2012 05:38 PM
Cool tool for changing numbers of winding and diameters wye/delta - delta/wye powerditto Power Systems 1 Nov 05, 2005 01:17 PM
Rave advice sought on negative delta V / zero delta V peak charging djgorman23 Batteries and Chargers 3 Jan 04, 2005 08:28 PM
Micro Delta! ,maybe Mini Delta digitaloblivian Scratchbuilt Indoor and Micro Models 7 Oct 02, 2004 02:42 AM
