Jan 11, 2019, 05:45 AM
davereap's Avatar
Qv3 16.5fatty maiden trimming flight 10Jan2019 (4 min 59 sec)
Qv3 16.5fatty flight2 10Jan2019 (5 min 12 sec)
Qv3 16.5fatty flight3 10Jan2019 (6 min 2 sec)
Feb 09, 2019, 09:15 AM
davereap's Avatar
Finally the weather has warmed up enough.. at 6 degrees-C the lipos are ok.. 2s is adequate .. 3s is fine..
the noisy prop is down to a poor fitting adaptor and unbalanced prop..these are now sorted for next weeks session..
Along with the small quasar you might notice a couple of funnyCubs flying.. they are good, able to fly very slowly at low power yet able to aerobat well..
Qv3 16 5fatty flight1 8feb2019 (7 min 19 sec)
Qv3 16 5fatty flight2 8feb2019 (4 min 11 sec)
Qv3 16 5fatty flight3 8feb2019 (3 min 30 sec)
Qv3 16 5fatty flight4 8feb2019 (5 min 1 sec)
Feb 25, 2019, 04:36 AM
davereap's Avatar
here the last weeks session.. on 2s its a lot quieter.. and its performance is improved
Qv3 16 5fatty 21feb2019 (10 min 15 sec)
Mar 08, 2019, 01:48 AM
davereap's Avatar
testing flights are continuing.... both large and small size Qv3's are going well...
performance is very similar.
They both use 450 2s lipos..
Note..flight times are better with the larger model , this is contrary to what I expected..
Max thrust is much better on the larger 8.5oz Qv3 model, its using a gartt 2204-1800..with an 8x4.3prop
The smaller lighter fatty uses an tgy1811-3800 with a 6x3 prop..
It may be worth making a larger in-between size "Fatty" using the Gartt setup..
A 20" span is my thought.
Mar 09, 2019, 07:35 PM
I'm guessing if my big qv3d was made of epp instead of heavy foamboafx it would be a real floater.
Might try a lightweight version for winter
Mar 14, 2019, 02:10 AM
davereap's Avatar
Its taken many years but Ive come to the conclusion that you must build your models light if you want the best performance.. I do find that difficult because our venue is a killer ...bash and crash wise..
8mm EPP works for strength but is just a bit over heavy.. Indoors on 2s the standard 23" span 8mm size is excellent, on 3s it can be a bit much, but has plenty of thrust for vertical .. outside it will be ideal..
5mm would be a better floater but is a bit too fragile..
Finding an optimum size for the material we can buy is the key..robot birds has both 5mm and 8mm..
perhaps for outside a 25" or 26" using the 8mm will give best floating results.. or going smaller a 20" using 5mm ..
For performance building , getting floaty models look at the mutiplex 3d models manuals... use their methods to save weight..
Discussion Simple Delta... a quick build "prop on the front" delta dekan Foamies (Scratchbuilt) 3060 Sep 09, 2018 03:01 PM
Discussion Bullseye Delta, RET w/no dihedral delta-- the finest RET Delta w/ Video tymbrewolf Foamies (Scratchbuilt) 145 Jul 04, 2012 05:38 PM
Cool tool for changing numbers of winding and diameters wye/delta - delta/wye powerditto Power Systems 1 Nov 05, 2005 01:17 PM
Rave advice sought on negative delta V / zero delta V peak charging djgorman23 Batteries and Chargers 3 Jan 04, 2005 08:28 PM
Micro Delta! ,maybe Mini Delta digitaloblivian Scratchbuilt Indoor and Micro Models 7 Oct 02, 2004 02:42 AM
