Nov 04, 2018, 05:26 AM
Originally Posted by davereap
UK art boards that were a good quality product had the same problem... I used to leave them in a bath for ages, then the stripping took ages ... not satisfactory at all... finally I found uncovered depron and swapped to that .. Ive still got a box some where of the paper covered board which is much too heavy with the paper on, to be used...
I found a solution. It it's time consuming though. If you heat up the paper enough the glue let's go and the paper plus glue comes clean off. I used a hsair dryer on high but I found outhersnbused a heat gun. Font get it too hot though as it can shrink the foam.
Nov 04, 2018, 05:31 AM
Originally Posted by Jim_W
Enjoying this beautiful day! This v1 is unpredictable..or mine is anyway...I hope with some MPF and new plans for the v3, it will be better.
https://www.youtube.com/watch?v=ezt1JgV5xMM
Looks like it's flying well. Unpredictable? Have u tried balancing the wings? On mine due to where I had to mount esc and wires being on line side it was heavy on one side. I balanced it out with a small battery on the other wing which made a big difference. Especially in barriers. There'ds a lot of wing area I found it catches the wind really easily.
Nov 05, 2018, 01:21 PM
FinLly got the video. Not made any changes. Winds we're super low so could actually fly it the way I wanted to.
Harriers like a chsnmp hovers easily even for a beginner. Cannot get it to knife edge just flips over.
I had a shot of an sbach foamie and the rudder okn that behaves totally different even to the small 3d shockie i hsve. The sbach when using just s little rudder gives a nice flat turn with hasrdly any sileron corrections needed and eill turn quite alot.
Where as sll the oither plsnes i have the rudder requires slot nof sileron to keep it from rolling. Seems there is a lot of coupling going on compared to a well designed/setup 3d plane.
The sbach will start rolling once u start using slot of rudder
QV3D XL (6 min 56 sec)
Nov 05, 2018, 04:46 PM
Jim
https://youtu.be/y4nD8fNKqBk
Nice! Enjoyed your video and the XL looks like it flies great. That is a beautiful place to fly.
Nov 05, 2018, 05:38 PM
Yeah it's a nice club especially during week in winter time when u dfolnt mind being a bit cold. Lots of cool guys.
Nov 06, 2018, 05:28 AM
davereap's Avatar
The rudder on the Q is very strong...perhaps we need to use a massive expo setting.. If the balance on the fuz is good only small rudder inputs might do the job..
Nov 07, 2018, 12:59 AM
flyin' fool
goldguy's Avatar
With a conventional airframe like the Sbach, when in knife edge, the rudder becomes the elevator and the elevator the rudder.
With a delta, the rudder becomes the elevator, and the elevons the rudder. But elevon movement also can induce aileron movement as well if your not careful.
So, if the CG is right, it only takes small movements to keep it on it's side. Just a bit too much and it will roll over.
Nov 07, 2018, 01:02 AM
flyin' fool
goldguy's Avatar
Baz: Sounds like you need to balance the prop.
Nov 07, 2018, 05:58 AM
Probably they are cheap hk ones 11x4. Either that or I have a bent motor shaft. Or nthe prop adapter isn't ln suite straight. This motor has taken a few hits in it's time.
I do have one of those dubro balances however it's a fake copy. The shaft it came with was too big wouldn't fit the clones. I finally got a replacement it came in a padded envelope so it was bent. Not to mention that the wheels are pretty poor so it's useless. Need to find my other prop balancer
Nov 18, 2018, 03:45 AM
davereap's Avatar
Finally its flown...and I find Ive made some mistakes, noticeably the COG was calculated wrong.. and being rear heavy it did some odd things..
lol .. all good fun , it was still flyable.. but a B** to try and trim..
now wheels are added , skids were poor..
flying weight at 8.5oz... with a 2s 450
15gms ballast added to get a 22.5% COG
wing loading at 3.2 ozsqft.
Nov 18, 2018, 05:04 AM
Very nice will need to try that fin shape on mine. I haven't had much flights on the xl one due too winds. It's a nhasndfull I. Anything other than 5MPH and less.
Nov 18, 2018, 02:38 PM
davereap's Avatar
the fin shape is only altered in order to get the vertical areas percentages closer to ideal...
eg: if the wing is balanced at 22.5% then the fuzz should have 22.5% of its vertical area in front of the same spot...
ts not easy with the body shape as it is.. I can only achieve about 20%..perhaps less.. which should result in the nose dropping when banked over... with even more area at the back..ie bigger fins , the percentage will be lower and the nose will drop even faster....
If you have more area at the front the nose will rise when banked over... and that causes problems.. its better to drop, and hold it with some rudder.....
The reduced fin area flight is not so good...When flying in high alpha there is now a slight touch of wing wobbling..so the fins will be put back to the original shape..
The COG change cured the weird flight issues.. It is flying nicely on a 2s with the COG between 22.5 and 25%, and with a 3s it has more than enough power
Nov 23, 2018, 02:11 AM
davereap's Avatar
Videos from last nights session..flying with the COG at 23.5% on a 2s ..
The air temp in the hall was down at 4 degreesC and the 2s lipos had reduced power, not enough for hover and vertical, but a later change to 3s sorted that.. There is loads of vertical on a 3s
The extra nose weight of the 3s made no difference although it must have brought the COG forward.. anywhere between 20% and 25% works well.. just adjust the COG to where you prefer.
Qv3 trimming after COG adjustments 22 11 2018 (6 min 24 sec)
Qv3 COG adjusted 22 11 2018 (5 min 39 sec)
Nov 23, 2018, 05:23 AM
https://youtu.be/9DSFNLB3uiI
https://youtu.be/bOMvCCQwRG4
Very nice looks to be flying very nice. Got to say I think you guys have your indoor flying sorted. Look at all those models flying together. The one I go is a bit of a weird mix of quads slow sticks and some umx micro models.
Nov 24, 2018, 12:25 AM
davereap's Avatar
we run 1/2hr slots... helis/quads and planes.. while planes, like the crack yaks etc, are at mostly a larger size.. we get lots of mid-airs by accident so the planes have gradually gotten bigger and are made from EPP, so more likely to survive.. the umx get chopped up too easily but they can get more of a go later in the evening..
Discussion Simple Delta... a quick build "prop on the front" delta dekan Foamies (Scratchbuilt) 3060 Sep 09, 2018 03:01 PM
Discussion Bullseye Delta, RET w/no dihedral delta-- the finest RET Delta w/ Video tymbrewolf Foamies (Scratchbuilt) 145 Jul 04, 2012 05:38 PM
Cool tool for changing numbers of winding and diameters wye/delta - delta/wye powerditto Power Systems 1 Nov 05, 2005 01:17 PM
Rave advice sought on negative delta V / zero delta V peak charging djgorman23 Batteries and Chargers 3 Jan 04, 2005 08:28 PM
Micro Delta! ,maybe Mini Delta digitaloblivian Scratchbuilt Indoor and Micro Models 7 Oct 02, 2004 02:42 AM
