This thread is privately moderated by VicT, who may elect to delete unwanted replies.
Oct 02, 2018, 09:12 AM
Mini-HowTo
Using a box cutter to make wing tip dihedral
The approximate dihedral angle was measured as 21 degrees for Conscendo Advanced. Any angle between 18-22 will do. A greater angle will provide more turning performance with rudder only.
An alternative method is to cut the stock tube at the halfway point and insert a 4-6 inch long music wire bent slightly to create more dihedral. A straight 4-6 music wire can be put in to bring the stock dihedral back. The wire should be a tight fit and need not be glued in.
I taped the tips in place so they can be removed and replaced with tip plates made from 1/32-1/16 ply or plastic. A 4-5 inch long spar could be used to join the tip and wing. This will be a future project mod.
Here is a sketch of the dihedral angle:
Discussion Will using rudder over ailerons make it less likely to tip stall? handydandyandy Beginner Training Area (Aircraft-Electric) 26 May 15, 2018 03:37 PM
Discussion paper or cardboard sleeve/socket/sliptube making tips for wing joiner noobdude Balsa Builders 5 Sep 09, 2017 02:05 PM
Question Basic Wing Design -Traditional Dihedral vs. Straight Center With Upswept Tips Rickochet Foamies (Scratchbuilt) 55 Jun 28, 2009 05:49 AM
Help! Dihedral Wing Tip help tymbrewolf Foamies (Scratchbuilt) 13 Feb 01, 2008 09:05 AM
dihedral on tips of wings left out? [email protected] Electric Sailplanes 7 Nov 07, 2004 01:09 PM
