Dec 26, 2004, 07:05 PM
Spin Master Air Hogs Intense Micro RC Plane
I was just at radioshack and they had this little RC plane for sale for $20. It's one of those "Air Hogs" planes and it's called Spin Master Air Hogs Intense Micro RC Plane. It looked like a 2 channel with rudder control. Anybody know if it actually flies and if it's worth $20?
http://www.radioshack.com/product.as...t%5Fid=60-4380
Dec 26, 2004, 08:11 PM
I wouldn't spend money on it.
Dec 26, 2004, 11:19 PM
del
del
del's Avatar
I'm gonna go get one! For $US20 it might be worth a hack.
Or at worst, more parts....
--del
Dec 26, 2004, 11:23 PM
Flys OK but control is throttle on only with bang bang turn and it has a bit of lift so turning a bunch is a must but it does fly.
Dec 27, 2004, 12:52 AM
del
del
del's Avatar
Thanks for the report Matthew!
Sounds hackable...
--del
Dec 27, 2004, 10:07 AM
I think so..there is basicly a nice electronics board with output to the motor and the 3 wires going to the actuator.TX range is good so far.
Dec 27, 2004, 10:35 AM
Flap chap
snakeX2's Avatar
What worth would it be to hack it? I think weight would be the issue, how much does the components weigh, Rx, battery? Sounds like a fancy bit-car plane to me.
Dec 28, 2004, 02:59 AM
del
del
del's Avatar
OK, er, just got one today... I was WRONG..
It was a bummer; a sequence of bad news that got worse..
The first bad news came from the manual where I learned that
the throttle was on full blast the moment the transmitter got turned on.
To shut off the thrust while the thing is in flight, you have to turn off
the transmitter! Then, of course, you lose rudder control! Gag!
Barf.. That's just bad design.
Then I tried to charge up the flight batteries.... Nope.. The LED on the
transmitter did not light, and the Nimh battery pack didn't charge.
Nothing I tried would fix that.
So, still hoping it was hackable, I took it apart; and found more bad news.
The receiver circuit board was big, and heavy. Not worthy of a hack...
The rudder actuator was pure Bit Car, and as usual, I broke a magnet wire
on one of the coils..
In the end, I had a direct drive N-20 motor and prop, some Nimh cells that
I won't use, some bit actuator parts that I doubt that I'll use, and a bunch of
crap that will end up in a land-fill.
The only good thing that came out of the whole experience is that,
because I bought it, the thing won't end up disappointing some kid...
Maybe that makes it worth buying, but it would make it the most expensive
N-20 I've ever bought....
--del
Dec 28, 2004, 06:30 AM
The ceiling is the limit!
micromad's Avatar
Over here in the U.K. they are selling them for £30 in Woolworths which I think is a rip off for what they are.
Dec 28, 2004, 10:40 AM
Sorry Del, mine works fine and flies good once you get it airborn. Infact its a pretty slow flyer and gains altitude quite fast. Anyway...........
Discussion mIcro rc plane? FlyJumper Scratchbuilt Indoor and Micro Models 7 Jun 30, 2006 06:13 PM
Found Micro RC Plane Flight Pack johndreid Aircraft - Electric - Airplanes (FS/W) 0 Sep 25, 2005 01:53 AM
WTB: Micro Rc Plane VBSuperMaxx Aircraft - Electric - Airplanes (FS/W) 0 Apr 11, 2005 09:28 PM
air hogs ornithopter convert to RC ? surfdawg Ornithopters 2 May 12, 2004 06:48 PM
Accurate weights of various DWE micro RC plane components drliu Scratchbuilt Indoor and Micro Models 2 Jul 26, 2002 01:30 PM
