This thread is privately moderated by fastmax, who may elect to delete unwanted replies.
Oct 01, 2018, 01:21 PM
Time For Me To Fly!
fastmax's Avatar
Build Log
Skystars S225/STX225 5s 5 Inch FPV Racer Kit Build/Review
EDIT 1/24/2019 Available here for only $109.99
Flight Controller PDF Manual/Pin Out Diagram Thanks to member GCRC
The new Skystars S225/STX225 DIY Kit is now available. Looks to me like it is going to be an excellent value in the 5 inch FPV racer category. Specs look really good, and I am liking that we are seeing more and more of these quads available in kit form.
My kit arrived a couple days ago, and I finally got a chance to snap a few pics. Hoping to get started on the build this afternoon, and will post more pics as I make progress.
EDIT-10/2/2018
Build is complete. Added a bunch more pics below. Please don't hesitate to ask any questions, or request pics of something I missed. Flight video coming soon. Also added some large zoomable images of the F405 AIO Flight Controller (FC) pinout to aid in wiring for anyone else doing this build. Some of the print on my board was pretty faint and the pics helped me locate the necessary solder pads.
For anyone looking to get started with this FPV drone on a tight budget, and get in the air for around $200 here is a shopping list that will get you in the air. You will want to add more batteries as your budget allows, but this will get you flying. Please don't hesitate to ask any questions. I am happy to assist. I personally use, or have used everything listed below. All of my flight videos with this drone are done with the kit and radio in the below shopping list.
Skystars STX225 Kit
Flysky FS-i6 Radio & Receiver
iMax B6 AC/DC Balance Charger
4S 14.8V 1300mah LiPo Battery
EDIT-10/3/2018
Managed a quick test flight today. Flies very smooth, and has a lot more punch, and speed than I was expecting, especially on 5042 high efficiency props. Should be really impressive on some 5152 props.
EDIT-11-13-2018 Spares are now showing up at Gearbest
Frames are available here for $21.44
Motors are available here for $8.24 each
ESC's are available here for $6.99
I will update if/when more show up.
EDIT-11/26/2018 Printed a shark fin for my Skystars STX225. Thing file here. Requires a quick easy mod to install. Front of the plate lines up perfectly, so install it with the stock screws and then you will see where to trim and drill the screw holes for the rear. See image below.
EDIT-11/28/2018 Got some new props to try out as soon as the weather permits. They're EyeSky 5053 and I hope they perform as good as they look. See pic below. Flight video hopefully coming in the next couple days.
EDIT-12/6/2018 Here is a link to some 3D printable landing gear designed for this quad. Special thanks to adis1313. If anyone here would like a set of this landing gear that doesn't have access to a 3D printer PM me, or post here and I will print you a set for actual cost.
First flight video
SkyStars S225/STX225 5 Inch FPV Racing Drone Kit First Flight WOW! ONLY $99 (3 min 13 sec)
EDIT-12/18/2018
Test flight running EyeSky 5053 Props. Good news. Motors were cool to the touch after a 3:30 flight.
SkyStars STX225 5 Inch Kit EyeSky 5053 Prop Test (4 min 1 sec)
Specs from the Gearbest product page.
Frame Kit Specifications:
● Wheel base: 225mm
● Frame arm thickness: 4mm
● Bottom plate thickness: 2mm
● Side plate thickness: 2mm
Motor Specifications:
● Motor KV: 2300
● Idle current: 1.26A
● Lipo cell: 3 - 5S
● Max continuous current: 25A
● Max continuous power: 240W
● Configuration: 12N/14P
● Motor resistance ( RM ): 0.0572 ohm
● Stator diameter: 22mm
● Stator thickness: 4mm
● Motor diameter: 27.88mm
● Motor body length: 20mm
● Overall shaft length: 34.2mm
ESC Specifications:
● Continuous current: 35A
● Peak current: 40A ( 10S )
● Input voltage: 2 - 5S
● BEC: no
● Main control chip: STM32F051
● Firmware: BLHeli - 32 supports 500HZ PWM, Oneshot125, Oneshot42, Multishot, Dshot150 / 300 / 600 / 1200
Flight Controller Specifications:
● Sensor: MPU6000
● Power supply: 5V
● Integrated OSD
Camera Specifications:
● Total pixels: PAL: 1020H 596V ( 0.61MP ); NTSC: 1020H 508V ( 0.52MP )
● Effective pixels: PAL: 976H 582V ( 0.57MP ); NTSC: 976H 494V ( 0.48MP )
● Signal system: PAL / NTSC switchable
● Resolution ratio: 1200TVL
● Automatic gain control: yes
● White balance: on / off optional
● Exposure mode: electron exposure
● Electronic shutter: 1/50 ( 1/60 ) - 1/100000S
● Camera lens: standard 2.3mm
● Lens operating voltage: DC 12V
● Working current: 70mA ( low power consumption )
● Working temperature: - 20 Deg.C - -60 Deg.C
● Humidity: 0 percent - 98 percent
Transmitter Specifications:
● Frequency band: A - E ( 8 channels in each band )
● Transmitting power: 600mW
● Full video format: NTSC / PAL
● Input voltage: 7V - 24V
● Transmission distance: more than 0.5km ( 25mW ), more than 1km ( 200mW ), more than 2km ( 600mW )
● With output power self-check function
● Antenna connector: MMCX
Propeller Specifications:
● Quantity: 2 pairs
Battery:
● 3 - 4S 1300 - 1500mAh LiPo ( not included )
Oct 01, 2018, 07:08 PM
Mitchie's Avatar
Got mine today too! Frame's put together, so I plugged the fc to BF and it got 3.1.7 loaded on it! I don't know which fw to load as BF says it's OBSD board. Does it mean it's an Omnibus F4 board? There's no instructions anywhere for this frame/flight controller.
Oct 01, 2018, 07:42 PM
Time For Me To Fly!
fastmax's Avatar
I've been browsing for more info on the FC too, and not coming up with anything. I would think that's probably what OBSD means, but can't say with any certainty. If I come across anything relevant to this specific FC I'll be sure to post it here. Please do the same if you find anything.
EDIT
Ok, it does indeed mean it's an OMNIBUSF4SD board. Still trying to find more info on it though.
Oct 02, 2018, 07:47 AM
Time For Me To Fly!
fastmax's Avatar
Making some progress with the build.
Oct 02, 2018, 12:20 PM
Time For Me To Fly!
fastmax's Avatar
Ready for its maiden flight. Indoor test hover went well. Now it just needs to stop raining.
Oct 03, 2018, 05:56 PM
Time For Me To Fly!
fastmax's Avatar
Managed a quick test flight. Really impressed considering it's running 2204 motors, and 5042 props. Way faster, than I was expecting. Should really move out on some 5152 props. Video coming shortly.
Oct 04, 2018, 01:37 PM
Time For Me To Fly!
fastmax's Avatar
Flight video added above.
Oct 04, 2018, 04:19 PM
Mitchie's Avatar
Can someone post a connection diagram for the solder pads? I’m pretty sure where everything goes, but I really like to have documentation to follow. Don’t need to fry anything with stupidity!
Oct 05, 2018, 12:27 AM
Time For Me To Fly!
fastmax's Avatar
Hi Mitchie I took some pictures of the FC and zoomed in on them in order to read some of the very faint print on the board. I will upload them ASAP. If there is a specific connection you are curious about just let me know.
Oct 05, 2018, 04:57 AM
Mitchie's Avatar
Nothing in particular, just want to be sure.
Oct 05, 2018, 10:19 AM
Time For Me To Fly!
fastmax's Avatar
Added some large images of the FC to the first post. Makes identifying the necessary connections easier for anyone that's doing this build.
Oct 05, 2018, 06:02 PM
Mitchie's Avatar
Have you updated the firmware?
Oct 05, 2018, 06:03 PM
Mitchie's Avatar
I guess it's just the two of us
Oct 07, 2018, 05:28 PM
Mitchie's Avatar
Fastmax, what rx are you using? I’m having a hard time getting my rx working (newbish). I’m using a lemon rx and hoping you are too
Oct 08, 2018, 09:57 AM
Mitchie's Avatar
Got the rx figured out and first hover complete. Now I'm not getting an image from the camera. I'm getting OSD info, which proves the vtx and OSD work, but just a black image. Did you have to do something special to get it to work? I'll try swapping the cam to see if that helps.
Build Log Skystars S225/STX225 5S Capable 5 Inch Kit Build/Review fastmax Mini Multirotor Drones 227 Sep 20, 2019 01:24 AM
Mini-Review SkyStars X120 Bolt - Another interesting 2.5 inch option? (review) SoloProFan Micro Multirotor Drones 236 Aug 22, 2019 10:35 AM
Mini-Review Diatone 2018 GT-M3 SX - Stretched X 3 inch FPV Racer (review) SoloProFan Micro Multirotor Drones 17 Jul 08, 2019 06:24 PM
Video SkyStars X120 Micro Racer - Setup & Review kremerFPV Micro Multirotor Drones 8 Jul 08, 2018 04:54 PM
