Oct 15, 2019, 08:19 PM
5Gdrone's Avatar
Hubsan ZINO
Habsan Official Store of AliExpress sold 935 units of ZINO (includes Black color version) and other AliExpress sellers sold 1200 units, but Hubsan Official Store sold only 33 units of ZINO Pro, and others sold 35 units.
ZINO Pro is not good?
Oct 15, 2019, 09:16 PM
dragonblade's Avatar
Originally Posted by Sweref
- it drives sometimes. It's not rock steady.
Out of curiosity, what do you mean by driving and why is that a negative? By the way, for the most part, Zino footage looks pretty steady to me as a result of the 3 axis gimbal.
Oct 16, 2019, 03:34 AM
By no means an "Expert"
rontorbay's Avatar
Think he means DIVING.
On some earlier versions of the FC firmware, rapid forward movement caused the ZINO to dive towards the ground, so it would be wise to gain a little height before initiating rapid forwad movement.
This information was discovered from a video posted on YouTube by, I believe, "Idaho Quacopter". Look him up.
Here's another example.
Hubsan Zino update 1.1.48. Has it improved anything? (19 min 0 sec)
Watch from 18:58
Oct 16, 2019, 09:28 AM
Pixelpeter's Avatar
Rumors about the Zino 2 (NOT Zino Pro!):
HUBSAN ZINO 2 - THE FUTURE ZINO 2 FOR 2020? LOOK & SEE! (25 min 19 sec)
Oct 16, 2019, 11:51 AM
Rumored Zino 2 specs
I've seen lots of stuff about a zino 2 pop in up all over. Along with what QC guy is putting out, I saw this information (specs) online from this link.
https://translate.googleusercontent....71aBEe_dp2ewBA
Link details. Copied and pasted
Description
Brand Name: Hubsan
Model: ZINO 2
Aircraft weight (with paddle + battery): 915g
Folding Size: 216.5 * 129.0 * 94.9mm
Expand Size: 326.0 * 260.0 * 94.9mm
Motor: brushless motor abduction
ESC: ESC figures, more efficient, stronger anti-interference ability
Aircraft Battery: 17.4V 3800mAh smart lithium battery (included)
Remote control batteries: 3.7V 3350mAh (built-in)
Flight time: 33 minutes
Charging time: 2 hours
Figure pass band: 5.725 - 5.850 GHz
Maximum remote distance: 6KM (no interference, no occlusion)
FIG transmission distance: 6KM (no interference, no occlusion)
Camera: UHD 4K
Photo pixels: 12M
Video resolution:
4K: 3840 * 2160 30 / 60fps
2.7K: 2704 * 1520 30 / 60fps
1080P: 1920 * 1080 30/60 / 120fps
720P: 1280 * 720 30/60/120 / 200fps
Motion Control: GPS mode, the optical flow pattern, Atti
Image stabilization system: mechanical triaxial stabilizing platform
Shooting ability: 4K60 frame rate up to 100Mbps
Sensor: Sony 1 / 2.3 inch
Lens parameters: Aperture F / 2.2, TTL 23mm
Low-light capture: the ability to capture low light
Removable lens: can be equipped with filters (ND4 / ND8 / ND16 / ND32) (not included)
Time-lapse photography: freedom delay, surround delay
Remote Control Features:
1. Higher accuracy rocker
2. A remote control with display, real-time display
3. The remote control can be independently controlled UAV
4. The remote control highlighting display, outdoor sunlight clearly visible
Features:
1, the image follow: goalkeeper, to achieve the aircraft to follow
2, visual aids Landing: an aircraft landing, automatic search tarmac, landing on the tarmac, to achieve precision landing
3, the film download: Direct download via wireless links
4, positioning: GPS + GLONASS positioning system bis
5,3800mAh smart lithium battery, the battery power is calculated to ensure the life safety, long life 33 minutes
6.6KM maximum effective distance signal, farther remote control
Specification
General
Brand: Hubsan
Model: Zino 2
Material: ABS / PS, Electronic Components
Type: Quadcopter
Motor Type: Brushless Motor
Functions: One Key Landing, One Key Taking Off, Up / Down, Height Holding, One Key Automatic Return, Slow down, Speed ​​up, Sideward flight, Forward / backward, Turn left / right, WiFi Connection, Headless Mode
Satellite System: GPS, GLONASS
Max Flying Height: 500 meters
Max Speed: Movie mode: 1m / s Normal mode: 12m / s Sports mode: 20m / s
Max Ascent Speed: Normal mode: 3m / s movement pattern: 5m / s
Max Descent Speed: Normal mode: 2m / s movement pattern: 3m / s
Built-in Gyro: Yes
Kit Types: RTF
Level: Professional
Age: Above 14 years old
Connectivity
Remote Control: 5.8GHz Wireless Remote Control, WiFi Remote Control
Channel: 4-Channels
Mode: Mode 2 (Left Hand Throttle)
Radio Mode: Left-hand Throttle Mode 2, WiFi APP
Detailed Control Distance: About 6000m
Compatible with Additional Gimbal: Yes
FPV Distance: 6KM
Transmitter Power: Built-in rechargeable battery
Model Power: 1 x Lithium battery (included)
Battery
Battery Weight: 310g
Camera
Camera Pixels: 12M
Video Resolution: 4K: 3840 * 2160 30 / 60fps; 2.7K: 2704 * 1520 30 / 60fps; 1080P: 1920 * 1080 30/60 / 120fps; 720P: 1280 * 720 30/60/120 / 200fps
Dimensions and Weight
Product weight: 0.9150 kg
Package weight: 3.1250 kg
Product size (W x W x H): 32.60 x 26.00 x 9.49 cm / 12.83 x 10.24 x 3.74 inches
Package size (W x W x H): 27.50 x 26.50 x 12.00 cm / 10.83 x 10.43 x 4.72 inches
Package Contents
Package Contents: * UAV 1, the remote controller 1 *, 2 * blade, a screw blade 2, 1 * load, a screwdriver, the remote controller 1 *
Specification
General
Brand: Hubsan
Model: Zino 2
Type: Quadcopter
Built-in Gyro: Yes
Kit Types: RTF
Level: Professional
Connectivity
Channel: 4-Channels
FPV Distance: 6KM
Battery
Camera
Camera Pixels: 12M
Package Contents
Buy Now
Ric...
Oct 16, 2019, 11:56 AM
Looks like QC guy got the same info and discussing it in his video.
ZINO 2 FULL SPECS & PRICE TAG! (NOT OFFICIAL) (12 min 41 sec)
Ric...
Oct 16, 2019, 05:47 PM
5Gdrone's Avatar
Zino 2
Looks like Zino 2 is a bit simple.
Oct 19, 2019, 08:23 PM
"Drives with the wind..". It's hovering horizontal unstable. (My English is not perfect)
And yes. It also dives but just a fiew decimeters.
But it's worth the bucks. I am not regretting the purchase. It's a good drone to practice with and feel if you want this kind of Drone. If you after a while feel that it's a boring slow flight you did not spend thousands of dollars as the prize.of a DJI
Skickat från min GM1913 via Tapatalk
Oct 24, 2019, 11:27 AM
Pixelpeter's Avatar
Zino battery weirdness:
Just back from flying with my Zino, and something weird is going on with one of the 3 batteries that I have. Not sure if I charged one of them, but when in the craft it read 40% battery-power. As I needed to test something quickly I flew a few minutes with that battery close-by until it forced the Zino into low batt return. Once back home I connected that battery to my (hobby) charger which display showed 99% power ( ) and wouldn't even start a balance charge. For now I have the battery charging (assuming the app/craft were right) on the included Hubsan charger (3 red leds). Weird discrepancy in readings which has got me puzzled
Oct 24, 2019, 12:49 PM
Gravity Tester
KnimRod's Avatar
Probably a bad cell (High IR).. Been seeing a lot of mentions of Zinos falling out of sky and crashing because of this lately. Be careful.
Oct 24, 2019, 04:45 PM
Pixelpeter's Avatar
Using the Hubsan charger for a while seems to have solved the problem; after that I could charge again with my hobby charger.
Zino's falling out of the sky? Wouldn't be surprised if that would be the result of the battery safety catch not catching like it should: noticed on one of my batteries the safety catch getting stuck almost inside the battery with possible nasty results in flight. Needed to fiddle around with it to get it working properly. Something to keep an eye on.
Oct 24, 2019, 09:03 PM
KC5UH transmits -------->
ham2405's Avatar
What hobby charger are you using? Are you using a home made adapter for the Zino? Look at battery voltage, not %
Oct 25, 2019, 04:06 AM
Pixelpeter's Avatar
Using a Turnigy Accucel6 which has proved itself over the past years to me as a reliable little charger. And yes, I'm using a home-made adapter for the Zino batts.
Oct 25, 2019, 02:41 PM
HUBSAN ZINO BATTERY HOW TO CHARGE WITH PRO CHARGER / Come caricare la batteria dello Zino (4 min 4 sec)
New Product Xiaomi Mi Drone WIFI FPV With 4K 30fps & 1080P Camera 3-Axis Gimbal RC Quadcopter Kenxiaofei Multirotor Drone Talk 7 Dec 31, 2018 04:30 PM
New Product Xiaomi Mi Drone WIFI FPV 4K 30fps & 1080P Camera 3-Axis Gimbal Squirrels Mini Multirotor Drones 81 Jul 22, 2017 09:04 AM
New Product Xiaomi Mi Drone WIFI FPV With 4K 30fps & 1080P Camera 3-Axis Gimbal RC Quadcopter Kenxiaofei Multirotor Drone Talk 0 Jan 17, 2017 08:49 PM
