Oct 10, 2018, 01:20 AM
TechTronic9000's Avatar
Originally Posted by SeByDocKy
If there is a 5.8G WiFi link, I hope european Android users won't be in trouble with incompatible channels.
I hope that too as 50% of the 5G WiFi bands used on Chinese quads are not working with normal smartphones sold in the EU. You mostly need to "hack" by using a Chinese brand phone such as Xiaomi and set the regional settings to China but that needs reset to factory defaults on some ROMs
Oct 10, 2018, 11:12 AM
Originally Posted by Crashaccepted
Don't expect any 5.8 goggle/module setup to pickup the video feed from this unless you use a groundstation type deal to convert it but by then the latency would be horrible.
This rig uses 5.8 wifi not 5.8 analog...at least from the description.
According to the description here in this thread the RC control is also 5.8 but the banggood link doesn't specify it.
It's going to be a "watch and see" kind of thing with this one. I pre-ordered the yuneec mantis q (have a yuneec q5004k that never let me down) but if this performs well it may be something to look at playing with.
Yikes. I am assuming the 5.8g compatibility meant video it has a vtx that I can use with goggles. That is not the case ?
Oct 10, 2018, 11:29 AM
I kill batteries!
Majority of the time on these types of drones the video feed is 5.8 wifi. This is fine for slow flying AP.
It has a vtx to send the video back to the tx (with vrx inside) but again it is based on wifi and not analog (according to the descriptions).
You might be able to grab the feed from the tx somehow and connect it to your goggles if your goggles has av input. But now your getting to the point of you might as well just do a dedicated ground station versus modifying the controller.
Oct 11, 2018, 01:37 AM
There are two "5G" options, the regular 5G WiFi and the "old" 5.8G Anolog FPV, the new Zino is "smart-app" based drone so 99.99% will uses digital WiFi which means 5G WiFi and that is not compatible with analog 5.8G FPV.
Oct 11, 2018, 02:34 AM
SeByDocKy's Avatar
Unfortunatly for some phones, as soon as the SIM card is inserted, android reselect the EU area even if you installed a oversea ROM ... So this trick is not working 100% of the time ...
Oct 11, 2018, 02:45 AM
Yes, that is also true and actually happens to most "known" brands such as Huawei, Samsung, etc. There are still some no-names such as Elephone, Ulephone, Umi, etc. that still ask before starting. Another trick is to start the phone without a sim after a factory defaults and select the region, then insert the SIM and hope for the best, non the less it's a pain in the .....
Oct 11, 2018, 02:50 AM
SeByDocKy's Avatar
I contacted Hubsan to be sure they have to pay attention on this topic... To be able to select the area via the appz for example. What is is confirmed with the zino, no USB thetering capacity ... only connexion via WiFi ....
Oct 11, 2018, 05:39 AM
Being depending on the phone WiFi is not that great, reminds me of the H501A app freezes an occasional lag... At least they could add a FPV output like the H501A which had both WiFi and regular FPV built into.
Here's a closeup of the app, which looks like the same for their older models.
Oct 11, 2018, 07:11 AM
Pixelpeter's Avatar
There are far more people around with smartphones then those who have 5.8gHz FPV stuff like a lot of us ... of course they'll go with smartphone connection. Looks like an interesting bird.
Oct 11, 2018, 10:05 AM
SilbernerSurfer's Avatar
Specs on BG are looking great!
https://www.banggood.com/de/Hubsan-H...ds=newArrivals
Oct 11, 2018, 10:48 AM
Yeah, but why not have the 5.8 reciever in the remote, and just feed video through the cable to the app? Or is that not the way any of this would work?
Oct 11, 2018, 10:55 AM
Pixelpeter's Avatar
You often do connect your smartphone via a cable to the remote/transmitter That's how you get better range. Toygrade quads however rely on direct signal to the phone, thus limiting range.
Oct 12, 2018, 04:38 PM
Yes my goggles have a video input. I wonder if this has a video out that could make this work. Seen anything in the zino specs?
Oct 16, 2018, 09:48 AM
The figure "9" Specialist
aeronca's Avatar
I'm interested in following along for a while on the Zino. Interesting stats, need to see if it will walk the talk...
Oct 16, 2018, 10:13 AM
Always Fly 2 Mistakes High!
RGS2010's Avatar
...Fly the Hype!
New Product Xiaomi Mi Drone WIFI FPV With 4K 30fps & 1080P Camera 3-Axis Gimbal RC Quadcopter Kenxiaofei Multirotor Drone Talk 7 Dec 31, 2018 04:30 PM
New Product Xiaomi Mi Drone WIFI FPV 4K 30fps & 1080P Camera 3-Axis Gimbal Squirrels Mini Multirotor Drones 81 Jul 22, 2017 09:04 AM
New Product Xiaomi Mi Drone WIFI FPV With 4K 30fps & 1080P Camera 3-Axis Gimbal RC Quadcopter Kenxiaofei Multirotor Drone Talk 0 Jan 17, 2017 08:49 PM
