Sep 30, 2018, 04:06 AM
Send Glue
Question
1.3 vid and vector
Hi Guy's, I am trying out 1.3 vid for the first time as I am after a bit more range when flying with just goggles and single cp antenna for those times I am not running full ground station. I have 5.8 and 2.3/4 but need a bit more range, hence trying 1.3. I am aware of some probs where up against with 1.3 such as servo jitter(running analog servos in the test plane and getting almost none, so good there. But I am wondering what is considered acceptable as far as sat count goes, I imagine the more the better! I am not sure what I normally get, and so far I have not had it outside of my shed...that has a tin roof, and I am getting between 9 and 11 inside, I have about 2 feet between the vid ant and sat Rx. Just wondering what is acceptable, and any other advice.
Neal
Jan 02, 2019, 05:28 PM
Originally Posted by neale
... and so far I have not had it outside of my shed...that has a tin roof, and I am getting between 9 and 11 inside, I have about 2 feet between the vid ant and sat Rx. Just wondering what is acceptable, and any other advice.
Neal
Lucky you, I don't get ANY gps lock inside my metal roofed house.
I've flown Vector with 1.3G video on 3 different aircraft and have never had a GPS problem. My GPS units are anywhere from 12" to 4/5" from the 400mW 1.3 VTX.
I set my min GPS sats for home look to 5 or 6. I typically get that in 1-2min after taking the model outside. I typically see 0 sats, then 5-6, then maybe no more until I get up in the air when I'll see 8-11. I'd consider anything above 5 to be flyable.
Discussion 1.3 vid nitrowing FPV Equipment 23 Aug 07, 2016 01:12 AM
Help! Help video interference - Dragon Link V2 - 1.3 Lawmate rx & 300mw vtx - Vids & Pics Doostur FPV Talk 3 Nov 28, 2013 07:55 AM
Discussion ep-1 project (with working power trim)youtube first run vid on pg 3! igotit Racing Boats - Electric 55 May 13, 2013 06:42 PM
Discussion Vector Vector **with maiden vid** sno Slope 82 Apr 21, 2008 09:50 AM
Discussion New 1.3 gigs live vid system. macboffin FPV Talk 0 Jan 20, 2008 03:36 PM
