This thread is privately moderated by Mad_angler1, who may elect to delete unwanted replies.
Sep 29, 2018, 03:16 PM
Bog Flusher Platinum Grade
Mad_angler1's Avatar
Mini-Review
Freewell Gear DJI Mavic 2 Pro All Day ND Filter Set
Freewell 4K Series All Day Filter Set
For DJI Mavic 2 Pro
To coincide with the launch of the new Mavic 2 from DJI Freewell Gear have released their range of accessories and filters for this new model.
Freewell Gear make a range of accessories for drones that include ND filters, carry cases and device holders and they have kindly sent me their all day filter set for the Mavic 2 Pro to take a look at.
This new kit contains 8 filters specifically designed for the Mavic 2, Freewell state that these filters use razor sharp optical glass to ensure optimal image quality and that each filter uses 16 layer multicoated optical glass to ensure crystal clarity.
In The Box
Like many of Freewells other filters these come very well protected, this kit comes in two plastic storage cases with the range of filters split across them, standard ND and CPL in one box and the Polarised versions in the other. The lid is completely removable and each filter is held in place by foam in the base of the case.
The Filters
Freewell Gear All Day Filter Kit includes
8 Double Sided Multi Coated Filters
ND4
ND8
ND16
CPL
ND8/PL,
ND16/PL
ND32/PL
ND64/PL
Looking at the ND filters closely you will see that they are extremely well made, the glass is perfectly fitted with no signs of adhesive and both internally and externally the machining is precise with no signs of any imperfections. Externally you can see the Freewell name printed along the top and the ND ratings are marked on the bottom.
To make fitting easier Freewell have also added grips around the outside edge of the filters
Looking at the Polarised filters they are larger overall compared to the ND and have a separate rotating ring that sits on the top to adjust the polarising position. If you have not used Polarised filters before these have the additional ability to restrict light from specific directions depending on where the filter is set, this means youíre able to reduce glare from the sky or remove reflections from water. To set the polarisers position you simply turn the outer ring until you get the desired effect on your footage, this is easy to do on the ground before take off.
Another nice addition is a mark on the ring so you can easily find and remember the desired position for polarisation.
Fitting
To fit you simply remove the existing UV from the Mavic 2 camera, to do this you gently press and rotate and the glass will turn then release
Once removed you can see the main camera lens and housing
To refit simply place the latches into the holes and rotate left to lock in place
A nice benefit of these Freewell filters is that they can also be left on with the gimbal clamp fitted unlike some others out there so you donít have to keep removing them for storage.
Overall
I have been using these filters for the past few days and I am happy to say in my opinion they are very nice high quality filters. In using and testing them compared to others they have no noticeable colour shift all the way up to the ND64 and are easy to use and fit, I did find the polarised ones a little more of a fiddle to get on compared to the standard ND simply because there base plate is much thinner.
Overall if you looking to buy a pretty much complete pack of filters for the Mavic 2 Pro that should cover every occasion and can be left on between flights then these are well worth a look, as with all Freewell gear you can also have piece of mind that if you get an issue later down the line you will be covered as they include there lifetime warranty as well.
This set is available from freewellgear.com as well as amazon and costís $129, it contains a filter for every occasion and as usual is covered by Freewells lifetime warranty.
These Filters are available from
Freewell Amazon Store
https://www.amazon.com/freewell
Freewell Website
https://freewellgear.com/114-dji-mav...nd-accessories
More Info on the DJI Mavic 2 can be found here
https://click.dji.com/ACTBAoHVP9yY3Q...m=link&as=0030
Please note : These filters were received FOC as I do some testing for Freewell, the info provided is an honest reflection in my opinion however as with any preview, review or info provided on any website or YouTube users should look at what a product does, look at many opinions and then make purchase decisions based on that and not a single persons.
Discussion DJI SDK Apps - Spark-P3-P4P-Mavic Pro-Air-Pro2-Inspire1 & 2-M100-M200-M600-A3-N3 MultiRotR Multirotor Drone Talk 2231 Dec 20, 2018 10:19 AM
