This thread is privately moderated by TinkleWid, who may elect to delete unwanted replies.
Sep 28, 2018, 06:51 AM
TinkleWid's Avatar
Smooth 🐢 Caddx Turtle v2 Firmware Update (1080p 60FPS) on BR3 3" HGLRC XJB 145 Quad
🐢 Caddx Turtle 1080p 60/FPS raw footage on BR3 3" inch Quad with XJB 145 stack and motors
Updated the Caddx Turtle from the original firmware from v1 to v2. All the old arefacts are gone and the picture is much smoother compared to my last flight footage (the only issue is that the 16:9 fpv view is now letterboxed)
Still loving my new BR3 Frame from Kwad Karl which flies so much smoother than the original xjb frame. It is much more stable and carries a 4s 850mah very nicely. This video was the Tatu 4S 650mah.
To upgrade the firmware copy download to empty sd card from https://lunchboxfpv.zendesk.com/hc/e...RE-UPDATE-V2-1
ENSURE YOU HAVE THE ORIGINAL FIRMWARE (or risk a brick)
Smooth 🐢 Caddx Turtle v2 Firmware Update (1080p 60FPS) on BR3 3" HGLRC XJB 145 Quad (2 min 9 sec)
Quad Set-Up
3 inch BR3 Frame: https://droiddesignfpv.co.uk/product...-fpv-frame-kit
PIDS used for this video on Betaflight 3.3 (same as xjb 145 for first test)
Roll: 45, 45, 27; Pitch: 46, 50, 30 Yaw:70, 45, 20
Tatu 4S 650mah but moving to 850mah to reduce sag
HGLRC XJB 145 Mini Quad chasis https://www.banggood.com/HGLRC-XJB-1...SABEgJKx_D_BwE
Jumper T8SG https://www.gearbest.com/radios-rece...SABEgJ8cvD_BwE
Caddx Turtlet or Caddx Turtle https://www.banggood.com/Caddx-Turtl...p-1320281.html
Gemfan 3052
Apr 28, 2019, 10:34 AM
Are there two versions of the Caddx Turtle, or just the firmware? I have a Beta x85 HD and I know the firmware is V1.1. Can I update this or do I risk bricking it?
Apr 28, 2019, 02:10 PM
TinkleWid's Avatar
There are 2 versions of the Caddx Turtle but the firmware works for both. There are a number of versions (all v1.1) but I am using the September 2018 release. The latest release is January 2019 but I have not tried it yet. You always risk a bricked camera with the upgrade but I have been lucky so far.
Discussion Caddx Turtles FOV 145 Degree Super WDR Mini FPV Camera 1080P 60fps DVR - Micro HD! BobFromMars Banggood.com 0 Jul 05, 2018 09:05 AM
