Sep 28, 2018, 02:19 AM
Merch's Avatar
New Product
HG P403 1/10 2.4G 4WD 49cm Rc Car 540 Brushed 20m/h Rock Crawler Off-road Truck RTR
https://www.banggood.com/HG-P403-110-2_4G-4WD-49cm-Rc-Car-540-Brushed-20mh-Rock-Crawler-Off-road-Truck-RTR-Toy-p-1332929.html?rmmds=category&cur_warehouse=CN
Description:
Basic information Brand:HG
Item No:P403
Scale: 1/10
Color:Blue
Max speed:20km/h Power System ESC:40A electronic stepless 2-in-1 esc
Motor:540 brushed motor
Servo:3kg S3003 standard analog plastic gear servo
Transmitter Frequency: 2.4G
Channel:3CH
Remote distance:≥ 100m
Battery:4X 1.5v AA(not included) Battery Car Battery: 7.4V 1500mAh Lipo battery(included)
Charging time:about 3.5hours
Using time:about 12minutes
Other Material:hardware,plastic and electronic components Dimension Car size: 49*26.5*25cm(L*W*H)
Wheelbase:280mm/290mm/300mm(adjustable,
Track: 205mm Wheel diameter: R121mm
Main Function:
forward,backward,turn left/right,brake
Features:
26T/28T/30T,the motor gear can be set
Central transmission secondary mechanical gear adjustable (upgradeable remote control)
Up to 6 gear ratios can be set
The front and rear axles adopt a conical gear to straight tooth high-load reduction transmission structure
Large stroke damping adjustable shock absorber
Variable stroke ball type universal joint shaft
Front and rear independent link type bridge system
The wheelbase is adjustable,80mm/290mm/300mm
The protection function,charging,low pressure,high temperature
Package included:
1X Rc Car(included the car battery)
1X Transmitter
1X 7.4V Balance Charger
1X Manual
1X 1.5mm hex wrench
1X 2.0mm hex wrench
1X 2.5mm hex wrench
1X Cross wrench (small)
2X Shock absorber adjustment buckle set
4X Car body latch (small)
2X Car body latch (large)
1X M3*4 drill screw
1X Flanged nylon locknut
1x 26T Motor Gear
1X 30T Motor Gear
2X Nylon cable tie 3*200mm
New Product HG P402 1/10 2.4G 4WD Rc Car 540 Brushed Rock Crawler Metal 4X4 Pickup Truck RTR Toy Merch Banggood.com 6 Mar 25, 2019 10:56 AM
New Product Remo Hobby 1073-SJ 1/10 2.4G 4WD Brushed Rc Car Off-road Rock Crawler Trail Rigs Truc scousethief Banggood.com 0 Aug 22, 2018 06:13 AM
Discussion HG P104 1/10 2.4G 4WD 25km/h Rc Car Knight 550 Brushed Big Foot Off-road Truck RTR To scousethief Banggood.com 0 Aug 13, 2018 05:30 AM
New Product HSP RGT 18000 1/10 2.4G 4WD 470mm Rc Car Rock Hammer Crawler Off-road Truck RTR Toy scousethief Banggood.com 0 Jul 26, 2018 05:22 AM
Discussion HG P407 1/10 2.4G 4WD Rally Rc Car TOYATO Metal 4X 4 Pickup Truck Rock Crawler RTR To scousethief Banggood.com 0 Jun 08, 2018 06:58 AM
