Thread Tools |
This thread is privately moderated by old4570, who may elect to delete unwanted replies. |
Mini-Review
Flysky FS2A 4 channel mini receiver from BG![]() ![]() My next receiver test is this 4 channel flysky AFHDS 2A ( apparently now called FS2A ) . A word of warning , these receivers need to have the pins soldered in place by the purchaser . If you look at the pictures you will see that 3 of my solder joints were questionable . Good thing about Macro Photography , great way to check really small work . Anyhow , I went back and corrected the 3 questionable solder jobs . Once again this is more a test to see how useful this receiver might be for DLG use , as I would be very interested in running a 1s battery without a voltage booster . Some time in the future I will have to so some servo tests , to see how much current they pull . Might be nice to have lower current servos in a DLG running a 1s solution less voltage boost . ( But that's down the track ) Variable Power Supply : Putting the small FS2A receiver on the power supply with 2x9g servos attached , I first tried 5v @ 0.5A - There was no browning out . Next I tried 4v , but I increased the available amps to 1 ( 1A ) . 4v @ 1A - There was no browning out . From here I went to 3.5v @ 1A - There was no browning out . Then I went to 3.2v @ 1A - There was no browning out . To push my luck I dropped the voltage to 3v @ 1A - There was no browning out . Ooooh come on , brownout already ! So I lowered the available current to 0.5A , 3v @ 0.5A , yes the Rx is browning out . At 3.2v the 9g servos are really feeling the low voltage , becoming sluggish . ( Perhaps a good warning for low voltage ? ) 1s Battery : I was going to recharge that 1s battery I have been using , but now me thinks not . Last time I checked it was 3.85v and I think that might be enough . This receiver look to be very 1s capable and all we need to check on is how low can it go ! I plugged in the 1s and then added some 201.8 grams of weight to the end of the servo arm to do some weight lifting ( add some load ) . The results were some what energetic and there was no sign of brownouts . Next I am discharging the battery closer to a state of discharge ( empty ) to see how the Rx performs . At some 3.67v I try again to see if the receiver browns out , and no ! Discharged further to some 3.51v ( battery is close to depleted ) and ran the same scenario and no browning out .. Even with the 1s @ 3.51v the servo doing the lifting had some energy and gusto .. Range Test : Using that 1s battery @ 3.51v I went outside to range test the Rx . Transmitter was the Jumper T8SG Plus and set to range test mode 100uW .. At some 50 meters I still had no brownouts , not even when I tried to block the signal with my body . I have to say , I am learning something ... Conclusion : Darn it to all heck ! , just have to buy another one of these FS2A Rx.. 5 minutes later ( Ok just bought another ! ) A) small mini size Rx B) Looks to run 1s really well C) yes you need to solder in the pins , but why ? Why not de-plug your servos and solder them directly ? And the same goes for the battery , since the Rx will run 1s why not just solder in a battery plug ? ( Fun and games ) D) CHEAP ! E) I really think this Rx might work well in a DLG ( 1 meter or smaller ) F) Range tested well . So I am impressed again , yes I had to buy another ( There was no choice - get em while you can ) .. So this is it for now as far as receivers go , I think I have enough for my glider plans . I have a few 9g servos in my collection , so I may test 'em for current draw - Lower might be better in this case . Also have some cheap small servos on order - be interesting to see how they go . My gliders ( Foam FF ) are not here yet . ( I might want to try wingerons ) Stuff is slowly getting here , hmmm carbon ! ![]() Have fun everyone ... ( I'm trying to ) ![]() |
Thread Tools | |
Similar Threads | |||||
Discussion | FlySky 2.4G 6-Channel Receiver (R6B) for FlySky flight systems | Nitro_Nancy | NitroRCX | 0 | Jun 18, 2018 04:09 PM |
Discussion | Flysky FS2A 4CH AFHDS 2A Mini Compatible Receiver PWM Output for Flysky i6 i6X i6S | scousethief | Banggood.com | 3 | Apr 09, 2018 10:04 AM |
Discussion | 4 dollar flysky Mini Receiver! | akyros | Radios | 8 | Feb 02, 2018 04:58 PM |
Discussion | Flysky i6 -switching controls from one channel to another on the fly (2 pos switch) | ricoghardforth | Radios | 0 | Feb 01, 2018 05:07 AM |
Discussion | champ/p51 receiver - from 4 to 3 channel | codan | Electric Plane Talk | 6 | Sep 04, 2013 03:15 PM |
