This thread is privately moderated by HOMI_EPP, who may elect to delete unwanted replies.
Sep 27, 2018, 05:04 AM
Build Log
hand lauch EPP glider with motor
It is really easy to have fun with this hand launch motor glider!
EPP battery charge hand launch glider plane
You can Launch it to fly without battery charge,also you can choose to charge it first in a short seconds
Wingspan:36CM
Fuselage:36.5CM
Flying weight:21G
Motor:KPD 7*16MM
Charge time:no more than 30s,better to charge 10-15s
(charging indication light and charge protection set)
Flight height:10-15M
Flying distance:100-150M
Flying time:45-60s.
Pack:30sets/carton(retailer box including holder)Weight:9.5KG/cartons
Instructions:
1,Connect the battery box plug with charging socket on the fuselage.
2,Turn on the battery box and keep the fusalage switched OFF.
3,After charging 10-15s,turn the battery box OFF and remove the charging plug.
Cautions:
charging time better within 10-15s,no more than 30s or the capacitor will be damaged.
Flying Operation:
Turn on the switch on fuselage,when the motors starts spinning in a high speed,throw the glider up in the air with an angle of 10-15 degree.
New Product HF-i3 Standard Tail EPP Hand Throwing Glider Airplane 480mm ONLY $8.99 FREE DELIVERY cooperationRC Multirotor Drone Talk 0 Feb 13, 2017 01:41 AM
Question Right hand vs Left hand for DLG lauch? magee8578 Hand Launch 8 Nov 08, 2007 12:17 AM
Re EPP Hand launch Gliders grodgers Hand Launch 6 Jan 06, 2004 04:15 PM
