Many thanks. Just waiting for one of these, then have to figure out how to connect it all up http://hobbyking.com/en_us/blheli-s-4-in-1-30a.html BC |
Mike |
Next I need to bind the Rx to my Taranis. A I see it the board can be fed from a 3s to a 6s Battery.???
There are two tabs just below the bootloader button, marked Vin, and Gnd. I guess that is where the power goes to?? Just like confirmation before I connect it up?? BC |
Flashing - hard to debug. Try looking at the Youtube for the flashing tips. You may need to install Zadig drivers for the DFU mode or thw other reasons. |
Will try freerider. BC |
Power connection
Next problem, where to connect the power, and what voltage.
Are either of these correct?? |
Can't seem to find any info, but does the F7 flight controller come with a barometer?
RXSR-FC (Omnibus F4 V6)
OK, So I have Inav running. I have bound the the Rx to my Taranis+
If I go to the Receiver section in Inav, I get no reaction to any stick movements. If I go to the Motors section, I cannot make any of the motors turn. I have a 4inone esc, connected with the supplied cable. I have connected the esc direct to a receiver, and then I can run all the motors, so I guess the ESC is OK. Any thoughts anyone?? BC |
See Abovehelp
Is this your configuration https://www.rcgroups.com/forums/show...7&postcount=14 MIke |
Mike,
I will go through that tomorrow. Thanks BC |
OK,
I have done that, and now the receiver is talking to the board. I have done the calibration, but all does not seem to be correct. I had this problem before, the orientation of the board does not seem to match what I am seeing on the PC screen. This is made more difficult by the board not having an arrow on it showing which is the front... Any thoughts on this?? Again, thanks for your help. BC I will connect up the ESC again and see if the motors turn. |
I have had enough of that one, so in the bin and start again. BC |
First post on this forum!
I just got this FC, the F7 version. I’m having a having a hard time getting turtle mode to work. It’s not even showing up in the modes tab. Is there a way I can enable it in CLI or something? For the price point I feel like it should have it. Any help would be appreciated, Thanks! |
Thread Tools | |
Similar Threads | |||||
New Product | FrSky New Arrival - RXSRF3OM 20mm Hole Spacing Flight Controller Release! | AndreaHuang | FrSky | 3 | Sep 05, 2018 12:30 AM |
Discussion | F4 - F7 Flight Controller and for Aerial Photography waterproof Drone | Svitol | Multirotor Drone Talk | 2 | Jun 10, 2018 09:39 AM |
Discussion | F3, F4 & F7 Flight Controllers - Is there a performance benefit over a Naze32? | JohnM | Multirotor Drone Talk | 2 | Dec 01, 2017 08:10 PM |
Discussion | F3, F4 & F7 Flight Controllers - Is there a performance benefit over a Naze32? | JohnM | Micro Multirotor Drones | 0 | Dec 01, 2017 05:39 PM |
