Oct 15, 2018, 01:23 PM
Dirty Dee's Avatar
great scheme!
Oct 17, 2018, 05:08 AM
SJ
SJ
SJ's Avatar
What landing gear did you use ?
Oct 17, 2018, 06:32 AM
japim's Avatar
Nice looking plane.
Oct 17, 2018, 08:19 AM
iFly SL
Hi everyone.
First plane from 3d Labs.
How do you get your 3D printers to print these bridges without using supports?
Sportjet
Oct 17, 2018, 09:48 AM
MorganTech
The recommended ones from HobbyKing, but it looks like they are out of stock again.
https://hobbyking.com/en_us/servoles...___store=en_us
https://hobbyking.com/en_us/alloy-ol...___store=en_us
Thanks everyone for the comments on the scheme, it was a combo of paint and vinyl. The plane was printed in clear High Heat PLA, sprayed with silver Rust-Oleum 2X and then trimmed in blue and red Rust-Oleum 2X paint. I created graphic files for the vinyl and used 2mil conforming vinyl that sticks really well to the printed surface.
Oct 17, 2018, 10:10 AM
SJ
SJ
SJ's Avatar
Originally Posted by sportjet
Hi everyone.
Sportjet
Press print and dont worry
Oct 19, 2018, 09:31 PM
iFly SL
Rust-Oleum is an enamel-type spray-paint can? I can't find that specific brand where I live so I need to find a substitute as similar as possible.
Is this the best method for finishing a 3D printed plane?
Sportjet
Oct 20, 2018, 08:12 PM
MorganTech
I'd take a look at your local automotive store, get a silver but not metallic with the flakes. It took 1 1/2 regular spray cans to paint the F-86. The automotive ones might be a bit smaller.
With clear High Heat PLA and silver paint it should hold up to the sun pretty well. Left a sample print with silver paint out in the 70-80 degree sun for about 30 minutes and it stayed pretty cool.
Oct 27, 2018, 08:45 PM
So many planes, So little time
Xflyfun's Avatar
PIMA Girl
I didn't want to use the HobbyKing gear, so I tried the f-4 gear from Motion RC. Freewing 90mm f-4 Phantom...
The Freewing f-4 is about nine pounds, so I thought that was close enough to the printed f-86. 8lbs 5 oz. is the weight of my f-86, that's without batteries.
Some Pics.
The Freewing gear need a shim to make the strut bend back enough to fit the well.
I have a piece of credit card in that spot for now.
Description:
Name: Freewing parts.jpg
Description:
Name: Closeup of shim.jpg
Description:
Name: area to trim.jpg
Description:
grind off a little plastic here,
Name: fit at install.jpg
Description:
Name: HobbyKing retract with Freewing f-86 gear strut.jpg
Description:
The front leg is the HobbyKing retract with a Freewing f-86 strut mounted to the pin, fits nice.
Looking forward to the first flight, I have a Changesun 90 and the fandrive 1500Kv motor on 8S
I have not run it up to test Amps and Watts yet.
Oct 28, 2018, 08:15 AM
SJ
SJ
SJ's Avatar
Looks great. Thanks for the info on the freewing legs. They will be much easier to get hold of.
Oct 29, 2018, 02:56 AM
Hey,
I printed and fly the Mig 15 from 3dlabprint and Would like to use the RC conponents in the Sabre.
EDF is a Wemotec with YEP100A.
Do you think this will work ?
Best regards,
Kai
Oct 29, 2018, 12:28 PM
Xflyfun's Avatar
Originally Posted by fly-kai
Hey,
Best regards,
Kai
I don't see why not, the Mig is a little smaller. I printed the Mig but did not set it up to fly. I did not like the small battery area on the Mig.
The f-86 has plenty of room for batteries...
Description:
I've got a pair of 4S 5000 mAh Batteries installed here.
Oct 31, 2018, 07:58 AM
stevek1959
The latest Mig 15 BIS is similar to the F-86. Plenty of room for batteries.
Nov 01, 2018, 12:02 PM
What´s about the flight weight?
And the weight without the battery?
When do you plan to fly?
Klaus
Nov 02, 2018, 07:13 AM
Xflyfun's Avatar
Klaus
Name: f-86 specs.JPG
Description:
Or here's a link to 3Dprintlab https://3dlabprint.com/shop/f86asabre/
I plan to fly soon, The weight of this plane is 8lbs 5 ozs without the batteries.
I do want to check Amps and Watts with the meter before flight.
Also, the HobbyKing retract needs to be reversed,> Freewing retracts and HobbyKing are not working together so well.
Build Log 3D LabPrint P-47N build stangrob 3D Printed Planes 134 Mar 26, 2019 04:51 PM
Gallery F86 Sabre Rubber Power Ronny Free Flight 32 Nov 25, 2017 11:13 AM
Poll 3D LabPrint night flyer stangrob 3D Printed Planes 3 Jul 12, 2017 10:48 PM
Discussion Power systems for 3D LabPrints fighters stangrob 3D Printed Planes 2 Apr 26, 2017 12:48 PM
Discussion Trouble scaling 3D Labprint file. FidlerEd 3D Printed Planes 3 Apr 18, 2017 05:49 PM
