Thunder Tiger Robotix HXC2 Jupiter Fuel Cell
Thunder Tiger recently showed a video of a new helicopter called the HXC2 Jupiter. It's a hydrogen fuel-cell powered large helicopter that will be amazing for long flight times.
Thunder Tiger Shows Off a Fuel-Cell Heli
Thunder Tiger recently showed a video of a new helicopter called the HXC2 Jupiter. It's a hydrogen fuel-cell powered coaxial helicopter that will be amazing for long flight times. It has a 6000W fuel cell module which can be seen on the outside with carbon fiber cylinders that are filled with hydrogen.
They say the flight time is 3 times that of a conventional drone and can carry a greater payload. That translates to hours of flight time carrying an array of sensors and data capturing equipment. It is the world's only fuel-cell powered coaxial helicopter. Other specs are light at the moment, but more details should be available once Thunder Tiger Robotix puts up the webpage for it.
Learn more at the ThunderTigerRobotix Site Here
Sep 24, 2018, 10:54 AM
Recovering nitro addict
papa38's Avatar
Too cool
Sep 25, 2018, 10:48 AM
Just what Amazon needs!
Sep 25, 2018, 12:35 PM
Front Yard Flyer
Decnav's Avatar
Im interested in seeing it move about. Would like to see if it suffers from the pendulum effect like the old blade cx
Sep 25, 2018, 03:08 PM
Horizon Hobby Employee
aaronredbaron's Avatar
this is nothing like the coaxial counter rotators that were common in the hobby about 10 years ago. Those used a self stabilizing flybar arrangement on the top rotor, hobby grade coaxials often had a lower rotor blade swash plate. this new helicopter is akin to the Kamov helicopters from Russia. These have both a lower and upper swashplate. Full scale use a pushrod in the center of the main shaft to control the differential pitch required to cause yaw, this model may just utilize differential speed with independent motors for yaw, but it does have a top rotor system with a full swashplate, so it should not suffer any of the pendulem effects you are mentioning.
https://www.youtube.com/watch?v=4RITbQHLLhU
here is a model proving coaxials aren't all the same
Coaxial 3D 550/600 twin motor (4 min 24 sec)
Sep 25, 2018, 03:09 PM
delete, duplicate post
Sep 26, 2018, 07:54 AM
UAV Flight Operations Manager
Very cool video, Aaron!
Sep 26, 2018, 08:22 AM
It looks to me like it has a pushrod going through the center of the main shaft for differential pitch for yaw, as indicated by the mixing assembly above the upper rotor head. If that is true it gets the odd and complicating resultant reversing yaw phenomenon that all bicopter helicopters experience, when you use differential pitch for yaw, it flips on you with negative pitch.
Sep 26, 2018, 10:28 AM
Front Yard Flyer
Decnav's Avatar
last time I saw a big outdoor collective pitch coax, it never made it to production. I was interested in this thing https://www.rcgroups.com/forums/show...g-to-market%21
Oct 01, 2018, 01:29 PM
amateurs.....yaaawn
try 50-200km range without looking bloated like a frog
http://www.pulseaero.com/uas-products/vapor-55
https://schiebel.net/products/camcopter-s-100/
News Thunder Tiger Robotix Ghost Quad Copter Jason Cole Multirotor Drone Talk 14 Oct 13, 2017 04:19 PM
Discussion Super Tiger S3250 question (fuel economy) kenh3497 Engines 41 Feb 15, 2016 12:01 PM
Cool IOn Tiger: ONR Fuel Cell UAV Ken Lapointe Electric Plane Talk 0 Apr 01, 2009 01:25 PM
Discussion Thunder tiger 46 fuel flow issue robandeva Engines 10 Jul 08, 2008 10:27 AM
