This thread is privately moderated by montis, who may elect to delete unwanted replies.
Sep 23, 2018, 03:17 PM
Mini-Review
Jumper T8SG Lite radio transmitter review
In the August of 2018 Jumper introduced the T8SG Lite radio – the “little brother” of the Jumper T8SG.
Jumper T8SG Lite
Lite version of the T8SG comes in a small box, with a chance to be broken in the severe postal processes. I have received the undamaged unit despite my package beeing totally crushed.
Inside the box we can find the transmitter itself, USB mini type cable and nice Jumper neck strap (lanyard).
There was no manual included in the package, but you can download the T8SG Lite quick start guide manual: http://www.hobbyporter.com/u_file/18...84fee4f29b.pdf
Also you can use T8SG V2 User manual for Lite version as most of the Deviation features are the same: http://www.hobbyporter.com/u_file/18...6b4871acd1.pdf
Jumper T8SG Lite has the same 1.7” LCD display as the T8SG V2 transmitter.
Two leds indicate the power on status of the transmitter also there is small speaker behind the small openings over the power button.
Once powered on you will be welcomed by Deviation firmware.
There are Enter/Select (the top one) and Cancel/Returm button (the bottom one) located on the left side of the T8SG Lite.
Navigation and value adjust buttons are on the right side.
There are pot and switch located on the each of the top sides. So this transmitter counts total 8 controls (4 axes, 2 pots and 2 switches). These controls can be assigned to the channels in the Deviation Firmware.
On the top of the transmitter you can find 3.5mm socket for trainer port or PPM output and mini USB socket for connecting with PC.
There is no module bay on the back side of the transmitter.
The 4 AA size battery bay opens vertically.
Size and feel
This transmitter is REALLY small! It easily fits in my hand!
T8SG Lite is marginally smaller than Flysky FS-i6 transmitter.
There is very small distance (only 9mm) between the tip of the stick and the switch. This can be the problem for the pinchers.
Switch is impeding while pinching.
No problems for thumbers.
Side pots are in the inconvenient position. It would be more convenient if the side pots were on the top side of the transmitter.
Gimbals
The gimbals of T8SG Lite is toy grade gimbals similar to ones that can be found in the toy quadcopters.
The gimbals have short sticks with metal grips on the endings. They cannot be extended.
Radio transmitter has gimbals intalled in MODE2 configuration. So the Throttle is on left. You can easily swap the gimbals to make MODE1.
The first problem with the gimbals is the left gimbal plastic rubs into the edge of the top cover and comletely binds to it at the rightmost position. This is annoying and may lead to unpleasent surprise while flying the aircraft.
My solution to this problem is adding some thin plastic washers on the gimbal mount.
Another dirty simple solution is to unscrew the two screws, holding the left gimbal side for just a half of the turn.
Another gimbals issue – they have noticeable deadband in the middle of the stick travel.
Third issue – as the cut for the gimbal is in the form of the circle, you can’t get the maximum stick travel in the diagonal stick travel. Below is the photo of the right gimbal values when the stick is at the top right “corner” – you’ll get about 83-85 percents while the maximum values should be 100 and 100.
Teardown
Radio can be easily disassembled by unscrewing 6 screws. Everything is mounted to the top part of the shell – gimbals, pots, switches, LCD and PCB.
Antenna is 2.4GHz dipole antenna with cylindrical bell.
RF module is made of CC2500 chip and RXF2401C PA/LNA amplifier chip.
Main MCU is ARM STM32F103RCT6 and is used in all most Jumper radios.
All the gimbals, pots and switches are installed in separe PCB boards and connected with the mainboard via ribbon cables.
From the front side of the mainboard we can locate trim buttons, haptic vibration motor, buzzer and control buttons. LCD is 1.7″ size with 128 x64 px resolution. The same display as in Jumper T8SG V2.
Neck strap hook is not well balanced, radio leans towards front when hanging on the lanyard. However I don’t think anybody will be using the neck strap for this radio as it is very small and light.
Available @ Banggood: http://bit.ly/Banggood-Jumper-T8SG-L...io-Transmitter
Quick Start Guide for Jumper T8SG Lite: http://bit.ly/Quick-Start-Guide-for-Jumper-T8SG-Lite
Deviation User Manual for Jumper T8SG series radios: http://bit.ly/Deviation-User-Manual-For-Jumper-T8SG
Read more on Multirotorguide: http://www.multirotorguide.com/revie...mitter-review/
PROS
  • Small lightweight radio
  • Cheap, but not the cheapest
  • Runs Deviation TX firmware
CONS
  • Toy grade gimbals
  • Deadband in the center of gimbals
  • 3-way switches touch the fingers while pinching
  • Pots positions are inconvenient
  • Questionable selection of Frsky module
CONCLUSION
This is toy grade transmitter with super simple gimbals. There is a noticeable deadband in the middle of the gimbal sticks travel, that can be noticeable for advanced pilots, but can be bearable for beginners. The choice of the RF module with Futaba and FrSky protocols is really questionable as these systems are mostly used on higher end systems. It would be more reasonable to have Flysky or the module that controls most of the toy quadcopters (Syma, Bayang, Wltoys, etc).
The fact that this small transmitter runs Open Source Deviation firmware opens the posibilites to mod this radio for other protocols or anything the hobby enthusiasts would think of.
Jumper T8SG Lite could be an option for the youngest beginners as the first radio, doing the first steps into the magnificient world of the RC hobby.
Disclaimer: This item was supplied by Banggood for a fair and unbiased review. Banggood never asked for a positive review and never infuenced my opinion in any way. I’m trying my best to stay uninfluenced and give only my own opinion. All affiliate links, if there are any, will help me purchase more items for independent reviews.
Discussion Jumper T8SG Lite Multi-Protocol Compact Full Range Radio Transmitter-- Free Reviewing BGKevin Radios 221 Apr 19, 2019 09:25 AM
