Sep 22, 2018, 10:18 AM
SuperCal's Avatar
Esc's won't initialize
Hi everyone,
I'm using a Vector in my quadcopter and the esc's won't initialize when i plug the battery in. It has been flown before and everything seemed ok. I've tried everything I can think of, even tried running a different Vector and still no luck. The esc's work fine when plugged directly into the receiver though. Any ideas would be appreciated...
Thanks in advance... Calvin
Sep 24, 2018, 08:28 AM
JohnET's Avatar
Hello,
Have you reviewed the log file to see if there is an error? Some errors will not allow the system to arm. Otherwise I suggest recalibrating the ESCs and re-running the RX Wizard. Also, a change in your radio could cause the issue and it may be a good idea to create a new model in your radio. If you cant get it working please open a support ticket and provide your log and config files.
Regards, John
Discussion Tarot 2D Gimbal won't initialize CrimsonCup Multirotor Drone Talk 1 Feb 15, 2016 03:28 PM
Question ESC won't initialize JGallo Power Systems 6 Feb 14, 2016 11:30 AM
Discussion ESC won't initialize? SDScuba Car Talk 1 Nov 12, 2007 11:11 AM
Help! HiModel 18/22A ESC Won't Initialize bevers01 Power Systems 0 Sep 12, 2006 09:32 PM
Help! ESC won't initialize kharrison Power Systems 3 May 14, 2006 12:58 AM
