Thread Tools |
This thread is privately moderated by old4570, who may elect to delete unwanted replies. |
Mini-Review
Predator 40A ESC![]() For review : Predator 40A ESC Sent by : Fasttech.com Link : http://shrsl.com/127wr Finally had the weather and the time on my side to test the Predator 40A ESC . What attracted me to this ESC was simply that it was ready to go , everything is soldered in place - XT60 plug and bullet connectors for the motor . To test the ESC my plan was to run it at the rated current and see what happens ( Heat - power sag ) , look for those tell tale signs that maybe everything is not right in the world . The first prop I tried is a 10.5 x 5 and the motor pulled 30A .. The Predator 40A never got more than barely warm at all .. So obviously I had to try a larger prop to load up the motor to put the ESC under some pressure as 30A was doing nothing to the ESC . Danger Danger : I swapped props and put a 11x6 Master on the motor . When I did this I also changed the battery , putting the first one on the charger . As I plugged in the battery and slowly cranked in power . Something strange happened . The power sagged something terrible .. Got to run through that check list right ? Did I over prop the motor = Nope Was the ESC overloading = Nope ![]() Only thing left is the battery ! So carefully applying power I watched the power meter .. 5 amps / 10 amps and at 15 amps the battery began to collapse , or should that be the voltage was collapsing ... 10 volts , 9 volts , 8 volts , 7 volts ![]() Bad Ju Ju folks - Looks like the battery can not sustain a discharge any longer .. Much better to find these things out under test conditions rather than say trying to take off with possibly a expensive model .. Oh well ! With the first battery hitting 4.1v per cell , I thought enough .. With the Master 11x6 on the motor , I applied power till I hit 40 amps ... After a while I thought I should check to see if the Predator 40A was at least getting hot ? Nope ! It did get warm how ever , but not hot . The maximum power I could put through that combo was 42 Amps with the 3s sagging to 10v under load ... 10v * 42A = 420 Watts with the Master 11 x 6 The only thing that approached getting hot was the motor , it warmed up very nicely with the Master 11x6 in place . I would say I was very close to the comfort ceiling of that motor . Considering that the motor got mildly warm with the 10.5 x 5 @ 30A ... Sorry guys I did not tach the 10.5 x 5 .. But for the Master 11x6 = 420Watts / 9060 rpm ( Ranged from 8900 to 9000 ) That motor be a budget motor , intended for a electric control liner .. Back to the Predator 40A ESC : I'm really impressed with the ESC , it handled 40A really well . Did not get hot and there was no power sag . Everything is pre soldered and there is nothing obvious to fault . Fasttech.com is currently selling the Predator for $14.76 and there are other plug options ( Like the T plug ) , but for $15 USD with everything soldered the Predator 40A is a rather good deal handling it's power rating with no issue's . |
Thread Tools | |
Similar Threads | |||||
Discussion | Identification of RW.RC 30 and 40A ESCs for wii esc flashing | tete | Multirotor Drone Electronics | 1 | Jan 02, 2016 12:18 PM |
Discussion | HVSK-40A Multicopter Brushless ESC 40A (OPTO) can't be programmed? | psindrup | Multirotor Drone Talk | 6 | May 09, 2013 05:37 PM |
Discussion | Will a 30A ESC ruin a 40a ESC motor? | macentyre | DIY Electronics | 5 | May 07, 2013 11:01 PM |
Poll | What is better tower pro 40h esc or mystery 40a or hkss45 esc | boylonely004 | Power Systems | 3 | Jul 22, 2011 08:57 AM |
Discussion | What happens when using LiPo battery recommended for 40A ESC into a 30A ESC? | Fernlope | Power Systems | 2 | Mar 31, 2009 01:05 AM |
