Sep 20, 2018, 01:18 PM
Sucker for biplanes
DMHIGHFLYER's Avatar
Hangar 9 P-51D Mustang 20cc ARF 69.5” (HAN2820)
Will be pre-ordering this one!
Hangar 9 P-51D Mustang 20cc ARF 69.5" (4 min 10 sec)
Features
Expertly constructed with lightweight, laser-cut balsa and plywood
Finely detailed, satin-finish covering includes scale nomenclature, panel lines, and more
Two decal sets let you customize the trim in “Geraldine” or “Sky Bouncer” livery
Detailed cockpit includes a 3D instrument panel, expertly painted pilot bust and more
Rugged fixed landing gear with 4-inch wheels and realistic shock-absorbing struts (included)
Retract ready—optional E-flite® electric retracts available
Optional tail retract and closing doors (retract, sold separately)
Functional flaps expand the flight envelope and enhance scale functionality
Scale control surface hinge lines, gear doors, wing guns and antenna
Painted cowl with simulated engine and exhaust detail
Scale spinner with matching paint finish
Optional-use wing pylons with removable drop tanks (remote release sold separately)
Two-piece, plug-in wing for easy transport and final assembly
Large top-hatch offers complete access to the electronics and fuel tank
Complete hardware package includes everything for EP or gas power recommendations
Back-Story
Make it powerful and make it able to fly far. These simple requirements sparked North American Aviation to create a phenomenal weapon called the P-51D. Beyond its muscle, gas storage and gun slinging capabilities, pilots loved to fly it. Better known as “Mustang,” it became America’s favorite fighter airplane, possibly of all-time. The Hangar 9® P-51D Mustang 20cc ARF brings valiant tales of this warbird to life in a convenient 1/6-scale model with unrivaled authenticity.
Overview
The Hangar 9® P-51D Mustang 20cc ARF is an expertly crafted model that combines modern engineering, outstanding flight capability, plus no compromise power-it-the-way-you-want-it expertise to deliver a replica warbird with stunning looks. Modeled after Mustangs used by the 375th Fighter Squadron during WWII, it’s constructed in 1/6-scale with lightweight balsa and plywood for legendary durability.
Leading the list of stunning details is the expertly applied, satin-finish covering of the sleek airframe. The lightweight material captures within scale features like panel lines, rivets, nomenclature and distinct colors for a brilliant appearance that’s durable. Bringing out its authenticity even further is a well-appointed cockpit with a 3D instrument panel, an intricately painted pilot figure and faceted utility compartment. Cowling detail features a matching finish with scale inlets and exhaust, plus a matching spinner. Optional-use wing tanks can be attached on the included wing pylons, or removed to improve high-speed maneuverability. Functional shock-absorbing gear struts include trailing-link suspension and scale-style axles with room for large wheels that make flying from grass easier.
No matter how you look at it, this Mustang is an impressive model for its size. Its two-piece wings smoothly connect with the scale wing fillet and distinct air scoop to lock-in without any need for tools. Control surfaces feature airfoil-shape design for smoother flight, and scale hinge lines with factory drilled hinges for easy installation. You can take the scale experience higher by replacing the rugged fixed landing gear with E-flite® electric retracts available for both the main and tail wheel locations. Functional flaps allow for a wider flight envelope that includes shorter takeoffs and slower landing speeds.
A large top-hatch provides extensive interior access from the cockpit to the firewall. The included hardware package is complete to make assembly as simple as possible and provide easy-to-install mounting options for all the electric and engine power recommendations. No matter what power plant you install, handling in the air is impressive with a look and control feel that honors the original. Whether this is your first warbird, or the perfect complement to your collection, the Hangar 9 P-51D Mustang 20cc ARF is the historic success story you’ve been looking for.
Needed to Complete
20cc two- or four-stroke gas engine or equivalent electric motor system
Full-range, 5+ channel transmitter and receiver (6+ for the retract option)
(8) Standard-size servos (7 for the electric power option)
(2) Batteries for receiver and engine ignition (for the gas power option)
(1) Propeller
What's in the box?
(1) Hangar 9 P-51D Mustang 20cc ARF
(1) User Manual
Lightweight Construction
Laser-cut, lightweight balsa and plywood construction is utilized to bring the P-51D Mustang 20cc to life as a durable scale model that's expertly built to exacting standards.
Scale Detail
Beyond the factory applied satin-finish printed covering, other iconic details include airfoil-shaped tail surfaces, realistic engine exhaust, wing guns, gear doors, optional-use drop tanks, radio antenna, a 3D instrument panel and a painted pilot figure—just to name a few.
Scale Detail
Functional Flaps
Light wing-load and a semi-symmetrical airfoil offer flight performance that’s comfortable at a wide range of speeds. Operational flaps allow its versatile flight envelope to open even wider so you can increase flight realism that includes shorter takeoffs and slower landings.
Functional Flaps
Convenience Features
The wing panels feature a strong aluminum tube joiner for ease of transport and storage. When the model is upright, full access inside the model is through a large top-hatch that makes any maintenance and battery changes simple.
Custom Decals
Choose from one of the two nose-art decals included to finish your model off. “Sky Bouncer” was flown by Captain Bruce (“Red”) Rowlett, and “Geraldine” was flown by Captain Charles Roscoe (“Chuck”) Cummins, both with the 361st Fighter Group, 375th Fighter Squadron stationed in England during WWII.
Custom Decals
Optional Retracts
Rugged fixed landing gear with functional shock-absorbing struts are included so that you can keep the project simple and still enjoy the benefit of smooth ground handling. The optional E-flite® electric retract system recommended accepts the struts, feature all-metal durability and are an easy installation that lets you take in-flight scale realism to a higher level. There’s even an electric tailwheel retract option that can utilize the gear doors included.
Optional Retracts
Power It the Way You Want It
The P-51D Mustang 20cc is designed to accept the Evolution® 20GX, 20cc gas engine, a Saito FG-21, 21cc four-stroke or E-flite Power 60 brushless electric outrunner motor system with a 6S LiPo battery. All hardware needed to install any of the recommended power system is included along with an electric motor mount so you can get to assembly right away and in the air faster. This 20cc ARF is also the perfect replacement airframe for the stock motor, ESC, and recommended flight battery used in the giant E-flite® Carbon-Z® T-28.
Sep 20, 2018, 01:23 PM
Sucker for biplanes
Looks nice, like the hatch.
Sep 20, 2018, 06:24 PM
Very interested
Sep 20, 2018, 06:32 PM
Arrowhead
Likewise, quite interested. And not really a big Mustang fan!
Sep 20, 2018, 09:52 PM
Sucker for biplanes
I got mine ordered today. I didn't really need another P-51, but I couldn't resist. This can replace my old H9 P-51 Marie, it's pretty rough at this point.
Sep 20, 2018, 09:57 PM
It’s a great flying plane. You will love it
Sep 21, 2018, 12:10 PM
Sucker for biplanes
Anyone know a part number for the struts, I don’t see them listed on HH or E Flite?
Sep 21, 2018, 04:26 PM
Warbird & Jet Lover
The struts are included with the ARF and drop in to the recommended retracts.
Sep 21, 2018, 06:20 PM
Sucker for biplanes
Thanks Dave, I see that in the info now. That’s a plus!
Sep 21, 2018, 08:24 PM
bonemadderek's Avatar
Not for me, already got a 60 sized Stang and F82
Oct 01, 2018, 12:19 PM
Sucker for biplanes
I would think the 20cc P-51 should be shipping soon so I'm looking into power options. I have a nicely broke in VVRC 20 and a fresh YS 120 to use on this build. The manual states the engine distance is 6.25" from the firewall. Took a measurement of the VVRC 20 mounted on my Stick and it's at 5.5" between firewall and spinner. So a rear mount carb should fit fine. (DLE 20, VVRC 20)
Oct 02, 2018, 08:25 AM
ncflyer79's Avatar
If you find out the length of the struts let me know. Im wondering if I could use them in my blue nose mustang
Oct 02, 2018, 10:11 PM
Sucker for biplanes
Yes I will, hope they ship soon.
Oct 04, 2018, 10:13 PM
Sucker for biplanes
Saw the 20cc P-51 on EBay today for sale. I didn't get a tracking # today, was surprised to see it on EBay before the preorders were sent out.
Oct 08, 2018, 08:47 PM
Sucker for biplanes
So I ended up canceling my order with HH and then ordered of eBay to save on the tax, which was around $30. I still ended up getting the plane shipped faster than a pre order plane. I will have the P-51 on Wednesday. 🙂
News Hangar 9 P-51D Mustang 20cc ARF 69.5" (HAN2820) Jim T. Graham Scale ARF/RTF 240 Oct 13, 2019 08:07 PM
New Product Hangar 9 P51-D Mustang 20cc ARF ncflyer79 Electric Warbirds 86 Oct 06, 2019 10:39 PM
Article Hangar 9 P-51D Mustang Sport 40 ARF with Robart Retracts Review Michael Heer Electric Warbirds 52 Mar 19, 2012 07:14 PM
Discussion Hangar 9 P-51D Mustang Sport 40 ARF Thad Eckland Sport Planes 3 Jan 21, 2010 12:04 AM
