This thread is privately moderated by aopen3434, who may elect to delete unwanted replies.
Sep 19, 2018, 07:21 AM
New Product
ST5XHPT military grade mini HDMI Video and Data http://OFFTHEGRIDWATER.CA
ST5XHPT is a Economy military grade mini HDMI Video and Data transmission COFDM system for UAV. It support HD720P video Range 1-2km
It develops CABAC (H.265+TS) coding&decoding technology to achieve Utra-high resolution(720P), long distance(air to ground 5km) and low delay(12-25ms)
transmission. The system supports (data&image) communication, adjustable video resolution, bit rate output with the TPlayer software. It can realize the soft decoding with low delay. Meanwhile this SUNTOR series products have small size, light-weight, low consumption, high stability and high sensitivity. They are suitable various environment of different application.
Features
 Video Input: HDMI
 Resolution: HD 720P
 Distance: Air to ground 5km
 Latency: ≤12-25ms
 Duplex Data Transmission: TTL-RS232/485
 Dimension: 73*48*14mm
 Weight: TX 58g/RX 58g
Model: ST5XHPT Frequency 2.4GHz(2.402-2.478GHz)
Wireless Fault-tolerant LDPC FEC
RF Transmitted Power 27dbm (Air to ground 5km)
Power Consumption
TX: 7Watts
RX: 5Watts
Frequency Bandwidth 2/4/6/8MHz
Latency ≤12-30ms
Video Color Space Default 4:2:0 optional: 4:2:2/4:4:4
Antenna 1T1R
Video Input/output Interface HDMI mini TX/RX, or transform FFC to HDMI-A RX/TX
Video Compressed Format H.265 +TS
Bit rate Adjustment DIP or SPI2MCU
Encryption WEP, WPA(PSK), WPA2(PSK), WPA+WPA2 (PSK)
Transmission Distance Air to ground 5km
Start-up time < 25s
Two-way function Support video and duplex data simultaneously
Data Support Duplex TTL RS232/485 Data Transmitting
Power supply DC 7- 18V
Transmission Rate 3-5Mbps
Receiving Sensitivity [email protected]
Interface
720P HDMI Mini RX x1 S1 TTL bidirectional serial port x1 RF SMA Power Input x1 Indicator Light
HDMI input/output Status Transmitting and receiving Video board working Status Power Temperature Range
Operating temperature:0C ~+ 85C Storage temperature:-10C ~+ 90C Appearance Design CNC technology/ double aluminum alloy shell with waterproof design
Dimension 734814mm
Weight Tx: 58g/Rx: 58g
http://OFFTHEGRIDWATER.CA/
New Product HOBBYWING XROTOR M2405-2600KV 30A ESC FPV POWER SYSTEM http://OFFTHEGRIDWATER.CA aopen3434 Product Announcements 0 Nov 03, 2017 07:50 AM
New Product ZYX-MINI Tarot Multirotor Flight NEW http://OFFTHEGRIDWATER.CA aopen3434 Product Announcements 3 Jul 03, 2016 11:12 AM
New Product HDMI to AV 5.8G 600mW 32 Channel & WIFI transmitter 2.4G http://offthegridwater.ca aopen3434 FPV Equipment 0 May 06, 2015 09:07 AM
